Towing w LSA (Light Sport Aircraft)
Old September 12th 05, 11:39 PM
Jeffrey Banks
Default Towing w LSA (Light Sport Aircraft)
Towing w LSA (FAA defined Light Sport Aircraft)?
Is anyone doing this?
Without a horsepower limit for Light Sport Aircraft it seems that a
small airframe and a big engine might be an ideal towplane.
The GW limit of 1320 lbs (599kg) and max cruise speed of 120knots do
not seem restrictive for such a tug.
Jeff Banks
Old September 13th 05, 05:08 AM
Mike Schumann
Is it legal to tow if you just have a light sport license? If not, what's
the point?
Mike Schumann
"Jeffrey Banks" wrote in message
Jeff Banks
Old September 13th 05, 05:32 AM
Bill Daniels
The point is that an airplane can be designed that is optimized for aero
tow. This theoretical aircraft could deliver far better tow performance on
half the HP of a Pawnee. It could be almost silent while using smaller
quantities of cheaper fuel. I agree that it's possible within the limits of
the Sport Light Aircraft regulations. We'll have to see if someone pick up
the challenge.
It's not the pilot, it's the airplane.
Bill Daniels
"Mike Schumann" wrote in message
link.net...
the point?
Mike Schumann
Jeff Banks
Old September 13th 05, 06:14 AM
Tim Ward
link.net...
the point?
Mike Schumann
Private pilots can fly LSAs. Those people who are towing hang gliders are
lobbying for towing with the experimental LSAs (the Dragonflys and so
forth).
If you could build an LSA similar to a Katana with 150 HP or so, I bet
that could make a dandy towplane. LSAs don't have to go through a complete
certification, so it's possible someone could design a towplane that would
have lower fuel burn and faster cycle time than existing towplanes.
It might even be able to double as a motorglider trainer when it wasn't
towing.
Tim Ward
Old September 13th 05, 06:33 AM
Jack
What do you consider a big engine?
A new, lightened Piper Pawnee (currently mt wt of 1288 lbs) would be
better than yet another high-wing lashup with horrible visibility from
the cockpit.
Jack
Old September 13th 05, 09:29 AM
Stefan
In Europe, this is becoming more and more common. Towing works
astonishingly well with 100 hp and one of those new planes. The limit is
when the glider is very heavy (fully loaded two seater) or the runway is
very short and soft. Towing with 3 gal/hour and with remarkably little
noise is much cheaper and neighbour-friendlier, even if a tow it last
10% longer.
There are currently two categories of "new tow planes": Motorgliders
(such as the Super Dimona, in the USA called Katana XTreme) and modern
ultalights, as they are called here (see for example http://www.remos.com/).
All in all, in Europe we strongly believe that this is the future of towing.
Stefan
Old September 13th 05, 02:12 PM
Martin Gregorie
noise is much cheaper and neighbour-friendlier, even if a tow it last 10%
longer.
When I visited the Wasserkuppe in 2003 they were using a Robin GR400 for
their two-seat fleet (ASK-21) and a Pelikan UL for the single seaters.
That's a reasonable tow-plane test: OK, they operate off tarmac, but
launch is usually down-wind and down-hill so the tow plane needs to be
fairly capable.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 13th 05, 02:59 PM
Bill Daniels
"Stefan" wrote in message
10% longer.
towing.
Stefan
I don't believe an optimum design tow plane would look anything like a
touring motorglider. The key to performance and economy is the propeller.
It should be really big and slow turning. Remember, propeller blades are
just rotating wings. They work best at the L/D max just like a sailplane.
Think of a three to four meter diameter prop turning at 1000 RPM. The
touring motorglider airframes won't accommodate a prop that big.
I'm thinking of something that would look like an oversize ultralight with
the pilot way forward for the best view and a pusher prop over a low wing.
The wing would baffle what little sound the prop made so it should be very
quiet. A very slow prop could be easily driven with a tooth belt. 130 HP
should be more than enough for the heaviest 20 meter two-seater. A water
cooled Honda or Subaru engine might work great.
Bill Daniels
Old September 13th 05, 03:28 PM
John Galloway
The Pik 27 looks as if it is getting close to completion.
It is a small single seat low wing Rotax 914 engined
machine with rear fuselage air brakes that has been
designed specifically as a glider tug and is expected
to outperform a Pawnee for towing and be much more
economical. See:
http://www.windcraft.fi/pik27/welcome
John Galloway
At 13:00 13 September 2005, Bill Daniels wrote:
'Stefan' wrote in message
Towing works
or the runway is
remarkably little
if a tow it last
10% longer.
There are currently two categories of 'new tow planes':
Motorgliders
XTreme) and modern
is the future of
towing.
Stefan
anything like a
is the propeller.
at 1000 RPM. The
that big.
ultralight with
two-seater. A water
Bill Daniels
Old September 13th 05, 03:57 PM
Fred
I've long thought an experimental category A/C dedicated only to towing
would be a good alternative to the Pawnee. The correct design would
get better fuel efficiency, be quieter, have longer TBO and probably be
liquid cooled so thermal shock is not such a problem on let down. Two
questions, though: who wants to design a specialized airplane with such
limited market potential, and what would the insurance companies say
about towing with an A/C in the experimental category? Otherwise,
bring it on! Fred
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
changing operating limitations pittss1c Home Built 46 August 22nd 05 05:28 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
