Tow Hook 337 for a 150-150
Old July 18th 05, 05:18 AM
1JH
Default Tow Hook 337 for a 150-150
Does anyone have a 337 they can share to demonstrate to the FAA that a
150-150 is suitable for towing gliders?
Old July 18th 05, 06:27 AM
Pete Brown
You don't need a 337 to show a 150-150 is suitable for
towing, you need to comply with 91.309 (2) which reads in part:
Section 91.309: Towing: Gliders and unpowered ultralight
vehicles.
(2) The towing aircraft is equipped with a tow-hitch of a
kind, and installed in a manner, that is approved by the
Administrator;
FAA Advisory Circular AC 43.13-1B ACCEPTABLE
METHODS,TECHNIQUES, AND PRACTICES ¾ AIRCRAFT INSPECTION AND
REPAIR, has a section on tow hook installation that you
might want to review to assure yourself that his eminence,
the Administrator, will approve your installation.
IIRC, the Schweizer tow hook was approved for all tricycle
gear Cessna's as a bolt on installation. Contact Mary Backus
at Schweizer at 607-739-3821 x4247 or e-mail at
or for
details on that approval data. I have no idea if Tost has
been approved on such a Cessna.
I assume your 150-150, is now a tail wheel aircraft so that
originally approved installation may not work. As an
alternative, I will email you a photo of my Schweizer hook
on my 170. The hook is bolted on to the tail wheel spring in
a neat installation.
Whether the 150-150 is adequate for towing will depend,
amongst other things, on what you are towing (mostly how
heavy) and where (density altitude), cooling considerations
for your particular engine and cowl combination, and how
patient your waiting club members or customers are.
Pete Brown
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Old July 19th 05, 12:41 AM
We are using 150/150 as a tow plane in our club. Refer to the posting
above for the tow hook instalation. The performance is rather on a week
side but we are towing 2 seat Lark IS28B2 at its max. gross weight;
the climb is only 200-300 fpm at density alt. of 3000'. Log on to the
SSA web site and under "Where to Fly" find Cascade Soaring Society, go
to "Members" and call our club president. He is the chief tow pilot and
he is very helpful gentleman. He will give you any info you might need.
Thanks.
Old July 19th 05, 07:35 PM
pbc76049
Thanks.
I bet a lot of the performance (or lack of) has to do with picking a prop
optimised for climb. Might be worth a peek anyway....
Scott
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 11:48 AM
Is it Possible to Self launch (no wingman) with CG hook?? Jerz Rossignol Soaring 43 November 16th 04 08:54 AM
Tow hook for a Cesna 185? Gary Boggs Soaring 4 February 13th 04 03:09 AM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 01:50 AM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 07:20 AM
