Are All Batteries Created Equal? (Does Size Matter?)
Old July 6th 05, 11:23 PM
Default Are All Batteries Created Equal? (Does Size Matter?)
Anyone have any experience with the 12-volt PowerSonic PSH-12100 10.5
AH sealed lead-acid battery? It's the same "footprint" (length and
width) as the 7.5 AH batteries most of us use but about 2/3 inch (17
mm) taller.
PowerSonic rates its own PSH-1280--the size most of us use--at 8.5 AH
which is already 1 AH more than most similar batteries, a 13% increase
for this brand. Then they spec 10.5 AH for the taller battery--a 24%
increase--with approx. 18% increases in volume and weight.
I know battery capacity isn't strictly proportional to size (I assume
there are some fixed components to each). And there are differences in
design among manufacturers. But does anyone have any first-hand
experience with the taller battery? Or know whether the upgraded
capacity is more or less likely to be marketing hype? Looking at the
specs for both, it doesn't appear that PowerSonic is playing games with
the numbers to favor the taller battery.
Another higher-capacity alternative--a battery with the same length and
height but wider--would require modifying the battery box and
associated mounting in my ASW 24.
With more electronics in the cockpit every year, I'm looking for easy
ways to add electrical energy with no or only minor glider surgery. Tim
Mara has both types in his online catalog, by the way (this is a
non-commercial, informational message intended for those who aren't
familiar with the batteries typically used in gliders).
Chip Bearden
ASW 24 "JB"
Old July 6th 05, 11:39 PM
01-- Zero One
Chip,
I have a couple on order right now... Will let you know how it goes.
www.extremebatteries.com had them for $19.85 each.
Larry
" wrote in message
mm) taller.
Chip Bearden
ASW 24 "JB"
Old July 7th 05, 12:01 AM
Robert Backer
I can't testify as to the 10.5 AH powersonic, but I can sing the praises
of their 8.5 AH that is exactly the same size as the old 7/7.5 AH
batteries that many gliders use. The two battery holders of my Ventus C
fit these batteries exactly. I have made a 6 hour on one of these
batteries with radio, transponder, encoder, 302 and Ipaq and did not
have to switch to the backup.
Bob
01-- Zero One wrote:
Chip,
Larry
" wrote in message
mm) taller.
Chip Bearden
ASW 24 "JB"
Old July 17th 05, 03:04 PM
David Kinsell
mm) taller.
Tim also has Powersonic 4 and 6 volt 10 AH batteries in his catalog. Two
4's and a 6 would give a whole lot more *usable* capacity than a 12V 10.5 AH,
when powering 14 volt instruments such as your radio.
Instrument overhaul - Are all overhauls created equal? RonLee Home Built 1 February 7th 05 07:35 PM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 6th 04 12:14 AM
Size does matter HECTOP Piloting 59 May 14th 04 12:48 AM
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future Jack White Military Aviation 71 September 21st 03 03:58 PM
