Remote Switch for Pointer ELT --- Why Does It Need Voltage?
Old November 22nd 04, 08:57 PM
jls
Default Remote Switch for Pointer ELT --- Why Does It Need Voltage?
The remote switch wiring diagram for the Pointer ELT shows a lead running to
the aircraft's 12V power supply. Why's that? The switch on the unit
itself doesn't require a connection to the aircraft's power supply. TIA.
Old November 22nd 04, 10:13 PM
On Mon, 22 Nov 2004 14:57:16 -0500, " jls"
I believe there is a pilot light on the switch, which requires 12
volts.PN 2019-10 is listed as a "remote switch/monitor kit"
Lycoming remote oil filter Evan Carew Home Built 0 November 5th 04 11:09 PM
Jim Weir - PTT switch article? Corrie Home Built 2 October 4th 04 05:46 PM
How to use Lycoming remote filter Evan Carew Home Built 0 October 1st 04 12:43 AM
REMOTE CONTROLLED AIRCRAFT RCPLANE Home Built 0 December 18th 03 07:40 PM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 03:21 AM
