L-Nav audio vario problem
Old September 7th 05, 05:39 AM
Roy Clark, B6
Default L-Nav audio vario problem
Used my L-Nav without problems in July.
Family and work-related events kept me away until this past week-end.
No audio vario sound from my L-Nav. Makes a short, soft "choo" when
turned on, then nada.
Any ideas or advice?
Old September 7th 05, 06:03 AM
Paul Remde
Hi Roy,
Verify that it is getting 12V power. Check the battery voltage level.
If those ideas don't help call Cambridge. They can repair it if necessary.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Roy Clark, B6" wrote in message
Old September 7th 05, 04:26 PM
Discus 44
Roy:
As your L-Nav is most likely the same age as mine, I had similar
problems and found out the internal battery was at fault. Almost
anyone who has an L-Nav from the mid 80's will need to replace the
battery if they have not already. I would try this first. It is easy
to replace BTW. If you have the GPS-Nav, it might need replacing also,
but you must follow the GPS-Nav instructions to keep the security seal
OK. This requires the power to be on to the GPS-Nav while removing the
cover and replacing the battery. See you in a couple of weeks.
Paul Remde wrote:
Hi Roy,
Good Soaring,
Paul Remde
Old September 8th 05, 02:42 AM
scooter
Roy;
I had this problem last year. I hooked up a speaker to the 'external
speaker' wires on the L-Nav and got through the season. Mine turned
out to be the speaker itself. It arrived at Cambridge on a Monday and
it was back on my step on Friday with a new speaker and updated
firmware! Not bad service.
Scott
Old September 8th 05, 05:48 AM
Roy Clark, B6
Was getting 12v before and after the flight.
Will have more time to investigate later this month. If no progress,
then off to Cambridge.
Thanks for you reply and your super informative website!
Old September 8th 05, 05:58 AM
Roy Clark, B6
Tom,
Mine is about 1997-1998 vintage, but will talk with ar Ephrata in
acouple of weeks.
Scott,
I will look into this possibility.
Another Cirrus BRS deployment: Dan Luke Piloting 111 April 19th 04 05:34 AM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 09:11 PM
where exactly to put the noise filter Dico Reyers Owning 25 February 25th 04 04:21 AM
Looking for helicopter audio – MI-4 engine Jukka O. Kauppinen Military Aviation 1 February 12th 04 06:30 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 10:10 PM
