PAI 700 VC Compass Failing
Old September 18th 05, 02:28 PM
Mike Spera
Default PAI 700 VC Compass Failing
My PAI 700 has performed quite well for the past 4 years or so until
now. I bought the "official" mounting bracket after seeing others that
were mounted without the bracket failing badly. Lately, even after
recalibration, I have noticed it seemed to be off 5 degrees or so
between 350 and 10 degrees. As slight tap on the side and it would get
back to where it should be. The other day with the nose pitched up into
a climb while turning, I noticed the thing sticking at North and
suddenly roll 100 degrees (to where it should have been) somewhere in
the turn. I just chalked it up to the very nose-high attitude the
student pilot friend had the plane into and the normal compass lead/lag
behavior.
The last straw was on the ground. While pointed at 150 degrees after the
runup, I reached over to set the DG to the compass and it was stuck at
North. A little tap to the side did nothing. A little bigger tap also
did nothing. Not until we rolled onto the runway and turned 30 degrees
did it finally catch up. These things do have a wee bit of sticking that
is usually not noticed if the engine is running and supplying its usual
copious vibrations. But this time it was sticking after a runup. This is
quite a bit of vibration.
So, a new one was ordered last night. I really cannot tolerate a balky
compass. But I had always praised this model over others because the
folks who I talked to all said this model would last the longest. Others
have had poor luck with the cheaper models.
Anyone else have or had a prematurely failed PAI 700? I figured one of
these units should last 7-10 years before the gearing wore out and began
sticking. Is my expectation unrealistic or was this one just a fluke?
Old September 18th 05, 08:13 PM
Mike Granby
There's an article somewhere out there about them failing due to some
bit or another coming off a mount as a result of ferous metal being too
close...
http://www.avionicswest.com/articles.htm
Old September 19th 05, 06:00 PM
Denny
I have yet to see this mechanical style compass survive... Someone
always lays something up on the glare shield that is steel, while
either working on the aircraft, or simply loading/unloading and that is
all it takes... The compass continues working after a fashion, but is
unreliable... If you don't want to go back to a traditional compass,
perhaps a SIRS Navigator might suffice...
denny
Old September 19th 05, 07:50 PM
Paul kgyy
Because of the gearing, these units are more likely to wear than a
simpler compass. I'd guess that the amount of wear is more related to
the number of hours of use, and the level of vibration experienced,
than the number of years you have owned it.
I just installed one and like it a lot but I'm sure that "stickiness"
will ultimately cause a replacement.
Old September 19th 05, 08:39 PM
NW_PILOT
Had my cessna wet compas seal go out then the light fixture broke upon
removal was a simple $100.00 bill to get it rebuilt aka re sealed, should
work for another 30 years.
"Mike Spera" wrote in message
et...
behavior.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Experience with SIRS compass? Ross Oliver Owning 2 March 18th 05 07:21 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 01:08 PM
Strange compass behavior me Owning 10 February 14th 04 05:24 AM
Compass turning error Marty Ross Piloting 3 August 21st 03 03:53 PM
