IRANIAN AIM-54A PHOENIX MISSILE
Old July 25th 05, 09:31 AM
Amir
Default IRANIAN AIM-54A PHOENIX MISSILE
In the early days of December 1980 a single F-14 took off from Khatami
Air Base in Esfehan. The pilot was patrolling and scanning the sky over
the Persian Gulf about 60 to 70 miles west of Bushehr at an altitude of
about 3 to 4 thousand ft. ,when ground radar advised the F-14 pilot of
multiple boogies closing fast toward him. His aircraft was too far out
to send in any back up help, so ground radar told the pilot you are on
your own and good luck.
The pilot turned around towards them knowing he had a disadvantage in
numbers. By now the F-14 and two boogies were head to head about 20
miles apart. The crew got a Phoenix Missile lock at about 10 miles,
although it was a close range for phoenix. The pilot went ahead with
fox1, he fired an AIM-54 phoenix. Following the smoke path of the
phoenix he saw a ball of fire from the wing of MiG-21 that was
breaking-up. Moments later a splash down from pieces of MiG-21 were
visible in the ocean. In the mean while F-14 pilot observed the second
MiG-21doing a hard G-turn away from the fire ball since the 2 MiGs were
flying too close together. He was going back toward Iraq. The F-14 in
pursuit could not get any radar lock on the second MiG-21 before he
went super sonic.
Submitted by IRANIAN F-14 Pilot
Old July 26th 05, 06:35 PM
W. D. Allen Sr.
Wonder what the readiness of those Iranian F-14s and Phoenix missiles are
today?
end
"Amir" wrote in message
went super sonic.
Old July 26th 05, 11:20 PM
Ed Rasimus
went super sonic.
Maybe some Tom-drivers in this forum will comment, but I've got to
think that in a head-to-head pass with a system lock at ten miles
there is no possible way that the AIM-54 could function.
It's well inside Vmin for a AIM-7E-2 and wouldn't be a viable shot for
an AIM-9J, P, or M.
And, inside ten miles, even a MiG-21 can be easily acquired visually.
Sorry, I've gotta throw a bull-**** flag on this story.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old July 27th 05, 02:31 AM
John Carrier
went super sonic.
Given a 180 turn at 10NM while the Turkey is closing, I think the Mig could
easily have been run down. And there's no problem with locking a target in
the rear hemisphere, supersonic or not.
an AIM-9J, P, or M.
I think your memory is cloudy. 10NM is nicely within the AIM-7 envelope.
It's also in the heart of the AIM-54 ACM Active mode envelope IIRC.
Head-on @ ten miles? Not with these eyes when they were 20/15 and on a good
day. Of course, the T-38 (and to a very slightly lesser degree, the F-5)
were more difficult still.
Sorry, but while the story may be false, the LARS aren't.
R / John
Ed Rasimus
Old July 27th 05, 02:35 AM
John Carrier
ACM active is w/o a lock. The bomb would have guided active, much as a
sparrow, initially.
R / John
"John Carrier" wrote in message
went super sonic.
could easily have been run down. And there's no problem with locking a
target in the rear hemisphere, supersonic or not.
an AIM-9J, P, or M.
good day. Of course, the T-38 (and to a very slightly lesser degree, the
F-5) were more difficult still.
R / John
Ed Rasimus
Old July 27th 05, 04:29 AM
Guy Alcala
John Carrier wrote:
Ed Rasimus
an AIM-9J, P, or M.
Indeed. Lodge/Locher (Oyster 01) and Markle/Eaves (Oyster 02) got an in-range
light at 13nm and made their first launch at 8nm FQ (approx. 135 deg. TCA,
target angels 13, snap-up) on 10 May 1972, and Lodge fired again at 6nm when the
first AIM-7E-2 blew up at motor burn-out. Min-range for AIM-7E or maybe E-2 is
12,000 feet head-on (firer and target speeds and altitudes not stated, but I'm
guessing M0.9), according to one Air Force report. Here's some data from the
SAC for the earlier, less maneuverable, and shorter-ranged (due to a lower total
impulse motor and less-sensitive seeker) AIM-7C, the first SARH Sparrow version,
culled from a post by Pete Stickney a few years back:
The motor is the same Aerojet 1.8KS-7800 used on the Sparrow I and
Sparrow II. The motor performance is roughly that of the AIM-7D.
The autopilot has a G-limiter that holds it to 15Gs.
Launch limits a Altitude 0 to 60,000', and max launch speed is Mach
1.3. The range diagrams are for a launch speed of Mach 0.9, and
target speeds of Mach 0.7 and Mach 0.9. (It's fascinating to see how
much the max range decreases with altitude. Max range vs. a Mach 0.9
target head on at
sea level is 'bout 19000', min range about 9500.
At 30,000', the correspondng numbers are 34,000' and about 9500'.
At 50,000', Max Range vs. a Mach 0.9 target is 'bout 37000', min range
14250'
Tail chase, vs. a Mach 0.9 target (Co-speed)
Sea Level: Max Range 5700', Min Range 2000'
30,000': Max Range 21000', min range 'bout 4200'
50,000': Max Range 25000', min range 8200'.
It's pretty clear that head-on Vmin is well below 10nm for an AIM-7E2
Yeah, considering typical tally distance on MiGs in Vietnam was 1.5-2nm.
Practice with F-5s/T-38s or A-4s helped, but it sure didn't make head or tail-on
pickups at 10nm 'easy'. By all accounts 5nm would be unusual, with the average
perhaps 2-3nm.
Guy
Old July 27th 05, 05:35 AM
John
Just a comment from the sideline . . . Guys . . what a great thread . .
.. this is the stuff i come here for. Thanks to all who posted.
Blue skies
John
Old July 27th 05, 05:04 PM
Ed Rasimus
On Tue, 26 Jul 2005 20:31:46 -0500, "John Carrier"
went super sonic.
The kill-shot is claimed on a head-to-head situation. That would be in
the 1000-1100kt Vc region which means that the interval from Rmax to
Rmin would be pretty short.
I'm an old AF guy, so don't have clue one about the AIM-54 (beyond
knowing multiple engagement capabiility, launch-n-leave, and
exceptional range), but I don't know the sequence of firing, guidance,
arming, ranging, etc operations.
an AIM-9J, P, or M.
10NM is just great for a low aspect shot, but head-on is a distinctly
different situation.
We were doing a low level escorted attack on Red Rio range in the
Holloman complex in which I was leading a four-ship of AT-38 "bombers"
onto the tac range with a pair of F-15A's flying outrigger escort for
me. The defenders were a pair of F-5E Aggressors deployed from Nellis.
I visually acquired the pair of F-5s and called them out for the
offensive force at "5 miles"---GCI confirmed the visual, but corrected
my range to 13 miles.
With a radar contact for cueing on the visual search quadrant, visuals
at 10 miles on MiG-21 sized targets are not out of thequestion.
Ed Rasimus
Old July 27th 05, 08:19 PM
John Carrier
SNIP
good
Optimum contrast, maybe a bit of target aspect? Possible. But having
watched a padlocked T-38 disappear into the background at a mile, not
likely.
R / John
Old July 27th 05, 08:49 PM
Amir
Minimum engagement range is about 3.7 km (2 nm), in which case active
homing is used from the beginning.
Missile defense Mike Military Aviation 0 August 28th 04 02:13 AM
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield Paul J. Adam Military Aviation 1 August 9th 04 08:29 PM
V-4 Missile Possibilities robert arndt Military Aviation 42 January 23rd 04 05:40 AM
Australia to participate in US missile defence program David Bromage Military Aviation 40 December 13th 03 01:52 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
