Stuck piano hinge pin
Old September 15th 05, 04:52 PM
Dick
Default Stuck piano hinge pin
My old project plane has working flap but it appears pin for hinge is
corroded and stuck.
Flap needs to be removed for access to rear main gear bracket.
I can't get a grip on holding the pin and pulling or twisting. Being cheap ,
would rather not cut the pin into small removable pieces as a long
replacement pin or piano hinge ships at a higher rate.
Suggestion would be appreciated, thanks. Dick
Old September 15th 05, 05:24 PM
John Ammeter
Can you cut ONE loop off an end and get a grasp on the pin that way?
Or, can you, using a small punch drive the pin out the other way?
John
corroded and stuck.
Old September 15th 05, 06:04 PM
Don Lewis n FTW
"Dick" wrote in message ...
My old project plane has working flap but it appears pin for hinge is corroded and stuck.
Try " Kano Kroil"... put a drop on each joint and let it set a coupla days...
Should then easily drift out...
See: http://www.kanolabs.com/ ... located in BNA...
Don L. n FTW
Old September 15th 05, 08:16 PM
Dan, U.S. Air Force, retired
Don L. n FTW
In the Air Force we had some rather long hinges. To get the pins in
or out we'd chuck the end into a drill and spin it as it was removed or
installed. A properly aligned hinge takes only a few seconds to pin.
Old September 15th 05, 09:26 PM
W P Dixon
Try some Mouse Milk to help loosen it up.
Patrick
student SPL
aircraft structural mech
"Dan, U.S. Air Force, retired" wrote in message
news:qUiWe.20500$dm.10661@lakeread03...
corroded and stuck.
days...
Don L. n FTW
In the Air Force we had some rather long hinges. To get the pins in or
Hinge pins for Pegasus AD tooromeo Soaring 0 May 17th 05 03:56 PM
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 04:36 AM
Aluminum hinge VideoFlyer Home Built 2 May 11th 04 09:39 PM
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 03:58 PM
Stuck valve versus plugged injector Viperdoc Owning 6 April 13th 04 01:15 AM
