Piper Aztec - Purchase Advice
Old July 3rd 05, 10:24 AM
Bongo
Default Piper Aztec - Purchase Advice
I'm looking at purchasing an early (1960) Piper Aztec. I would like to know
what should be checked and what the real gotchas are on this age of
aircraft.
Dean
Old July 4th 05, 03:09 AM
Jim Burns
Google this groop for my name + Aztec. Any specific questions you can email
me, I'd be glad to help.
Jim Burns
"Bongo" wrote in message
know
aircraft.
Dean
Old July 7th 05, 01:14 PM
Dean
Jim Burns
know
aircraft.
Dean
Thanks Jim
I've put a deposit down on the aircraft. The owner has spent a lot on
it over the past few years so it should be in good condition (pre
purchase will confirm), its also been flown regularly which is a plus
in my book.
One question is to do with handling. I've flown it, and its a pussy
cat, however my home grass strip at 600m (2000ft) is plenty long
enough, especially lightly loaded (it doesnt get over 65c here usually
and i'm at 400amsl). It does have a tricky close in tight turn of 90
degrees at a few hundred feet and 1/2 mile from the threshold (we have
pylons at the end of the strip). On other aircraft, no problems, and
I've landed a lot on this strip, and know it well, but i've only 60
hours on twins so not too sure.
There is a 700m hard runway not too far away, but just to sit the
aircraft outside is over 300US dollars/month. I'll definately keep it
here short term until I'm familiar with the aircraft.
In the UK we have a CAA notice 75 on the props (complete strip down,
inspection and replacement of seals, rebuild etc) every 6 years. This
is due next month. I have the option of putting it on the N reg (run
on condition) but do you think the prop overhaul is a good idea anyway
(in the UK its about 7000 dollars for both props).
Cheers,
Dean
Old July 7th 05, 06:42 PM
Jim Burns
Landings is where Aztecs really shine. I see no problem having to maneuver
on final, they are very stable airplanes and are able to fly particularly
slow for a twin. The length of your strip could be an issue. The balanced
field length for ours is 2200 feet at sea level on an asphalt runway. Grass
and a higher density altitude will increase that dramatically, loose an
engine at rotation speed and you won't get it stopped. If you plan on
flying in and out of grass strips, have your gear struts pumped up. On our
plane, the normal prop clearance is only 8 inches, we've got the struts
pumped up so it's much more comfortable.
The prop question on this vintage of Aztec is always a problem. You have to
weigh the repetitive expense vs. the time period you expect to own the
airplane. This was something that we specifically avoided when shopping for
ours, we simply didn't want the expense and hassle. Non AD replacement
props are outrageously priced.
Other items previously mentioned in other threads a
Generators/Alternators dual or single
Hydraulic pump electric backup?
Hydraulic power pack age/condition
Autopilot, if this age Aztec has an original Mitchell or Century, nobody
will touch it for repairs
Heater, AD's, inspections, nozzle, igniter, combustion and ventilation motor
brushes
All "smooth" hydraulic lines need to be replaced with braided or "rough
surface" lines
Fuel bladders
If you need one, there's a spinner back plate on Ebay right now for an early
Aztec.
Good luck,
Old July 8th 05, 06:17 PM
Kyler Laird
"Dean" writes:
I like to go out on stormy nights to get my three night landings for
currency. The storms clear the pattern from all of the students so I
can have fun. The tower here usually lets me do fun things like depart
10 and then immediately flip around and land 23. The Aztec *is* truck-
like but I feel very comfortable doing close-in maneuvers in it.
If the standard Aztec feels marginal on your home strip you can always
add vortex generators, flap seals, wingtips, etc. to improve the low-
speed handling. (I don't have them yet.)
We just replaced the props on ours to eliminate the AD. I've run into
problems enough even with those new props that I'd tend toward getting
a prop overhaul anyway - perhaps as part of the pre-purchase
negotiation. (We were told our props would be good.)
Good luck!
--kyler
Old July 9th 05, 04:52 PM
Dean
Kyle,
I think landing at our strip will be okay, i'm just not used to hauling
twins around the way I do singles. Perhaps a few hours in the Aztec
will sort that out.
The prop overhaul is probably a good idea anyway, and i'll include this
on the pre purchase (i.e. the props have to pass the inspection).
As an aside, how much are the no-AD props?
Dean
Old July 10th 05, 04:17 AM
Kyler Laird
"Dean" writes:
will sort that out.
Yeah, I got the Aztec before my Private so it's the only plane I *really*
know but I'm quite comfortable swinging it around. The controls might
seem a bit heavy but I think you'll enjoy it.
As I recall ours were $7K/side (props and hubs).
--kyler
Old July 21st 05, 05:58 PM
Bongo
I've now had the pre-purchase and apart from a few minor things the main
issue seems to be that the right gear leg is slightly higher than the left.
The engineer thinks the oil has leaked around the seal and its frozen in
place, but isn't a killer on the deal. I'll get the current owner to rectify
this with new seals before sale.
The compressions are reasonable with the left engine having a couple of
cylinders in the mid to high 60's, but I expected this with the engine
having 2100 hours on.
Regards,
Dean
know what should be checked and what the real gotchas are on this age of
aircraft.
Dean
Old July 21st 05, 06:33 PM
Jim Burns
Good luck! I see that the owner of an older local Aztec has his price down
to "Best offer over $22,000
left.
rectify
Regards,
Dean
aircraft.
Dean
Old July 21st 05, 06:49 PM
Dean
Jim,
Prices on older Aztecs seem to very "realistic" at present. Here in the
UK where fuel is getting over 7USD/gallon its must be starting to hurt
some people. For me it gives me the chance to get into a twin, without
paying big bucks. I dont mind and expect to pay higher maintenance and
running costs.
I also had the problem that there are literally no twins to rent within
100 miles of where I live. The only one I could find a Seneca IIT is
about 400USD/hour (and thats reasonable over here!).
Lets hope the pre-purchase was accurate!
Dean
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 03:32 AM
WTB: Piper Aztec C Jim Burns Aviation Marketplace 0 July 20th 04 08:38 PM
Piper Aztec and/or Apache owner groups? Ronnie D. Hughes Owning 3 April 1st 04 08:00 PM
Piper Aztec F Model Dual Hydraulics(1976-1981) STC Keith Owning 4 February 12th 04 05:52 AM
Piper Aztec handling qualities John McFarlane Owning 1 October 3rd 03 05:11 PM
