Passing out at high altitudes / the Greek ailrliner crash
Old August 15th 05, 06:54 PM
Default Passing out at high altitudes / the Greek ailrliner crash
I am not a pilot, and as much as my email address sounds like I am a
doctor, I'm not...
That said, I thought someone here might be able to help me out - they
news reports talk about passing out within seconds at high altitudes.
I understand the air is thinner / less O2.
But if I go underwater, there's certainly no air there. And I can stay
down for a while, holding my breath. How is high altitudes different?
I would think you would rasp / fight to breath in but keep functioning
as your body uses up the 02 in the blood from your last breath? Not
like a sleeping gas in the movies where you just keel over as soon as
it hits you?
THANKS!
Old August 15th 05, 07:12 PM
Mike Rapoport
My understanding is that the O2 in the cells and in the blood will actually
go back into the lungs at very low ambient pressures. It doesn't matter
whether you breath or hold your breath, the O2 will leave your body. It is
something like the bends where gases that will disolve in the body under
higher pressures will come out of solution at lower pressures.
MU-2
doctor, I'm not...
it hits you?
THANKS!
Old August 15th 05, 07:29 PM
Mike Rapoport
It isn't totally clear from your post but I think you have it wrong. The
concentration of O2 is the same at all altitudes. At 18000' for instance
the air pressure is half, the concentration of O2 is the same as at sea
level so the total amount of O2 is half.
MU-2
"Mark Hansen" wrote in message
doctor, I'm not...
it hits you? THANKS!
There is a big difference between Air and Oxygen. With no Air,
you are unable to move your lungs (there is nothing to pull in).
With low oxygen, you can still move air, it just don't provide the
oxygen necessary to support your life.
This is called Hypoxia, and one of the side effects of this is
euphoria. What that means, is it causes you to feel like everything
is really great, when in fact, you're asphyxiating yourself.
Here is a link to an explanation of Hypoxia:
http://www.batnet.com/mfwright/hypoxia.html
This is the simple answer. Let me know if you would like more details.
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old August 15th 05, 07:34 PM
Ron Garret
In article .com,
doctor, I'm not...
It depends on how you get there :-)
If the decompression is sudden then you can't "hold your last breath."
If you try then the air pressure in your lungs will cause them to
rupture. It's called an "air embolism". Scuba divers can get them too
if they surface while holding their breath.
If the decompression is slow then you can keep breathing but your blood
oxygen level will gradually go down and you will gradually lose mental
function. The effect can be subtle enough that you don't realize that
it's happening even as you drift into unconsciousness. Pilots sometimes
get special training to help them recognize and deal with the symptoms
of decreased blood oxygen at high altitude.
In a sudden decompression it is of course obvious that something has
happened, but your "time of useful consciousness" as it's called can be
very short (seconds). If you don't manage to put on an oxygen mask in
that time, or if the oxygen system isn't working, you drift off to sleep.
There is one case of a pilot who actually managed to survive such an
occurrence. The plane was on autopilot when the (human) pilot passed
out and when it ran out of gas the autopilot kept the wings level and
the plane did a gear-up landing in a field.
rg
Old August 15th 05, 07:38 PM
Mark Hansen
Yes, you're right (on both counts) - I had forgotten about this.
MU-2
doctor, I'm not...
Sacramento, CA
Sacramento, CA
Old August 15th 05, 11:57 PM
David Kazdan
Not quite. Mole fraction of oxygen in the air is the same at all
altitudes, about 21%. Concentration, in the senses of partial pressure
and number of molecules in a given volume (such as one breath), goes
down with increasing altitude. The partial pressure translates to the
fraction of available molecules that are biologically usable; the
density of molecules translates to how many there are in the breath.
You lose twice with increasing altitude.
David
MU-2
Old August 15th 05, 11:58 PM
Bob Gardner
Based on my experience in a USAF altitude chamber, after the chamber has
been pumped up (actually down...it is a vacuum) to 25000 feet and the
pressure suddenly dumped as would be the case in a decompression, whatever
air you have in your lungs comes out forcefully...no way do you have any
control over it. Gotta get that mask on and get it on in a hurry, because
time is fleetingly short.
In US regulations, the magic altitude is flight level 350 (more or less
35000 feet, depending on ambient atmospheric pressure). The Cypriot plane
was reportedly at FL 340, if we can believe the media. Under US rules, above
FL 350 both pilots must be at the controls and each must have a
quick-donning mask at hand. If one pilot has to leave the cockpit for any
reason, the other has to put on and use oxygen until he returns.
Lots of unknowns.
Bob Gardner
Bob Gardner
doctor, I'm not...
it hits you?
THANKS!
Old August 16th 05, 11:05 AM
It's FL 250 (121.333 I believe). Above 250 one crewmember must be on O2 when
the other leaves the flight deck.
As to decompression of an aircraft the size of the 737, there is rapid
decompression and explosive decompression. It the packs both trip off or a
window blows out it results in rapid decompression, which is quite different
than an altitude chamber experience. The cabin ascends at perhaps 10,000 feet
per minute. But, if there is some type of structural failure resulting in a
whole larger than a window, then the cabin can explosively decompress, similar
to your experience in the altitude chamber.
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 08:35 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 04:31 AM
