An interesting dilemma.
The manual for the 172 N tells you that 0-10 degrees is acceptable for takeoff. However it does not tell you what affect it has at low altitude 300 feet MSL Density altitude around 2500 MSL. It only states that it will have a detrimental affect at high altitude on a hot day. It also does not give an airspeed for Vy flaps 10 degrees. In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. The only definitive number the 172N manual states for flaps 10 degrees is Vx. First hand experience seems to confirm what the 172 L manual says. What do you all think? Michelle |
"Michelle P" wrote in message nk.net... An interesting dilemma. The manual for the 172 N tells you that 0-10 degrees is acceptable for takeoff. However it does not tell you what affect it has at low altitude 300 feet MSL Density altitude around 2500 MSL. It only states that it will have a detrimental affect at high altitude on a hot day. It also does not give an airspeed for Vy flaps 10 degrees. In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. The only definitive number the 172N manual states for flaps 10 degrees is Vx. First hand experience seems to confirm what the 172 L manual says. What do you all think? Michelle 1975 C172M manual... "Normal and obstacle clearance take-offs are performed with wing flaps up. The use of 10° flaps will shorten the ground run approximately 10%, but this advantage is lost in the climb to a 50-foot obstacle. Therefore, the use of 10° flaps is reserved for minimum ground runs or for take-off from soft or rough fields. If 10° of flaps are used for minimum ground runs, it is preferable to leave them extended rather than retract them in the climb to the obstacle. In this case, use an obstacle clearance speed of 65 mph. As soon as the obstacle is cleared, the flaps may be retracted as the aircraft accelerates to the normal flaps up climb speed of 80 to 90 mph. During a high altitude take-off in hot weather where the climb would be marginal with 10° flaps, it is recommended that flaps not be used for take-off. Flap settings greater than 10° are not recommended at any time for takeoff." The Take-off checklist has a normal and a maximum performance set of items. Both say Flaps up. The only real difference is the brakes are held until full power is applied and the run is with the tail slightly low for the max performance T-O... The old C-172A book says pretty much the same thing. From my experience the use of flaps should be reserved for those really rough or rain soaked grass fields with low obstacles. |
based on this, I was always told that 10degree flaps on take off where to
get up off that wet grassy runway and accelerate in ground effect, slower climb rate to be expected, so make sure there are no trees at the other end. BT " Blueskies" wrote in message . .. "Michelle P" wrote in message nk.net... An interesting dilemma. The manual for the 172 N tells you that 0-10 degrees is acceptable for takeoff. However it does not tell you what affect it has at low altitude 300 feet MSL Density altitude around 2500 MSL. It only states that it will have a detrimental affect at high altitude on a hot day. It also does not give an airspeed for Vy flaps 10 degrees. In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. The only definitive number the 172N manual states for flaps 10 degrees is Vx. First hand experience seems to confirm what the 172 L manual says. What do you all think? Michelle 1975 C172M manual... "Normal and obstacle clearance take-offs are performed with wing flaps up. The use of 10° flaps will shorten the ground run approximately 10%, but this advantage is lost in the climb to a 50-foot obstacle. Therefore, the use of 10° flaps is reserved for minimum ground runs or for take-off from soft or rough fields. If 10° of flaps are used for minimum ground runs, it is preferable to leave them extended rather than retract them in the climb to the obstacle. In this case, use an obstacle clearance speed of 65 mph. As soon as the obstacle is cleared, the flaps may be retracted as the aircraft accelerates to the normal flaps up climb speed of 80 to 90 mph. During a high altitude take-off in hot weather where the climb would be marginal with 10° flaps, it is recommended that flaps not be used for take-off. Flap settings greater than 10° are not recommended at any time for takeoff." The Take-off checklist has a normal and a maximum performance set of items. Both say Flaps up. The only real difference is the brakes are held until full power is applied and the run is with the tail slightly low for the max performance T-O... The old C-172A book says pretty much the same thing. From my experience the use of flaps should be reserved for those really rough or rain soaked grass fields with low obstacles. |
Michelle P wrote:
In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. I have a 172S manual It's my understanding that, in terms of flaps and related performance, all models after L are exactly the same. My manual says that "using 10 degrees of wing flaps reduces the ground toll and total distance over an obstacle by approximately 10 percent." For a short field takeoff, that would be an overall beneficial affect, not detrimental. It's my experience that, at low airpseeds, 10 degrees of flaps increases my climb performance substantially. |
On 11 Aug 2005 00:11:51 -0700, "Brien K. Meehan"
wrote: Michelle P wrote: In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. I have a 172S manual It's my understanding that, in terms of flaps and related performance, all models after L are exactly the same. The newest (G1000) 172S manuals and checklist (and factory transition training) say 0-10deg is approved, but 10deg is preferred to flaps up in all conditions due to the decreased ground roll and increased climb performance, and specifically called for when doing soft/rough field. |
Michelle,
I have always read the manual to mean that 10 degrees is useful for all situations where the ground roll should be minimal, e.g. soft fields. Since we almost only use soft fields here in Germany, I have always used 10 deg when I flew 172s. It got me some funny looks, though. -- Thomas Borchert (EDDH) |
Are you sure that was due to the flaps? ;-)
Michelle P wrote:
An interesting dilemma. The manual for the 172 N tells you that 0-10 degrees is acceptable for takeoff. However it does not tell you what affect it has at low altitude 300 feet MSL Density altitude around 2500 MSL. It only states that it will have a detrimental affect at high altitude on a hot day. It also does not give an airspeed for Vy flaps 10 degrees. In talking to another pilot who has an 172 L has states that his manual says if 10 degrees flaps are used it will decrease ground roll and decrease climb rate. Having an overall detrimental affect. The only definitive number the 172N manual states for flaps 10 degrees is Vx. First hand experience seems to confirm what the 172 L manual says. What do you all think? Michelle I used to rent a 172L a lot many years ago, and used 10 degrees to reduce the takeoff roll but for me it *increased* the rate of climb slightly at airspeeds between Vx and Vy. Any more than 10 degrees and it certainly hindered climb rate, but on really soft or muddy turf strips, I'd use a little more than 10 degrees by carefully bumping the flap switch down in short spurts during the takeoff roll until it felt better and got the mains off the ground, then once a positive rate of climb was established I'd carefully retract the flaps a small amount at a time until the airplane was happier. A lot of the other renters hated the spring-loaded up/down flap switch in the 172L because you had to keep it pushed up or down to run the flap motor, but I liked being able to 'fine-tune' the flaps to what felt best in a given takeoff situation. |
wrote in message ... http://www.coloradopilots.org/ Yes, we fly a normally aspirated C172 ("N" model) into Leadville, Colorado at 9,927 MSL. Pattern altitude is 11,000 MSL. FUN! Best regards, Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard How long is the runway and what does the approach/departure zones look like? |
| Thread Tools | |
| Display Modes | |
| Headwinds, always | Paul kgyy | Piloting | 36 | June 9th 05 02:05 AM |
| 757 flaps miss-aligned in cruise | AnyBody43 | General Aviation | 1 | April 2nd 04 02:01 AM |
| Cessna 182S flaps | EDR | Piloting | 7 | January 16th 04 03:37 AM |
| C182 Stabilized Approach | III | Piloting | 16 | December 16th 03 08:36 PM |
| Flaps and V-Tails of Death | Wallace Berry | Soaring | 59 | November 26th 03 10:54 PM |
