Wing engineering?
Old August 29th 05, 12:45 AM
Lou
Default Wing engineering?
Ok, a question or 2 about the wings. I'm building a wooden aircraft
that could go either fixed tri-gear or retract. I choose fixed seeing
how this is my first plane to build and I wanted to keep it simple. The
fuel was supposed to go behind the firewall but I choose to build tanks
in each wing where the wheels where to go.
What will this do to the loading of the aircraft? Does this effect
the useful load and how? Does it raise my useful load or lower it or
niether? Since the wings create lift, and the fuel was in the fuselage
and now in the wing should it screw up the center of gravity? Anybody,
Anybody, Anybody????
Old August 29th 05, 01:42 AM
john smith
Depends upon the wing and where in the wing the tanks are located. Fuel
burn will affect center of gravity. Tank shape and location will
determine the affect.
Old August 29th 05, 01:49 AM
Bob Martin
Well, I'm not really an expert... but by moving the tank(s) from behind
the firewall to the wings, you create two main issues:
First, center-of-gravity changes. Moving them further aft will cause an
aft shift in CG. You will have to move other components forward to
compensate (or add ballast), and be VERY, VERY sure you analyze all of
the load conditions possible to make sure the CG is not out-of-limits.
Second, moving the tanks to the wings (assuming a low-wing aircraft)
means you will need an engine-driven fuel pump and an electric boost
pump. You can't simply use a gravity feed like you could with high-wing
tanks or (I'm assuming) a fuselage-mounted tank.
As far as changes in lift, assuming you don't change the outer mold line
of the wing, you won't generate more or less lift by putting the tanks
in the wing. However, putting them out there means the load
distribution will change; you have to make sure your wing structure can
support the tank. However, moving the tanks to the wings should reduce
the bending moment a bit.
Old August 29th 05, 03:16 AM
Ernest Christley
You have to worry about 3 axis. With now knowledge of the airplane, it
is possible that the fuels position may not have not changed fore or
aft. If that it true then your CG is safe. If not, then you will have
to be very careful in your weight and balance calculations. The nice
thing about wing tanks is that the fuel tends to sit on the center of
lift. When this is the case, the draining fuel doesn't cause your trim
to creep.
Next is the vertical axis. If you move a lot of weight from up high to
down load, but leave the center of thrust untouched, then you've created
a situation where adding thrust will cause the plane to tend to nose
over. You're trying to move a filing cabinet by pushing the top. So,
you're on short final, just before the flair, all trimmed out and
smooth. A deer jumps on the runway. You firewall the throttle. Do you
have enough elevator to keep from eating a mouthful of dirt.
The other issue is lateral loading. Move all that weight to the wings
and you've modified your roll response. Just like an ice skater that
changes her spin by extending her arms or retracting her arms (moving
weight in and out.) When you try to start a roll, you have to have
enough differential lift in the ailerons to get everything moving...and
THEN get everything stopped. Moving the tanks could make the plane
difficult to control.
The upshot is that the wing ROOT doesn't have to carry the bending
moment of the fuel load. If the wing root was the limiting factor in
your load allowance, then this move very well could increase your
plane's usefull load. Airplanes have to be light, though. It's
doubtful that the designer cut the wing root to the bare minimum and
then beefed up everthing else, like landing gear, tail surface area,
elevator surface area, etc. I wouldn't bet MY life on an increased load
allowance from moving the fuel tank.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old August 29th 05, 10:57 AM
Lou
Very nice analogie's, they put good pictures in my head. If I kept the
fuel tank in the fuselage behind the firewall, wouldn't that have
created trim problems as the fuel got used up?
Old August 29th 05, 12:36 PM
Jean-Paul Roy
Lou, have you asked tjis question to the designer of your craft?
His comments could be very interesting and informative.
Jean-Paul
"Lou" wrote in message
Old August 29th 05, 02:57 PM
Lou
As a matter of fact I finally found a way to communicate with him. He
is an Italian resident who doesn't speak english and I could so much as
insult someone in Italian. I did get a fax number for him (I will find
out about email soon) and am starting to translate a bunch of questions
to fax him. This will be interesting.
Old September 1st 05, 03:31 AM
Ernest Christley
If you move any loads, including the fuel, you've changed the trim
point. You're always chasing the trim to some small extent anyway
(unless you have an autopilot which is doing the chasing for you). I
don't know if it can be described as a problem. You, as the pilot, will
have to decide that.
Old September 1st 05, 06:47 PM
Lou
Ok I've started it, I have built the 2 wing ribs the way it called for
in the plans if I were installing the retract gear. The only differnce
is that I will not be cutting the bottom of the ribs out for the gear
that won't be there. They seem to be extreemly strong, sorry I didn't
think of this for luggage.
Lou
Old September 1st 05, 09:14 PM
Orval Fairbairn
In article . com,
Lou
What kind of plane is it?
Long wing twisting JJ Sinclair Soaring 13 June 28th 05 06:42 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
