Cherokee Strut Lower Strut Seal Replacement Report
Old July 20th 05, 03:22 AM
Mike Spera
Default Cherokee Strut Lower Strut Seal Replacement Report
Well, did my first seal swap on the 140 on all 3 legs. Took me and the
wrench about 5 hours total. Completely slimy, dirty job. Remember, I
worked in my father's body shop as a younger man, so I am no stranger to
being filthy. This was worse. Being dirty WITH oil/grease involved is
way worse than just being dirty from sanding dust and dirt. Completely
forgot to take pictures. Sorry about that.
To start, you need new seals, scrapers, etc. I bought the complete seal
"kits" from Chief Aircraft. You get a nice bag o' parts for each leg.
What seemed a shame was, these kits were for a "complete" rebuild. They
also included seals for several different models of Cherokee. Since a
bottom rebuild only used 2 or 3 of the 7 or 8 seals in the kit, you had
lots of extra parts. I just gave them to the wrench for his stock. I
also bought new valves. The seal kit has the new crush rings for the
valves (seemed odd that the valves did not come with new rings). The
wrench advised that these puppies don't seal correctly every time. And
the crush seal is a one time deal. So, if one does not seal and you have
used your one and only crush ring, you may be walking home. His advice
was that, if they ain't leaking, leave them alone. Generally, the cores
contain all the necessary sealing stuff. So, if they leak, a new core
will usually seal em' up. I agreed to leave them alone.
Working at the mechanic's place with the entire plane up on jacks is way
easier than trying to do them one at a time (with the other 2 legs on
the ground).
Once the 3 legs were relieved of air and oil, they are "freed" from the
beast by disconnecting one of the torque links. On the mains, I chose to
disconnect the bottom link that incorporates the brake line bracket.
That way, all you would deal with is the strut tube itself as the links
would be left mounted to the bird. Also, if you disconnect the middle or
top link, you have to undo the bottom link anyway to free the brake line
and caliper. I also disconnected the nose gear lower link.
Getting the snap rings out on the mains are a REAL wrestling match. The
snap rings are not of the type with the eyelets, rather they are the
kind with the ends bent (almost) 90 degrees. Once you have a grip on the
ends and squeeze, it is a real bear to work them out. They are pretty
"robust". There is a spacer ring above the snap ring that is split. If
you find the end and work it a bit the spacer will "spring" closed
slightly and remove easily.
The nose gear snap ring is of the eyelet type, but the original (circa
1974) rubber scraper is right in the way of compressing the ring and
removing it. For the nose, once the snap ring is removed, the gear
fork/tube drops out with an inner assembly that holds all the seals.
Conversely, on the mains, you work upside down getting out the various
scrapers and seals.
Installing the main seals, scrapers, spacers, and snap rings back in are
a lot easier than taking them all out. The nose gear has the main "quad"
seal stuffed in the groove along with a leather "backup" seal. Install
the leather one first with the smooth side facing the quad seal, and
then the quad seal. Any other order won't work. The service manual does
not mention any of this. The nose scraper rubber needs to be cut to
size. CUT IT 3/8 inch TOO LONG. I did and it JUST FIT. Another little
tidbit the service manual fails to mention. By the way, the new design
of the scraper ring makes it so that it does NOT interfere with getting
at the snap ring. Made it a lot easier to get the nose snap ring back in.
Once the struts are all together you push a hose onto the air valve stem
(valve core removed) with the other end in a can of fresh 5606. Raise
the strut slowly with an official, FAA approved, calibrated, 8 foot long
2 X 4. lower slowly to draw in fluid (you may have to slap or lightly
fist the tire to get it to drop). Compress and extend about 6 or 7 times
or until the last 3 or 4 inches on compression shows no air in the hose.
Remove from the fluid/hose and let it drop completely before filling
with air. The object is to fill the strut completely with fluid when it
is completely compressed.
Replace the valve cores. You can use a nitrogen bottle, strut pump, or
little 12v compressor that can do at least 200 psi to refill the beasts
on a Cherokee. The mains take about 190 psi unloaded and the nose takes
about 120 psi or so. Some have strong opinions about using air. Mine
have been riding on air for 12 years. The bores and strut legs showed
absolutely no corrosion. But, we did not take the top end apart. So, the
nitrogen fanatics may have the last laugh some day.
Taking the beast over to the runway at the wrench's place involves going
across his bumpy grass and up onto the pavement. The runway also has
some "personality" at his airpark. So, the newly rebuilt legs got a good
initial workout. What a remarkable difference when the struts actually
move up and down rather than sticking and transferring the bumps into
the airframe! It was also cool to see a distinct ring of oil where the
strut would bottom as the scrapers and seals actually did what they were
supposed to do (namely, scrape and seal).
So, how was the "experience"?
I usually prefer to perform all service work on the beast myself at my
wrench's place under his watchful eye. But, this is one job I would have
probably turned over to the local boys. I used to do a lot of work on my
own cars too. But, with age, I have come to appreciate the local
mechanics to do exhaust, suspension, and coolant related repairs because
I have no desire to do that nasty work. Strut seal replacement appears
to fall into that category. Unless the mechanics wanted to charge more
than about 2 hours labor for each leg, it just did not seem worth it to
do it yourself.
Good Luck,
Old July 21st 05, 08:58 PM
Mike Rapoport
Something I learned a long time ago is to clean the area before beginning
disassembly...nicer that way. Also have a box of cheap latex gloves around.
All the parts including the valve seal are availible from Spruce or any
other parts supplier, I always buy a couple extra of any fittings or
hardware that doesn't cost much.
MU-2
"Mike Spera" wrote in message
link.net...
being filthy. This was worse. Being dirty WITH oil/grease involved is way
worse than just being dirty from sanding dust and dirt. Completely forgot
"kits" from Chief Aircraft. You get a nice bag o' parts for each leg. What
seemed a shame was, these kits were for a "complete" rebuild. They also
included seals for several different models of Cherokee. Since a bottom
rebuild only used 2 or 3 of the 7 or 8 seals in the kit, you had lots of
extra parts. I just gave them to the wrench for his stock. I also bought
new valves. The seal kit has the new crush rings for the valves (seemed
odd that the valves did not come with new rings). The wrench advised that
these puppies don't seal correctly every time. And the crush seal is a one
time deal. So, if one does not seal and you have used your one and only
crush ring, you may be walking home. His advice was that, if they ain't
leaking, leave them alone. Generally, the cores contain all the necessary
sealing stuff. So, if they leak, a new core will usually seal em' up. I
easier than trying to do them one at a time (with the other 2 legs on the
ground).
disconnect the bottom link that incorporates the brake line bracket. That
way, all you would deal with is the strut tube itself as the links would
be left mounted to the bird. Also, if you disconnect the middle or top
link, you have to undo the bottom link anyway to free the brake line and
snap rings are not of the type with the eyelets, rather they are the kind
with the ends bent (almost) 90 degrees. Once you have a grip on the ends
and squeeze, it is a real bear to work them out. They are pretty "robust".
There is a spacer ring above the snap ring that is split. If you find the
end and work it a bit the spacer will "spring" closed slightly and remove
easily.
scrapers and seals.
Installing the main seals, scrapers, spacers, and snap rings back in are a
seal stuffed in the groove along with a leather "backup" seal. Install the
leather one first with the smooth side facing the quad seal, and then the
quad seal. Any other order won't work. The service manual does not mention
any of this. The nose scraper rubber needs to be cut to size. CUT IT 3/8
inch TOO LONG. I did and it JUST FIT. Another little tidbit the service
manual fails to mention. By the way, the new design of the scraper ring
makes it so that it does NOT interfere with getting at the snap ring. Made
(valve core removed) with the other end in a can of fresh 5606. Raise the
strut slowly with an official, FAA approved, calibrated, 8 foot long 2 X
4. lower slowly to draw in fluid (you may have to slap or lightly fist the
tire to get it to drop). Compress and extend about 6 or 7 times or until
the last 3 or 4 inches on compression shows no air in the hose. Remove
from the fluid/hose and let it drop completely before filling with air.
The object is to fill the strut completely with fluid when it is
little 12v compressor that can do at least 200 psi to refill the beasts on
a Cherokee. The mains take about 190 psi unloaded and the nose takes about
120 psi or so. Some have strong opinions about using air. Mine have been
riding on air for 12 years. The bores and strut legs showed absolutely no
corrosion. But, we did not take the top end apart. So, the nitrogen
across his bumpy grass and up onto the pavement. The runway also has some
move up and down rather than sticking and transferring the bumps into the
airframe! It was also cool to see a distinct ring of oil where the strut
own cars too. But, with age, I have come to appreciate the local mechanics
to do exhaust, suspension, and coolant related repairs because I have no
desire to do that nasty work. Strut seal replacement appears to fall into
that category. Unless the mechanics wanted to charge more than about 2
hours labor for each leg, it just did not seem worth it to do it yourself.
Good Luck,
Old July 23rd 05, 10:47 AM
Chuck
On Wed, 20 Jul 2005 01:22:26 GMT, Mike Spera
scrapers and seals.
Hi Mike,
I had to replace the seal on the pilot side main on my Cherokee a
couple months ago. It was leaking down every couple weeks and sagging
a couple inches on that side.
I was working with an A&P, but apparently he hadn't done a Cherokee
before. We disconnected the torque links and removed the schrader
valve. He started to remove the snap ring and had a bitch of a time.
It doesn't have rings on the ends, just a barely 90degree bend on the
ends of the ring. We fought and fought for almost an hour to get it
out. We could get one end out, but the bends on the ends were so long
that once we got one end out, the other was NOT coming out. Just not
enough room between the stationary strut body and moving strut shaft.
Finally, I got ****ed and we pulled hard -- twisting the ring into a
unusable shape, but got it out. OK, we replaced the seal and headed
to the Piper dealer to get a replacement. TWENTY dollars for this
damn little snap ring. I know aircraft parts are expensive -- but
that's ridiculous.
Went back and tried to put it in. NO WAY. When you put the shaft in,
you squeezed the ring ends together. They would come completely
together and still not go inside the shaft body. We tried moving one
side above the other to get the two ends past each other a bit -- but
still couldn't get it up into the groove.
OK, pulled the shaft out and tried it without the shaft in the way.
It took some doing, but we got it into the groove. And guess what --
I took a guess and tried to stuff the shaft in with the snap ring
ALREADY IN PLACE. And what do you know -- it went in!!!
Turns out the ring does NOT hold the shaft into the body. We pulled
the shaft again to double check -- and sure enough, there is no
"larger" area at the top of the shaft that the ring would hold. The
ring apparently just holds the seals in place. The torque links keep
DAMN -- twenty dollars down the tube. If we'd just tried pulling the
shaft with the ring still in, I wouldn't have been forced to buy a
replacement. Next time, save yourself the fight. Disconnect the
torque links and pull the shaft first. THEN get the ring out to
replace the seals.
Chuck (learning the hard way)
PA28-180
Old July 23rd 05, 08:07 PM
Mike Spera
Well... yeah. You mean you tried to get the snap ring out BEFORE
removing the strut tube? No way that will work (as you pointed out). I'm
surprised you got it out at all. Hope you did not wind up scratching the
polished surface of the tube while you were wrestling it.
My point in my posting was that once the strut lower tubes are removed,
it is STILL a bitch to get these things out.
By the way, the NOSE requires the snap ring to be removed with the tube
in place.
One of the best purchases I made 11 years ago was the Piper service
manual for the plane. I have always been a person to "read the
instructions first". However, there have been cases in the manual where
the procedure they described was not quite what was necessary. In a few
cases, the procedure was outright wrong because they were describing an
earlier design. So, once you get the manual, it is important to check
and see if it was properly updated. Many of the outfits selling manuals
don't sell the latest versions.
Good Luck,
replace the seals.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
