Terminal Certified GPS
Old September 2nd 05, 05:53 AM
Scott Draper
Default Terminal Certified GPS
A friend has some Apollo unit that is capable of enroute and terminal
navigation. How do I know if the installation is actually approved
for IFR flight ?
Thanks
Old September 2nd 05, 06:34 AM
Doug
for IFR flight ?
AFM Supplement ?
Old September 2nd 05, 02:22 PM
Roy Smith
for IFR flight ?
AFM Supplement ?
Also, if it's not, it will have a placard saying "VFR use only" or
something to that effect.
Old September 2nd 05, 02:44 PM
for IFR flight ?
AFM Supplement ?
I would qualify that by saying it is *supposed* to have such a placard.~
Old September 3rd 05, 06:25 AM
Scott Draper
AFM Supplement ?
Not to be found.
Old September 3rd 05, 06:26 AM
Scott Draper
True, with Tim's caveat noted. ;-)
Old September 3rd 05, 05:41 PM
Jim H
If your unit is IFR approved, then it will be listed on the type certificate
(if it came that way from the factory), or if the unit was installed in the
field there will be a 337 with a FSDO's signature approving the unit for IFR
use. You can get a CD from the FAA that lists all the 337s for that
airplane on it.
Jim Howard
"Scott Draper" wrote in message
AFM Supplement ?
Not to be found.
Old September 3rd 05, 06:32 PM
Paul Lynch
Not legal to fly then. If there is a 337, you can get a new AFM supplement
issued.
AFM Supplement ?
Not to be found.
Old September 3rd 05, 08:32 PM
Newps
issued.
There is a 337, has to be to get installed, assuming of course it was
installed legally.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
