Old Plans, New Part Numbers
Old December 14th 04, 03:25 PM
Default Old Plans, New Part Numbers
I am working with 40 year old plans that call out AN365-6 Nuts.
Since they are used in conjunction with AN6 Bolts (24 of them) to
attach the main spars together, I am assuming they are locknuts.
Is the AN363-624 Metal Lock Nut a good match or good substitution?
Gotta have something to hold 49 feet of wings together.
Prue Super
Circa 1963 Standard Class Sailplane.
15 meter all metal 35:1 L/D
Clark
Old December 14th 04, 04:50 PM
plasticguy
MS20365's are the same part. Why change.
They are freely available at most suppliers.
ALSO, Irv designed neat airplanes but unless you
show somebody HOW the bolt is used, asking
about substitutions on the net isn't where I'd
get the answers.
http://www.aircraft-spruce.com/catal...ages/an363.php
Scott.
Prue Super
Clark
Old December 16th 04, 03:41 AM
Cy Galley
My Genuine Aircraft Hardware says that MS21044N is the replacement for both
obsolete # AN365 and MS20365. These are just Nylon insert, full profile hex
nuts.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
"plasticguy" wrote in message
get the answers.
Scott.
Prue Super
Clark
Old December 16th 04, 11:25 AM
smjmitchell
Yes ... AN363 are a suitable and cheaper alternative. The main difference is
that they can be used in higher temperature applications because they don't
have the nyloc insert (which I don't think it that important in a glider).
Same strength though. Most engineers use metal-loc bolts in preference to
Nyloc's these days. You could also use a MS21042 and a whole lot of other
part numbers. See the interchangability chart on the MS21042 data sheet (get
from STINET on the web). Of course you could also use the MS20365 as the
direct replacement for the old AN365. Provided that the bolt is loaded in
shear (and it sounds like they are the wing attach fitting bolts so I assume
they will be) you have little to worry about with respect to the
substitution.
I have question for you on the Prue sailplane which is way off topic and I
will take that up with you direct - hope you don't mind.
Prue Super
Clark
Unused plans question Doc Font Home Built 0 December 8th 04 10:16 PM
Modifying Vision plans for retractable gear... Chris Home Built 1 February 27th 04 10:23 PM
What do you do with you plans? Bill A. Home Built 2 January 23rd 04 12:48 AM
Homebuilt plans F.S. Aaavision51 Home Built 1 November 10th 03 04:50 AM
Here's a silly question regarding plans David Hill Home Built 21 October 8th 03 05:17 AM
