PDA touch screen problems
Old September 20th 05, 04:48 PM
Dan
Default PDA touch screen problems
I've had two iPAQ 37xx series go on the blink.
The touch screen goes haywire.
When I try to re align the screen it just goes into a do-loop and never
properly re-sets.
Sometimes it gets better if I keep it turned off for a few weeks, but
that doesn't seem to work now.
Any suggestions?
Old September 20th 05, 05:24 PM
John Scott
I've had iPaqs act funny, acting like the screen had been touched when it
hadn't, starting up programs at random, etc.
First I put in fresh batteries. On the older models this entails opening
the case. The battery is stuck to the inside of the case back and connects
with a short flat cable to the board. One I had to finally resort to a
percussive maintenance procedure that seemed to cure the problem, i.e., a
sharp smack on the back of the base.
If you're using them with a jacket, you may need to also change the battery
in the jacket.
John Scott
"Dan" wrote in message
properly re-sets.
Any suggestions?
Old September 20th 05, 06:43 PM
Eric Greenwell
properly re-sets.
I assume you've tried a soft reset. Perhaps a hard reset (don't ask me
how) would be worth a try?
I've had good luck with the Ipaq forums on HP's web site. Give them a
try - tons more geeks there than in all of RAS land.
Eric Greenwell
Washington State
USA
Old September 20th 05, 06:56 PM
Dan
I changed the battery in one last February
and I've tried soft re-set. no joy!
Old September 20th 05, 07:44 PM
Martin Eiler
I had a similar problem with my 3765. After trying to align
the touch screen dozens of times with the back light on,
I stumbled across the fact that if I aligned the screen with
the back light off and use it with the back light off it works
fine. But anytime I turn the back light on the touch screen
alignment seems to shift and becomes rather useless but
otherwise the programs seem to run fine. Since glider flying
is typically done during daylight hours having the backlight
off is no big deal.
M Eiler
Old September 20th 05, 08:35 PM
Dan
Hmmmm...I'm pretty sure I always had the back light on.
I'll try it and report back.
Dan
Old September 20th 05, 08:36 PM
Dan
BTW- Awesome flight for the DDD.
I didn't enter, gave up on the conditions.
You're the Man!
Old September 20th 05, 11:30 PM
KO
I got that very same problem with a 3635. It happened that I used one
of those screen protectors and after a while it got all scratched and
glue got undone, so I decided to remove it.
Removing it left particles traped around the screen frame causing the
touchpad to go crazy... $50 and a quick trip to Compaq fixed it 2 years
ago...
Regards
Enrique
properly re-sets.
Any suggestions?
Old September 21st 05, 01:07 AM
Dan
I put screen protectors on both PDA's to reduce the glare, that may be
a cause for the problems
Anyone know if HP will fix old iPAQ's?
Old September 21st 05, 08:46 AM
David Salmon
In the UK www.ipaqrepair.co.uk can do almost any repair
or replacement.
Dave Salmon
glare, that may be
Touch and Goes versus Full Stop Taxi Backs Kevin Dunlevy Piloting 81 September 18th 05 10:26 PM
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 02:30 PM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 06:09 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
