Big Bertha Thing blogs
Old September 22nd 05, 02:05 PM
Tony Lance
Default Big Bertha Thing blogs
Big Bertha Thing uniform
Cosmic Ray Series
Possible Real World System Constructs.
http://web.onetel.com/~tonylance/uniform.html
Access page to 714K ZIP file
Astrophysics net ring Access site
Newsgroup Reviews including alt.support.attn-deficit
Animated wire-frame Polyhedron display,
complete with duals and double precision
angles to the polygons. Also technical
program description and 75 pictures.
Just one thing, thats still outstanding.
This is a collection of PostScript files from
the Computing Science Technical Report series
of organization 1127 of AT&T Bell Laboratories
report Comp. Sci. Tech. Rep. No. 130
author Andrew Hume
title Exact Descriptions of Regular
and Semi-Regular Polyhedra and Their Duals
date November 1986
tm TM 11276-861022-09
type techreport
Just two programs ready to run.
1. kaleido.exe (MSDOS) 86KB (see Zip)
2. schwarz.exe (MSDOS) 27KB (see Zip)
Just one description of two programs,
that do just one thing, better than the next best thing.
uniform.pdf (Adobe) 676KB (see Zip)
Big Bertha Thing windows
On the Windows of King's College Remaining Boarded.
Loquitur Discipulus Esuriens.
Professors, in your plan there seems
A something not quite right,
'Tis queer to cherish learning's beams,
By shutting out the light.
While thus we see your windows block'd,
If nobody complains;
Yet everybody must be shock'd,
To see you don't take pains.
And tell me why should bodily
Succumb to mental meat?
Or why should eta, beta, pi,
Be all the pie we eat?
No helluo liborum I,
No literary glutton,
Would veal with Virgil like to try,
With metaphysics, mutton.
Leave us no longer in the lurch,
With Romans, Greeks, and Hindoos;
But give us beef as well as birch,
And board us - not your windows.
From the book
The Ingoldsby Legends
by the Rev. Richard H. Barham
Published by Richard Edward King,
88 Curtain Road,
London E.C.
Inscribed;-
Barbara Death
From Aunt Emma
March 6th 1921
Thank you,
Tony Lance
Big Bertha Thing outlandish
Outlandish Particle Periodic Table
By Tony Lance Dip.Math(Open) 16th January 2004
Update V from
http://web.onetel.com/~tonylance/structur.html
Review of Particle Physics 1st July 2002 Physical Review D66 (2002)
Reviews Included 1980, 1992, 1994, 1996, 1998, 2000, 2002.
Review from http://pdg.lbl.gov/2002/contents_listings.html
M Mesons: B Baryons: L Leptons: S Summary Particle List
X Full Experimental Particle List: C Ratio Match Checked
Review used in 1st, 3rd, last & part of 2nd columns.
Col.1 Actual Particle Mass MeV (Electron .510998902)
Col.2 Nominal Particle Mass Error MeV
(Actual Error MeV detail line number 1,3,45,436,437,803) updated
(Electron Mass MeV 0.510998901 Nominal Electron Error MeV 2.0D-08
detail line numbers 13,19,22,24,36,51,56,57,62,79,86,95,96,99,106,
119,122,123,124,130,145,147,148,152,154,158,159,16 1,168,172,175,
177,180,181,183,185,187,190,191,192,194,195,196,19 7,200,202,204,
205,208,210,225,226,229,231,236,238,244,252,260,26 3,273,276,279,
285,292,298,305,313,315,322,328,330,332,333,337,34 1,344,354,357,
363,372,373,381,384,387,388,395,398,399,400,404,40 9,416,419,424,
425,427,433,435,443,445,451,458,459,469,470,472,48 7,496,498,499,
503,504,509,524,530,535,540,542,548,554,560,567,56 9,576,580,581,
582,592,593,595,598,599,604,605,608,611,620,625,63 6,638,639,640,
641,647,651,672,683,686,688,690,692,697,699,706,71 3,721,725,733,
735,738,743,744,745,767,772,776,782) updated
(Electron Mass MeV 0.510998902 Nominal Electron Error MeV 1.0D-09
detail line numbers 6,25,38,54,55,87,171,184,193,201,219,227,
232,233,235,259,277,284,290,310,314,320,325,329,33 1,334,336,
338,340,342,345,370,411,420,422,430,431,434,462,46 5,475,492,500,
501,507,508,510,514,515,536,544,564,587,594,600,60 1,627,628,637,
645,652,653,680,687,691,696,698,700,704,710,718,72 0,732,737,742,
752,753,761,763,775,777,778,783,786,788,790) updated
(Offset see detail line numbers 20,655(441,521)354,355(220,529)
86,460(91,669)93,461(245,378)94,379(247,552)672,76 5(383,673)
465,766(474,628)125,272(126,127)633,682(130,634)13 4,770(138,570)
139,278(404,405)407,574(152,576)290,412(416,491)16 3,580(164,582)
584,689(311,777)695,741(189,652)190,597) updated
(Sequential see detail line numbers 4,5,6,7(56,57)58.59(94,95)
180,181(219,220)346,347,348(395,396)425,426(518,51 9)532,533
(536,537,538,539)602,603(651,652)701,702(753,754)) updated
Col.3 Particle Charge Exists (1:0)
Col.4 Particle Detail Line No.
Col.5 Polygon Edge Length in Photons
Col.6 Particle Structure Type (1-10,77,88,99)
Col.7 Particle Mass in Photons (Electron 227879226)
Col.8 Particle Pair Mass Ratio
Col.9 Index From Above (MBL, XS, C one from each group)
Type 1 Polygon III 1
000.510998902 2.1D-08 1 1 21348 1 227879226. 1.000000000 XLC
Type 2 Polyhedron III 4
134.97430000 .000390 0 2 173481 2 60191661684. 264.138433066 SMC
139.56782000 .000370 1 3 176085 2 62240085846. 273.127511176 XMC
493.63100000 .000600 1 4 331591 2 220133724970. 966.010499658 XMC
493.65700000 .000100 1 5 331600 2 220145662426. 966.062884670 XMC
493.67500000 .000070 1 6 331606 2 220153620910. 966.097808802 XMC
493.69600000 .000900 1 7 331613 2 220162905990. 966.138554420 XMC
493.78000000 .001000 1 8 331641 2 220200048270. 966.301545495 XMC
498.90000000 .000100 0 9 333529 2 222483854740. 976.323549300 XMC
547.30000000 .000500 0 10 349333 2 244067788444. 1071.040097547 XMC
547.45000000 .001200 0 11 349381 2 244134865084. 1071.334449258 XMC
548.20000000 .001000 0 12 349620 2 244468988040. 1072.800677496 XMC
549.00000000 .000004 0 13 349875 2 244825731000. 1074.366168858 XMC
744.00000000 .000100 0 14 407299 2 331785765400. 1455.971969117 XMC
750.00000000 .000100 0 15 408938 2 334461393564. 1467.713399922 XMC
761.10000000 .000100 0 16 411953 2 339411372324. 1489.435339420 XMC
764.10000000 .000500 0 17 412764 2 340749064920. 1495.305521706 XMC
766.00000000 .000200 1 18 413139 2 341596372146. 1499.023751055 XMC
766.80000000 .000070 1 19 413355 2 341953417986. 1500.590571542 XMC
767.00000000 .000100 1 20 413409 2 342042708606. 1500.982404627 XMC
769.50000000 .000150 0 21 414220 2 343157245240. 1505.873313963 XMC
773.00000000 .000100 0 22 415161 2 344718142164. 1512.722981445 XMC
775.00000000 .000500 0 23 415698 2 345610485804. 1516.638843613 XMC
776.09000000 .000070 0 24 415990 2 346096192180. 1518.770263771 XMC
777.40000000 .000150 0 25 416341 2 346680489244. 1521.334328404 XMC
781.00000000 .000270 0 26 417304 2 348286091440. 1528.380175558 XMC
781.96000000 .000900 0 27 417560 2 348713542320. 1530.255953739 XMC
782.60000000 .000100 0 28 417731 2 348999212184. 1531.509555785 XMC
783.20000000 .000400 0 29 417891 2 349266611544. 1532.682981572 XMC
888.00000000 .001000 1 30 444845 2 396002916966. 1737.775416904 XMC
890.40000000 .000650 1 31 445446 2 397073047950. 1742.471461396 XMC
890.70000000 .000500 1 32 445521 2 397206693150. 1743.057935215 XMC
891.00000000 .000500 1 33 445596 2 397340360850. 1743.644507771 XMC
891.70000000 .000004 1 34 445771 2 397652339650. 1745.013561043 XMC
891.90000000 .000070 1 35 445821 2 397741498950. 1745.404817857 XMC
892.20000000 .000004 1 36 445896 2 397875256650. 1745.991785359 XMC
892.60000000 .000900 1 37 445996 2 398053635250. 1746.774562285 XMC
892.80000000 .000070 1 38 446046 2 398142839550. 1747.166016572 XMC
893.50000000 .000100 1 39 446221 2 398455133350. 1748.536452156 XMC
894.90000000 .000300 0 40 446698 2 399079099804. 1751.274597554 XMC
895.00000000 .000100 0 41 446723 2 399123770904. 1751.470627270 XMC
897.00000000 .001000 0 42 447222 2 400015929012. 1755.385675270 XMC
897.10000000 .000500 0 43 447247 2 400060652512. 1755.581934932 XMC
898.40000000 .000500 0 44 447571 2 400640495224. 1758.126452580 XMC
939.56533000 .000038 0 45 457710 2 418997803620. 1838.683635076 XBC
956.10000000 .000100 0 46 461720 2 426371640240. 1871.042164414 XMC
956.30000000 .000350 0 47 461768 2 426460295184. 1871.431207968 XMC
957.80000000 .000600 0 48 462130 2 427129198060. 1874.366547392 XMC
969.80000000 .000100 0 49 465016 2 432480690544. 1897.850445323 XMC
974.00000000 .000070 0 50 466022 2 434353941012. 1906.070810562 XMC
976.00000000 .000035 1 51 466378 2 435245689750. 1909.984062128 XMC
977.00000000 .000100 0 52 466739 2 435691521720. 1911.940501852 XMC
982.00000000 .000100 0 53 467932 2 437921649112. 1921.726946326 XMC
993.10000000 .000150 1 54 470448 2 442871461530. 1943.448155867 XMC
1019.30000000 .000035 0 55 476736 2 454555380864. 1994.720575644 XMC
1019.41100000 .000004 0 56 476762 2 454604962812. 1994.938155582 XMC
1019.42000000 .000015 0 57 476764 2 454608776920. 1994.954892992 XMC
1019.48300000 .001000 0 58 476779 2 454637383240. 1995.080425804 XMC
1019.51000000 .000100 0 59 476785 2 454648826020. 1995.130640035 XMC
1019.60000000 .000300 0 60 476806 2 454688876884. 1995.306394818 XMC
1019.80000000 .000035 0 61 476853 2 454778520924. 1995.699778812 XMC
1020.10000000 .000035 0 62 476923 2 454912049704. 1996.285741746 XMC
1020.90000000 .000070 0 63 477110 2 455268858420. 1997.851521665 XMC
1115.44000000 .001000 0 64 498712 2 497428315312. 2182.859420946 XBC
1115.59000000 .000500 0 65 498746 2 497496142524. 2183.157066384 XBC
1168.00000000 .000500 0 66 510327 2 520868314512. 2285.720921801 XMC
1189.16000000 .000045 1 67 514818 2 530304055110. 2327.127682582 XBC
1189.33000000 .000500 1 68 514855 2 530380250986. 2327.462052140 XBC
1197.43000000 .000150 1 69 516606 2 533992430910. 2343.313343139 XBC
1225.00000000 .000500 0 70 522631 2 546287369584. 2397.267092631 XMC
1231.20000000 .000500 1 71 523843 2 549051904210. 2409.398670724 XBC
1232.50000000 .000800 0 72 524228 2 549631040424. 2411.940088053 XBC
1233.60000000 .000700 0 73 524462 2 550121827812. 2414.093805163 XBC
1234.90000000 .000500 1 74 524630 2 550702202286. 2416.640656336 XBC
1269.70000000 .000800 0 75 532081 2 566221445284. 2484.743586429 XMC
1274.00000000 .000004 0 76 532981 2 568138558684. 2493.156434909 XMC
1277.00000000 .000100 0 77 533608 2 569476062544. 2499.025788968 XMC
1278.00000000 .000004 0 78 533817 2 569922246612. 2500.983773800 XMC
1285.00000000 .000070 0 79 535277 2 573044004012. 2514.682948818 XMC
1299.00000000 .000004 0 80 538185 2 579287264820. 2542.080184264 XMC
1309.00000000 .000100 1 81 540147 2 583746522738. 2561.648698675 XMC
1321.67000000 .000100 1 82 542756 2 589397115810. 2586.445136557 XBC
1321.87000000 .000500 1 83 542797 2 589486131238. 2586.835762019 XBC
1330.70000000 .000700 0 84 544712 2 593423415312. 2604.113704125 XMC
1336.20000000 .001000 0 85 545837 2 595877152812. 2614.881414473 XMC
1380.00000000 .000100 1 86 554608 2 615409055770. 2700.593057877 XBC
1381.00000000 .000150 1 87 554809 2 615855041806. 2702.550173687 XBC
1382.00000000 .000100 1 88 555010 2 616301189446. 2704.507998662 XBC
1383.20000000 .001000 1 89 555251 2 616836335730. 2706.856375447 XBC
1383.50000000 .000100 1 90 555311 2 616969603290. 2707.441192073 XBC
1384.10000000 .000500 0 91 555534 2 617237161380. 2708.615314412 XBC
1384.90000000 .000070 1 92 555592 2 617593931338. 2710.180924250 XBC
1385.10000000 .000700 0 93 555735 2 617683891920. 2710.575697321 XBC
1391.00000000 .000350 0 94 556917 2 620314203612. 2722.118266331 XBC
1391.50000000 .000200 1 95 556915 2 620537627506. 2723.098715045 XBC
1392.00000000 .000100 1 96 557015 2 620760413706. 2724.076365373 XBC
1399.80000000 .000100 1 97 558574 2 624238823326. 2739.340633560 XBC
1400.00000000 .000070 0 98 558716 2 624328254744. 2739.733084507 XMC
1407.00000000 .000100 0 99 560111 2 627449784864. 2753.431262155 XMC
1409.00000000 .000100 0 100 560509 2 628341799180. 2757.345679154 XMC
1410.70000000 .000200 0 101 560847 2 629099836512. 2760.672166369 XBC
1422.00000000 .001000 0 102 563089 2 634139570020. 2782.787975680 XMC
1429.00000000 .000100 0 103 564473 2 637260664404. 2796.484241192 XMC
1436.00000000 .000004 1 104 565753 2 640381924750. 2810.181234993 XMC
1453.00000000 .001200 0 105 569193 2 647962480884. 2843.446909391 XMC
1477.00000000 .000004 0 106 573875 2 658666179000. 2890.417834753 XMC
1479.00000000 .000100 1 107 574164 2 659557625346. 2894.329759335 XBC
1485.00000000 .000100 1 108 575328 2 662233645050. 2906.072908331 XBC
1503.00000000 .000100 0 109 578904 2 670260840240. 2941.298564179 XBC
1519.00000000 3.5D-06 0 110 581977 2 677395621012. 2972.608047264 XBC
1521.00000000 .000100 0 111 582360 2 678287503920. 2976.521887607 XMC
1523.80000000 .000200 0 112 582896 2 679536659424. 2982.003543509 XMC
1532.10000000 .001000 0 113 584481 2 683237247684. 2998.242795875 XBC
1533.00000000 .000070 0 114 584653 2 683639430124. 3000.007688827 XBC
1540.00000000 .000015 1 115 585889 2 686760891646. 3013.705565447 XBC
1549.00000000 .000100 0 116 587696 2 690774352224. 3031.317792101 XBC
1610.00000000 .000100 0 117 599156 2 717977022984. 3150.690984811 XBC
1618.00000000 .000070 1 118 600548 2 721544880930. 3166.347778143 XBC
1620.00000000 .000035 0 119 601014 2 722436858420. 3170.262033539 XBC
1629.00000000 .000100 0 120 602681 2 726449980884. 3187.872776450 XMC
1667.00000000 .000100 0 121 609670 2 743396237140. 3262.237853748 XBC
1671.00000000 .000100 0 122 610401 2 745179982404. 3270.065444245 XBC
1671.90000000 .000100 1 123 610472 2 745581225738. 3271.826216129 XBC
1673.40000000 .000100 1 124 610746 2 746250453750. 3274.762982344 XBC
1682.00000000 .000200 0 125 612407 2 750085892112. 3291.593995988 XBC
1684.00000000 .000500 1 126 612678 2 750977767950. 3295.507805306 XBC
1684.00000000 .001000 0 127 612771 2 750977822424. 3295.508044353 XBC
1688.00000000 .000700 0 128 613498 2 752760819004. 3303.332349409 XBC
1695.70000000 .000300 0 129 614896 2 756195411424. 3318.404335040 XBC
1700.00000000 .000100 0 130 615675 2 758112642600. 3326.817700355 XBC
1746.00000000 .000100 0 131 623949 2 778625957100. 3416.836061660 XBC
1773.00000000 .000100 0 132 628755 2 790666957560. 3469.675456770 XMC
1778.00000000 .000100 0 133 629641 2 792896837044. 3479.460813352 XBC
1817.00000000 .001000 0 134 636509 2 810288687180. 3555.781285566 XBC
1819.00000000 .001000 0 135 636859 2 811180045480. 3559.692823777 XBC
1819.40000000 .000500 0 136 636929 2 811358375940. 3560.475389450 XBC
1821.00000000 .000500 0 137 637209 2 812071893780. 3563.606512250 XBC
1822.00000000 .001000 0 138 637384 2 812518001680. 3565.564162834 XBC
1823.00000000 .000100 0 139 637559 2 812964232080. 3567.522350984 XBC
1868.40000000 .000350 1 140 645361 2 833210810590. 3656.370197562 XMC
1894.00000000 .000100 0 141 649856 2 844626941184. 3706.467482841 XBC
1908.00000000 .001000 0 142 652253 2 850869256524. 3733.860569300 XBC
1909.00000000 .000100 0 143 652424 2 851315456400. 3735.818623502 XBC
1920.00000000 .000100 0 144 654301 2 856220905804. 3757.345155297 XBC
1935.50000000 .000300 0 145 656937 2 863133757812. 3787.680750732 XMC
1935.90000000 .001000 0 146 657005 2 863312454060. 3788.464921590 XMC
1968.30000000 .000137 1 147 662394 2 877760826486. 3851.868561665 XMC
1972.70000000 .000100 1 148 663134 2 879722609406. 3860.477432928 XMC
1978.00000000 .000850 0 149 664110 2 882085512420. 3870.846535261 XMC
2006.00000000 .000700 0 150 668794 2 894572166460. 3925.641587268 XMC
2015.00000000 .000100 0 151 670293 2 898586752284. 3943.258751827 XMC
2019.00000000 .000100 1 152 670873 2 900370385230. 3951.085849440 XBC
2020.00000000 .000100 0 153 671124 2 900816189000. 3953.042165414 XBC
2030.00000000 .000250 0 154 672783 2 905275275744. 3972.609928665 XBC
2070.00000000 .000500 0 155 679379 2 923113010040. 4050.887069627 XBC
2104.00000000 .000100 0 156 684936 2 938276018064. 4117.426737547 XBC
2107.00000000 .000100 0 157 685424 2 939613490400. 4123.295953270 XBC
2231.90000000 .000100 0 158 705447 2 995312350512. 4367.718672662 XMC
2281.70000000 .000100 1 159 713194 2 1017520668886. 4465.175201560 XBC
2286.20000000 .001000 1 160 713897 2 1019527160238. 4473.980266363 XBC
2340.00000000 .000100 0 161 722329 2 1043519813140. 4579.266971619 XBC
2422.00000000 .000100 0 162 734876 2 1080086940504. 4739.734110313 XMC
2425.00000000 .001300 1 163 735254 2 1081426238766. 4745.611338727 XMC
2453.00000000 .000500 0 164 739564 2 1093911299320. 4800.399398057 XMC
2459.00000000 .000100 0 165 740468 2 1096587198984. 4812.142020282 XMC
2465.00000000 .000100 0 166 741371 2 1099263402024. 4823.885973810 XMC
2466.50000000 .002000 1 167 741520 2 1099933183066. 4826.825166880 XBC
2473.30000000 .000200 0 168 742618 2 1102964473084. 4840.127344842 XBC
2536.60000000 .001000 1 169 751985 2 1131192263646. 4963.999059949 XMC
2578.80000000 .000100 0 170 758291 2 1150011997944. 5046.585501146 SBC
2593.60000000 .000070 1 171 760389 2 1156612262646. 5075.549373009 SBC
2593.90000000 .000070 1 172 760433 2 1156746095070. 5076.136668421 SBC
2705.90000000 .000100 0 173 776753 2 1206691999524. 5295.313753277 XBC
2719.00000000 .000100 0 174 778631 2 1212534025584. 5320.950254518 XBC
2819.00000000 .000100 0 175 792820 2 1257128690440. 5516.644551180 SBC
2880.90000000 .001000 1 176 801406 2 1284732635710. 5637.778652583 SBC
2969.00000000 .000500 0 177 813640 2 1324021726480. 5810.190554535 XMC
2980.20000000 .000100 0 178 815173 2 1329015670204. 5832.105425020 XMC
2982.00000000 .000500 0 179 815419 2 1329817921960. 5835.625937926 XMC
3096.89000000 .000100 0 180 830979 2 1381053858840. 6060.464058448 XMC
3096.95000000 .000100 0 181 830987 2 1381080450312. 6060.580749524 XMC
3417.80000000 .001000 0 182 872972 2 1524161971512. 6688.463877405 XMC
3507.40000000 .000100 0 183 884341 2 1564119777244. 6863.810294160 XMC
3526.20000000 .000350 0 184 886708 2 1572503927944. 6900.602374101 XMC
3556.40000000 .000070 0 185 890497 2 1585971595012. 6959.702395215 XMC
3557.80000000 .000500 0 186 890672 2 1586595004512. 6962.438096538 XMC
3594.00000000 .000100 0 187 895192 2 1602739224112. 7033.283604851 XMC
3685.95000000 .000150 0 188 906571 2 1643743769224. 7213.223416969 XMC
5278.20000000 .000100 0 189 1084851 2 2353805554104. 10329.180046030 XMC
5279.10000000 .000070 1 190 1084891 2 2354207012770. 10330.941762853 XMC
5280.50000000 .000100 1 191 1085035 2 2354831951746. 10333.684175959 XMC
5416.60000000 .000100 0 192 1098982 2 2415525070612. 10600.023148279 SMC
5713.00000000 .000323 0 193 1128650 2 2547703902300. 11180.062118958 XMC
9460.51000000 .001000 0 194 1452394 2 4218899567260. 18513.752399966 XMC
9460.60000000 .000100 0 195 1452401 2 4218940234404. 18513.930859165 XMC
9859.90000000 .000070 0 196 1482735 2 4397009125920. 19295.348694576 XMC
9864.00000000 .000100 0 197 1483043 2 4398836045784. 19303.365747714 XMC
9891.80000000 .002500 0 198 1485131 2 4411231144584. 19357.759028829 XMC
9893.70000000 .000200 0 199 1485274 2 4412080680700. 19361.487039192 XMC
9912.20000000 .000100 0 200 1486662 2 4420330777812. 19397.690853189 XMC
9913.20000000 .000767 0 201 1486737 2 4420776787812. 19399.648074160 XMC
9914.00000000 .000100 0 202 1486797 2 4421133612012. 19401.213922027 XMC
9914.50000000 .002000 0 203 1486835 2 4421359608120. 19402.205658360 XMC
10023.60000000 .000300 0 204 1494993 2 4470011130084. 19615.702618211 XMC
10268.10000000 .001000 0 205 1513116 2 4579043085144. 20094.166394720 XMC
Type 3 Polyhedron III 8
139.57071000 .000240 1 206 124512 3 62241329850. 273.132970225 XMC
493.90000000 .000700 1 207 234534 3 220253605986. 966.536572254 XMC
546.00000000 .000035 0 208 246722 3 243487968024. 1068.495677724 XMC
555.00000000 .000250 0 209 248747 3 247501275024. 1086.107230433 XMC
763.00000000 .000070 0 210 291658 3 340258722488. 1493.153757192 XMC
765.00000000 .000100 0 211 292040 3 341150614560. 1497.067637749 XMC
767.60000000 .000500 0 212 292536 3 342310415328. 1502.157179207 XMC
767.70000000 .000070 0 213 292555 3 342354882320. 1502.352313238 XMC
770.50000000 .000100 0 214 293088 3 343603475328. 1507.831500744 XMC
782.71000000 .000500 0 215 295401 3 349048184808. 1531.724461834 XMC
894.30000000 .000070 1 216 315667 3 398811761450. 1750.101439479 XMC
894.52000000 .000350 0 217 315796 3 398909717648. 1750.531299628 XMC
894.70000000 .000500 0 218 315828 3 398990565648. 1750.886084052 XMC
895.50000000 .000060 0 219 315969 3 399346899720. 1752.449781096 XMC
896.00000000 .000100 1 220 315967 3 399569723450. 1753.427596116 XMC
983.70000000 .000035 1 221 331078 3 438679771874. 1925.053808433 SMC
986.00000000 .000100 1 222 331465 3 439705389986. 1929.554517558 XMC
989.00000000 .000500 1 223 331969 3 441042874946. 1935.423788678 XMC
1018.90000000 .000100 0 224 337037 3 454377105624. 1993.938252292 XMC
1020.40000000 .000070 0 225 337285 3 455046034040. 1996.873703793 XMC
1107.00000000 .000035 0 226 351306 3 493665027768. 2166.345025974 XMC
1115.60000000 .000100 0 227 352668 3 497500283568. 2183.175238484 XBC
1115.86000000 .000035 0 228 352709 3 497615965560. 2183.682884547 XBC
1197.53200000 .000150 1 229 365311 3 534037847354. 2343.512643640 XBC
1213.00000000 .000500 0 230 367741 3 540935243288. 2373.780413349 XMC
1231.60000000 .000100 1 231 370473 3 549230336034. 2410.181681212 XBC
1269.00000000 .000150 0 232 376134 3 565908648360. 2483.370942992 XMC
1281.90000000 .000100 0 233 378041 3 571661502888. 2508.616133741 XMC
1318.00000000 .000700 0 234 383327 3 587759889024. 2579.260511548 XMC
1320.60000000 .000100 0 235 383705 3 588919642920. 2584.349847318 XMC
1321.20000000 .000120 1 236 383718 3 589187428194. 2585.524966607 XBC
1321.40000000 .001000 1 237 383747 3 589276454250. 2585.915638708 XBC
1321.60000000 .000100 1 238 383776 3 589365487034. 2586.306340333 XBC
1323.10000000 .000100 0 239 384068 3 590034450768. 2589.241946820 XMC
1376.00000000 .000100 1 240 391598 3 613625420034. 2692.765948020 XBC
1384.00000000 .001000 1 241 392735 3 617192571066. 2708.419639208 XBC
1384.40000000 .000500 1 242 392792 3 617371671450. 2709.205583531 XBC
1384.50000000 .000150 1 243 392806 3 617415664994. 2709.398639936 XBC
1385.00000000 .000100 1 244 392877 3 617638799250. 2710.377817634 XBC
1389.00000000 .000350 1 245 393444 3 619422177546. 2718.203797770 XBC
1409.60000000 .000400 0 246 396424 3 628609536800. 2758.520589323 XBC
1420.00000000 .000100 1 247 397812 3 633247019850. 2778.871207198 XMC
1423.40000000 .001000 1 248 398288 3 634762796154. 2785.522872339 XMC
1423.80000000 .000120 1 249 398344 3 634941241946. 2786.305944123 XMC
1449.00000000 .000100 0 250 401926 3 646179645608. 2835.623312184 XMC
1475.00000000 .000500 0 251 405516 3 657774527088. 2886.505008087 XMC
1500.00000000 .000100 0 252 408938 3 668922787128. 2935.426799844 XBC
1507.00000000 .000100 0 253 409891 3 672044167088. 2949.124318546 XBC
1510.00000000 .000500 0 254 410299 3 673382718800. 2954.998270882 XBC
1519.40000000 .000350 0 255 411574 3 677574276200. 2973.392037939 XBC
1525.00000000 .001200 0 256 412332 3 680072362224. 2984.354362446 XBC
1526.80000000 .000100 0 257 412575 3 680874172800. 2987.872939326 XMC
1530.00000000 .001000 0 258 413007 3 682300780224. 2994.133305613 XBC
1532.00000000 .000070 0 259 413277 3 683193168024. 2998.049361568 XBC
1532.20000000 .000100 0 260 413304 3 683282438880. 2998.441107923 XBC
1534.00000000 .001700 0 261 413547 3 684086139024. 3001.967976774 XBC
1534.70000000 .001000 1 262 413572 3 684396730250. 3003.330940970 XBC
1535.30000000 .000035 1 263 413653 3 684664751474. 3004.507095675 XBC
1582.00000000 .000100 0 264 419967 3 705490804224. 3095.897842939 XBC
1596.00000000 .000300 0 265 421821 3 711733511448. 3123.292649098 XBC
1625.00000000 .000870 0 266 425636 3 724665720528. 3180.042925580 XBC
1633.60000000 .000100 0 267 426761 3 728501511528. 3196.875486702 XMC
1640.00000000 .001000 0 268 427596 3 731355067248. 3209.397715121 XBC
1659.00000000 .000100 0 269 430066 3 739828777688. 3246.582809124 XBC
1671.70000000 .001000 1 270 431643 3 745492323594. 3271.436087790 XBC
1676.00000000 .000700 0 271 432264 3 747410391840. 3279.853126410 XBC
1682.00000000 .000150 1 272 432971 3 750085158474. 3291.590776572 XBC
1689.00000000 .000100 0 273 433937 3 753207015624. 3305.290389322 XBC
1760.00000000 .001000 0 274 442964 3 784870193040. 3444.237576268 XBC
1774.00000000 .000100 0 275 444722 3 791112408024. 3471.630222335 XBC
1776.96000000 .000100 1 276 445029 3 792432902706. 3477.424935198 XLC
1777.00000000 .000200 0 277 445098 3 792450698808. 3477.503029644 XBC
1823.00000000 .001000 1 278 450759 3 812964386586. 3567.523029001 XBC
1826.00000000 .000100 0 279 451193 3 814302297768. 3573.394170507 XBC
1860.00000000 .000700 0 280 455374 3 829463741000. 3639.926971667 XMC
1863.30000000 .000100 0 281 455778 3 830936164248. 3646.388391051 XMC
1864.60000000 .001000 0 282 455937 3 831516015624. 3648.932946718 XMC
1869.40000000 .000350 1 283 456461 3 833656283154. 3658.325060109 XMC
1911.00000000 .000100 0 284 461575 3 852207768800. 3739.734348580 XMC
1945.00000000 .000100 0 285 465663 3 867369980928. 3806.270523878 XBC
1963.00000000 .000200 1 286 467752 3 875397484250. 3841.497531899 XMC
2008.60000000 .000700 1 287 473155 3 895732387946. 3930.732974958 XMC
2022.00000000 .000100 1 288 474731 3 901707867594. 3956.955109168 XBC
2036.00000000 .000100 0 289 476432 3 907951708224. 3984.354889041 XBC
2044.00000000 .000100 0 290 477367 3 911518920224. 4000.008847774 XBC
2082.00000000 .000100 0 291 481784 3 928465217760. 4074.374106221 XBC
2100.00000000 .000300 0 292 483862 3 936491675624. 4109.596526469 XBC
2110.00000000 .000200 1 293 484954 3 940951347506. 4129.166857474 SMC
2137.00000000 .001000 0 294 488106 3 952991821368. 4182.003941720 XBC
2204.50000000 .000070 0 295 495755 3 983094063120. 4314.101291181 XBC
2281.00000000 .000700 1 296 504227 3 1017209366250. 4463.809115492 XBC
2283.00000000 .000100 1 297 504448 3 1018101035834. 4467.722019707 XBC
2283.10000000 .000070 1 298 504459 3 1018145427786. 4467.916824441 XBC
2285.80000000 .001000 1 299 504757 3 1019348414450. 4473.195878110 XBC
2290.00000000 .001000 1 300 505221 3 1021222935474. 4481.421818916 XBC
2307.00000000 .001000 0 301 507149 3 1028802461400. 4514.682972462 XMC
2356.00000000 .001000 1 302 512451 3 1050654038634. 4610.574017984 XBC
2359.00000000 .000100 0 303 512833 3 1051992794888. 4616.448867910 XMC
2414.00000000 .000500 0 304 518777 3 1076520378024. 4724.083001862 XMC
2428.00000000 .000100 0 305 520279 3 1082763032480. 4751.477576460 XMC
2451.30000000 .000100 1 306 522715 3 1093153854986. 4797.075513088 SBC
2452.10000000 .001500 0 307 522855 3 1093511495520. 4798.644943265 SBC
2455.00000000 .000400 0 308 523164 3 1094804376240. 4804.318478070 XMC
2462.10000000 .000800 0 309 523920 3 1097970761280. 4818.213492089 XBC
2465.80000000 .000070 1 310 524259 3 1099619972586. 4825.450708640 XBC
2500.00000000 .000300 0 311 527937 3 1114872015624. 4892.381087972 XBC
2534.20000000 .000100 1 312 531482 3 1130122470450. 4959.304497769 XMC
2534.80000000 .000100 1 313 531545 3 1130390353506. 4960.480046154 XMC
2535.00000000 .000100 1 314 531566 3 1130479654914. 4960.871926579 XMC
2535.20000000 .000100 1 315 531587 3 1130568959850. 4961.263822486 XMC
2574.50000000 .001000 1 316 535692 3 1148093697450. 5038.167443354 XMC
2644.50000000 .000100 0 317 542980 3 1179311293520. 5175.159290387 SBC
2694.60000000 .000600 0 318 548099 3 1201652247600. 5273.197863152 XBC
2699.90000000 .000035 0 319 548638 3 1204016814728. 5283.574268099 XBC
2976.00000000 .000500 0 320 576008 3 1327143168288. 5823.888344644 XMC
3097.00000000 .000350 0 321 587601 3 1381102091208. 6060.675716039 XMC
3170.00000000 .000100 0 322 594486 3 1413656794728. 6203.535177568 XBC
3416.50000000 .000100 0 323 617167 3 1523582892224. 6685.922709883 XMC
3510.10000000 .000100 0 324 625564 3 1565323774640. 6869.093783213 XMC
3511.30000000 .000350 0 325 625671 3 1565859303648. 6871.443839501 XMC
3512.30000000 .000100 0 326 625760 3 1566304813440. 6873.398865415 XMC
3525.40000000 .000700 0 327 626926 3 1572147345608. 6899.037587604 XMC
3555.90000000 .000100 0 328 629632 3 1585748340224. 6958.722688588 XMC
3770.00000000 .000015 0 329 648310 3 1681226017640. 7377.706371708 XMC
3772.00000000 .000100 0 330 648482 3 1682118211224. 7381.621575387 XMC
4040.00000000 .000500 0 331 671124 3 1801632378000. 7906.084330829 XMC
5279.20000000 .000100 0 332 767178 3 2354251403448. 10331.136561996 XMC
9460.59000000 .000100 0 333 1027002 3 4218936540024. 18513.914647156 XMC
9858.10000000 .000150 0 334 1048356 3 4396205404368. 19291.821731780 XMC
9860.00000000 .000500 0 335 1048457 3 4397052517224. 19295.539108177 XMC
9890.70000000 .000100 0 336 1050088 3 4410743431328. 19355.618801900 XMC
9892.00000000 .000100 0 337 1050157 3 4411323099224. 19358.162552404 XMC
9893.60000000 .001000 0 338 1050242 3 4412037235224. 19361.296387868 XMC
9911.90000000 .000070 0 339 1051213 3 4420199290328. 19397.113848052 XMC
9912.30000000 .000200 0 340 1051234 3 4420375895960. 19397.888844681 XMC
9913.30000000 .000500 0 341 1051287 3 4420821630624. 19399.844857398 XMC
10023.10000000 .000630 0 342 1057093 3 4469786670968. 19614.717626643 XMC
10254.70000000 .000150 0 343 1069236 3 4573066771728. 20067.940601694 XMC
10355.20000000 .000100 0 344 1074463 3 4617887251328. 20264.625838812 XMC
10580.00000000 .000100 0 345 1086063 3 4718135704128. 20704.545065148 XMC
Type 4 Polyhedron IV 6
493.63800000 .000070 1 346 178161 4 220137085512. 966.025246689 XMC
493.70900000 .000570 1 347 178174 4 220169167446. 966.166031501 XMC
493.75300000 .000300 1 348 178182 4 220188664620. 966.251590744 XMC
498.10000000 .000100 0 349 179057 4 222127108626. 974.758044097 XMC
547.12000000 .000230 0 350 187661 4 243987174396. 1070.686339772 XMC
757.50000000 .000070 0 351 220813 4 337806028500. 1482.390626077 XMC
762.60000000 .000350 0 352 221555 4 340080397086. 1492.371213715 XMC
764.00000000 .000070 0 353 221758 4 340704674880. 1495.110725363 XMC
771.00000000 .000004 0 354 222772 4 343826424186. 1508.809864862 XMC
771.00000000 .000100 1 355 222698 4 343826515794. 1508.810266865 XMC
775.80000000 .000100 0 356 223464 4 345967084554. 1518.203702140 XMC
777.00000000 .000100 0 357 223637 4 346501945830. 1520.550828227 XMC
782.08000000 .000600 0 358 224367 4 348767852124. 1530.494280878 XMC
893.70000000 .001000 0 359 239844 4 398543626770. 1748.924786896 XMC
894.00000000 .000500 0 360 239884 4 398677741194. 1749.513319806 XMC
984.00000000 .000100 1 361 251604 4 438813539496. 1925.640819475 XMC
1019.70000000 3.5D-07 0 362 256194 4 454733727150. 1995.503210767 XMC
1115.67800000 .000100 0 363 267980 4 497535027372. 2183.327704352 XBC
1189.48000000 .000350 1 364 276642 4 530446724088. 2327.753755351 XBC
1192.65000000 .000350 0 365 277070 4 531860395644. 2333.957355305 XBC
1233.80000000 .000630 0 366 281809 4 550211369658. 2414.486740700 XBC
1268.00000000 .000500 0 367 285688 4 565462411500. 2481.412726494 XMC
1280.00000000 .000035 0 368 287037 4 570813987582. 2504.896991277 XMC
1282.00000000 .000100 0 369 287261 4 571705847100. 2508.810728978 XMC
1286.00000000 .000120 0 370 287709 4 573489928470. 2516.639794406 XMC
1314.82000000 .000350 0 371 290915 4 586342247556. 2573.039490471 XBC
1317.90000000 .000035 1 372 291199 4 587715611406. 2579.066208545 XBC
1320.69000000 .000040 1 373 291507 4 588959653746. 2584.525426403 XBC
1321.46000000 .000700 1 374 291592 4 589302777078. 2586.031150896 XBC
1382.60000000 .000500 1 375 298264 4 616568523534. 2705.681138017 XBC
1383.00000000 .000150 1 376 298307 4 616746871974. 2706.463782592 XBC
1388.00000000 .000100 0 377 298901 4 618976904826. 2716.249812197 XMC
1389.00000000 .000500 0 378 299009 4 619423018518. 2718.207488198 XBC
1391.00000000 .000100 1 379 299169 4 620314429176. 2722.119256171 XBC
1405.00000000 .000100 0 380 300726 4 626557970544. 2749.517722796 XMC
1413.00000000 .000004 0 381 301581 4 630125312508. 2765.172251849 XMC
1421.60000000 .001680 0 382 302497 4 633959459850. 2781.997600123 XMC
1428.00000000 .000200 1 383 303123 4 636814228986. 2794.525153363 XMC
1433.40000000 .000004 0 384 303750 4 639222597780. 2805.093772699 XMC
1501.00000000 .000700 0 385 310830 4 669368219958. 2937.381488026 XBC
1512.00000000 .000100 0 386 311967 4 674274410172. 2958.911270710 XMC
1528.70000000 .000035 0 387 313685 4 681721740684. 2991.592312517 XBC
1535.70000000 .000100 1 388 314350 4 684843368286. 3005.290917944 XBC
1536.20000000 .000340 1 389 314401 4 685065737946. 3006.266740374 XBC
1572.00000000 .000070 1 390 318045 4 701031301908. 3076.328256039 XBC
1606.00000000 .000100 0 391 321518 4 716193734988. 3142.865400938 XBC
1655.00000000 .000700 0 392 326386 4 738045086814. 3238.755457305 XBC
1668.90000000 .001000 0 393 327754 4 744243638100. 3265.956494428 XBC
1670.00000000 .000800 0 394 327862 4 744734774358. 3268.111742481 XBC
1673.00000000 .000004 1 395 328106 4 746072052138. 3273.980104435 XBC
1673.10000000 .000100 1 396 328116 4 746116439604. 3274.174889483 XBC
1686.00000000 .000500 0 397 329429 4 751869819264. 3299.422384663 XBC
1723.00000000 .000300 0 398 333024 4 768369136422. 3371.826163838 XBC
1731.00000000 .000035 0 399 333796 4 771936808482. 3387.482141448 XMC
1772.00000000 .000100 0 400 337726 4 790220932116. 3467.718168026 XBC
1786.70000000 .000100 0 401 339124 4 796776089226. 3496.484094720 XBC
1813.00000000 .001000 1 402 341563 4 808505477976. 3547.956047455 XBC
1831.00000000 .001200 0 403 343302 4 816530945502. 3583.174121813 XBC
1838.00000000 .000100 0 404 343958 4 819653474160. 3596.876681335 XBC
1838.00000000 .000100 1 405 343910 4 819653478870. 3596.876702004 XBC
1840.00000000 .000100 0 406 344146 4 820549557108. 3600.808952669 XBC
1863.00000000 .000100 1 407 346242 4 830802376674. 3645.801292453 XMC
1897.00000000 .000150 0 408 349435 4 845964151644. 3712.335549376 XMC
1905.00000000 .000100 0 409 350171 4 849531841866. 3727.991606686 XBC*
1937.00000000 .000500 0 410 353100 4 863802843228. 3790.616891195 XBC
2024.00000000 .000250 1 411 360897 4 902599773762. 3960.869051583 XBC
2044.00000000 .001050 1 412 362676 4 911519706672. 4000.012298936 XBC
2091.00000000 .000100 0 413 366868 4 932478864510. 4091.987149851 XBC
2203.20000000 .000100 0 414 376582 4 982513937274. 4311.555531060 XBC
2358.00000000 .000100 0 415 389587 4 1051546947264. 4614.492359492 XBC
2373.00000000 .000100 1 416 390782 4 1058235964830. 4643.845704610 XBC
2421.00000000 .000100 0 417 394757 4 1079641658214. 4737.780082744 XMC
2461.00000000 .000070 0 418 398005 4 1097479896552. 4816.059435589 XMC
2505.00000000 .000004 1 419 401506 4 1117101349656. 4902.164050952 XBC
2573.20000000 .000200 1 420 406936 4 1147514970186. 5035.627820616 XMC
2984.00000000 .000100 0 421 438260 4 1330710985866. 5839.544960829 XMC
2988.30000000 .000500 0 422 438576 4 1332628322622. 5847.958789460 XMC
3096.93000000 .000700 0 423 446476 4 1381071948738. 6060.543442157 XMC
3098.40000000 .000004 0 424 446582 4 1381726733652. 6063.416827877 XMC
3510.40000000 .000100 0 425 475347 4 1565457677760. 6869.681388860 XMC
3510.53000000 .000070 0 426 475356 4 1565515838772. 6869.936616214 XMC
3563.00000000 .000100 0 427 478895 4 1588914483660. 6972.616642379 XMC
3684.00000000 .000100 0 428 486959 4 1642874291544. 7209.407897252 XMC
3686.00000000 .000100 0 429 487091 4 1643766775092. 7213.324373377 XMC
5275.80000000 .000100 1 430 582714 4 2352735512886. 10324.484395458 XMC
5278.80000000 .000700 1 431 582880 4 2354073661356. 10330.356578252 XMC
5281.30000000 .000100 0 432 583046 4 2355187809342. 10335.245782088 XMC
9915.70000000 .000100 0 433 798903 4 4421891783598. 19404.540998388 XMC
10023.50000000 .000200 0 434 803234 4 4469965511094. 19615.502428879 XMC
11019.00000000 .000100 0 435 842177 4 4913907861258. 21563.649954024 XMC
Type 5 Polyhedron III 20
105.65835680 5.2D-06 1 436 68476 5 47118189746. 206.768254277 XMC
139.57022000 .000140 1 437 78748 5 62241141746. 273.132144770 XMC
497.44000000 .000070 0 438 148940 5 221832725400. 973.466205296 XMC
497.66100000 .000800 0 439 148973 5 221931037020. 973.897625139 XMC
548.00000000 .000100 0 440 156326 5 244379746020. 1072.409057682 XMC
768.00000000 .000105 0 441 185064 5 342488691600. 1502.939507088 XMC
774.50000000 .000750 1 442 185784 5 345386683626. 1515.656734879 XMC
782.20000000 .000004 0 443 186767 5 348820990560. 1530.727467716 XMC
783.70000000 .000070 0 444 186946 5 349489938620. 1533.663005420 XMC
886.00000000 .000004 1 445 198716 5 395110352946. 1733.858587645 XMC
894.20000000 .000100 1 446 199634 5 398767215126. 1749.905957316 XMC
894.63000000 .000500 0 447 199739 5 398958678600. 1750.746154456 XMC
898.00000000 .000335 0 448 200115 5 400462133400. 1757.343749272 XMC
957.46000000 .000200 0 449 206634 5 426978165900. 1873.703774560 XMC
959.00000000 .000200 0 450 206800 5 427664468000. 1876.715466815 XMC
991.00000000 .000100 0 451 210222 5 441934995060. 1939.338669950 XMC
1019.40000000 .000100 0 452 213213 5 454599965820. 1994.916227335 XMC
1255.00000000 .000100 0 453 236572 5 559665477560. 2455.974102527 XMC
1272.00000000 .001000 0 454 238169 5 567247107300. 2489.244488219 XMC
1280.10000000 .000100 0 455 238926 5 570858724020. 2505.093307716 XMC
1281.00000000 .000200 0 456 239010 5 571260191100. 2506.855061461 XMC
1282.20000000 .000500 0 457 239122 5 571795700060. 2509.205029773 XMC
1321.12000000 .000100 1 458 242677 5 589151569286. 2585.367607340 XBC
1323.80000000 .000100 0 459 242970 5 590346638700. 2590.611917824 XMC
1380.00000000 .000700 0 460 248074 5 615409575500. 2700.595338603 XBC
1385.10000000 .000100 1 461 248486 5 617683286046. 2710.573038571 XBC
1388.30000000 .000100 1 462 248773 5 619110422246. 2716.835725280 XBC
1390.70000000 .000070 1 463 248988 5 620180610546. 2721.532021291 XBC
1425.00000000 .001000 0 464 252086 5 635476034820. 2788.652770042 XMC
1430.00000000 .000035 0 465 252528 5 637706433120. 2798.440403339 XMC
1431.20000000 .000150 0 466 252634 5 638241905900. 2800.790212882 XMC
1434.00000000 .000100 0 467 252881 5 639490530420. 2806.269538672 XMC
1515.00000000 .000650 0 468 259925 5 675612655500. 2964.783878545 XBC
1517.80000000 .000070 0 469 260165 5 676860873900. 2970.261422162 XBC
1531.40000000 .000150 0 470 261328 5 682925849120. 2996.876288846 XBC
1535.00000000 .000035 0 471 261635 5 684531348600. 3003.921685253 XBC
1608.00000000 .000035 0 472 267784 5 717085384400. 3146.778216633 XBC
1624.00000000 .000100 0 473 269113 5 724220758820. 3178.090304818 XBC
1665.00000000 3.5D-06 1 474 272447 5 742504281786. 3258.323695491 XBC
1665.10000000 .000200 0 475 272497 5 742548875060. 3258.519383684 XBC
1669.00000000 .000100 0 476 272816 5 744288426720. 3266.153039856 XMC
1670.60000000 .000100 1 477 272905 5 745001998526. 3269.284399474 XBC
1670.80000000 .001000 0 478 272963 5 745090723320. 3269.673749550 XBC
1671.80000000 .000100 1 479 273003 5 745536989346. 3271.632094037 XBC
1679.00000000 .000350 0 480 273632 5 748747450560. 3285.720527066 XBC
1735.00000000 .001000 0 481 278158 5 773721511220. 3395.313933619 XBC
1775.00000000 .000100 0 482 281346 5 791558530620. 3473.587937410 XMC
1778.20000000 3.5D-06 1 483 281559 5 792985399626. 3479.849451595 XLC
1825.00000000 .001000 0 484 285281 5 813855342420. 3571.432801075 XBC
1841.00000000 .000004 0 485 286529 5 820991543700. 3602.748517761 XBC
1868.30000000 .001000 1 486 288606 5 833164997646. 3656.169157104 XMC
1882.00000000 .000070 0 487 289702 5 839275385060. 3682.983305639 XBC
1900.00000000 .000500 0 488 291084 5 847301861400. 3718.205806965 XBC
2189.00000000 .000070 1 489 312402 5 976181099286. 4283.765205021 XBC
2250.00000000 .000300 0 490 316762 5 1003384814060. 4403.142979167 XBC
2373.00000000 .001000 0 491 325305 5 1058236683300. 4643.848857465 XBC
2457.00000000 .000100 1 492 330978 5 1095695553846. 4808.229223343 XBC
2463.00000000 .000100 1 493 331382 5 1098371492286. 4819.972015729 XMC
2467.00000000 .000100 1 494 331651 5 1100155053746. 4827.798799641 XBC
2470.00000000 .001000 0 495 331887 5 1101493126560. 4833.670650435 XBC
2472.10000000 .000100 0 496 332028 5 1102429248120. 4837.778622787 XBC
2517.50000000 .000100 0 497 335063 5 1122675490320. 4926.624993539 SBC
2574.10000000 .000100 1 498 338775 5 1147916273226. 5037.388854507 SBC
2626.60000000 .000004 1 499 342213 5 1171328675046. 5140.129250070 XBC
2643.80000000 .000350 0 500 343365 5 1178998665900. 5173.787389905 SBC
2975.80000000 .000100 0 501 364287 5 1327053826560. 5823.496287283 XMC
2982.60000000 .000100 0 502 364703 5 1330086429120. 5836.804225059 XMC
3416.00000000 .000100 0 503 390302 5 1523360415060. 6684.946415695 XMC
3417.40000000 .000100 0 504 390382 5 1523984963060. 6687.687113085 XMC
3556.15000000 .000035 0 505 398228 5 1585859382120. 6959.209972567 XMC
3556.90000000 .000700 0 506 398270 5 1586193911700. 6960.677985189 XMC
3559.90000000 .000100 0 507 398438 5 1587532382820. 6966.551583864 XMC
4414.00000000 .000800 0 508 443668 5 1968417378920. 8637.985188347 XMC
5278.30000000 .000100 1 509 485141 5 2353850629446. 10329.377849677 XMC
5325.00000000 .000300 0 510 487306 5 2374676249420. 10420.766697795 SMC
9890.80000000 .000070 0 511 664137 5 4410786189060. 19355.806435204 XMC
9894.40000000 .000100 0 512 664258 5 4412393548220. 19362.859992424 XMC
9912.10000000 .000070 0 513 664852 5 4420288467560. 19397.505183557 XMC
10255.30000000 .000700 0 514 676264 5 4573336739600. 20069.125298855 XMC
10577.40000000 .000700 0 515 686802 5 4716976740060. 20699.459195372 XMC
Type 6 Polyhedron III 8 IV 6
134.97660000 .000250 0 516 74216 6 60192629712. 264.142681053 SMC
139.56995000 .000150 1 517 75330 6 62240931540. 273.131222326 XMC
493.65800000 .000500 1 518 141859 6 220146288590. 966.065632459 XMC
493.74200000 .000100 1 519 141871 6 220183618688. 966.229447734 XMC
761.00000000 .000100 1 520 176163 6 339366763782. 1489.239584226 XMC
768.00000000 .000100 1 521 176972 6 342488636574. 1502.939265618 XMC
769.00000000 .000500 0 522 177146 6 342934201998. 1504.894535661 XMC
769.20000000 .000004 0 523 177169 6 343023728270. 1505.287402854 XMC
774.00000000 .000100 0 524 177721 6 345164134370. 1514.680124330 XMC
775.10000000 .000700 0 525 177847 6 345654276464. 1516.831009703 XMC
781.78000000 .000300 0 526 178612 6 348633930194. 1529.906592688 XMC
782.70000000 .000500 0 527 178717 6 349043690060. 1531.704737579 XMC
889.00000000 .000400 1 528 190412 6 396447933942. 1739.728280199 XMC
896.00000000 .000004 0 529 191215 6 399569850212. 1753.428152385 XMC
900.70000000 .000004 0 530 191716 6 401665828070. 1762.625909876 XMC
957.00000000 .000100 0 531 197617 6 426772988636. 1872.803397340 XMC
957.90000000 .000350 0 532 197710 6 427174309058. 1874.564507508 XMC
958.00000000 .001200 0 533 197720 6 427218059802. 1874.756498436 XMC
969.00000000 .000500 0 534 198852 6 432123796950. 1896.284292935 XMC
994.00000000 .000070 0 535 201401 6 443272833282. 1945.209491286 XMC
1019.36000000 .000070 0 536 203954 6 454582166388. 1994.838118276 XMC
1019.50000000 .000035 0 537 203968 6 454644373376. 1995.111100544 XMC
1019.52000000 .001200 0 538 203970 6 454654134588. 1995.153935568 XMC
1019.67000000 .000500 0 539 203985 6 454720615530. 1995.445673183 XMC
1115.52000000 .000070 0 540 213357 6 497464575684. 2183.018541953 XBC
1116.00000000 .000500 0 541 213403 6 497678957888. 2183.959313114 XBC
1197.41700000 .000070 1 542 221003 6 533986487154. 2343.287260217 XBC
1222.00000000 .000700 1 543 223261 6 544948670594. 2391.392493996 XMC
1231.80000000 .000100 1 544 224155 6 549319524514. 2410.573066077 XBC
1321.10000000 .000500 1 545 232141 6 589142327996. 2585.327053884 XBC
1381.90000000 .000070 1 546 237425 6 616256609664. 2704.312369676 XBC
1384.30000000 .000500 1 547 237631 6 617326247330. 2709.006249345 XBC
1385.30000000 .000100 1 548 237717 6 617772557262. 2710.964786505 XBC
1390.00000000 .000800 1 549 238120 6 619869109478. 2720.165064445 XBC
1403.00000000 .000100 0 550 239275 6 625665969230. 2745.603362853 XBC
1404.00000000 .000100 0 551 239360 6 626111792916. 2747.559766225 XMC
1420.00000000 .000800 0 552 240720 6 633246345486. 2778.868247894 XMC
1424.00000000 .000500 0 553 241059 6 635030531010. 2786.697770379 XMC
1426.00000000 .000100 0 554 241228 6 635922488138. 2790.611936421 XMC
1430.80000000 .000500 0 555 241634 6 638063702574. 2800.008205109 XMC
1446.00000000 .000100 0 556 242914 6 644841577892. 2829.751483762 XMC
1454.00000000 .000100 0 557 243585 6 648409272612. 2845.407560810 XMC
1518.00000000 .000100 0 558 248888 6 676950106806. 2970.653001981 XBC
1520.00000000 .000700 0 559 249052 6 677841973244. 2974.566770049 XBC
1526.00000000 .000100 0 560 249543 6 680517370056. 2986.307185614 XBC
1531.30000000 .000700 0 561 249976 6 682881071102. 2996.679789943 XBC
1577.80000000 .000030 0 562 253743 6 703617802806. 3087.678570604 XMC
1646.00000000 .000100 0 563 259169 6 734031020802. 3221.140573832 XBC
1652.00000000 .000100 0 564 259641 6 736707070392. 3232.883853976 XMC
1672.00000000 .001000 1 565 261168 6 745625518644. 3272.020586221 XBC
1699.00000000 .000100 1 566 263269 6 757666623302. 3324.860438582 XBC
1775.10000000 .000100 1 567 269102 6 791603185038. 3473.783893921 XLC
1778.40000000 .000100 0 568 269391 6 793074856386. 3480.242013750 XBC
1814.00000000 .000100 0 569 272074 6 808950696086. 3549.909793383 XBC
1822.00000000 .000100 1 570 272635 6 812518380146. 3565.565823653 XBC
1830.00000000 .000700 1 571 273233 6 816086462604. 3581.223602208 XBC
1856.60000000 .000100 0 572 275250 6 827948294010. 3633.276751651 XMC
1861.00000000 .000100 0 573 275576 6 829909948182. 3641.885057930 XMC
1863.00000000 .000100 0 574 275724 6 830801778498. 3645.798667484 XMC
2018.00000000 .000300 0 575 286965 6 899924689506. 3949.130007603 XMC
2019.00000000 .000100 0 576 287036 6 900370086048. 3951.084536543 XBC
2097.00000000 .001000 0 577 292528 6 935154837278. 4103.730092878 XBC
2123.00000000 .000100 0 578 294336 6 946748973228. 4154.608517180 XBC
2193.00000000 .000070 0 579 299149 6 977965506860. 4291.595701927 XMC
2425.00000000 .000100 0 580 314575 6 1081425341636. 4745.607401861 XMC
2452.20000000 .000100 0 581 316334 6 1093554786834. 4798.834918081 SBC
2453.00000000 .000375 1 582 316353 6 1093912251654. 4800.403577174 XMC
2466.00000000 .000100 0 583 317223 6 1099708896306. 4825.840931661 XMC
2469.00000000 .000100 1 584 317383 6 1101046863704. 4831.712319858 XMC
2535.30000000 .001000 1 585 321617 6 1130613391782. 4961.458802664 XMC
2535.90000000 .000100 1 586 321655 6 1130880758654. 4962.632085884 XMC
2976.30000000 .000070 0 587 348503 6 1327276650288. 5824.474102295 XMC
2980.40000000 .000100 0 588 348743 6 1329105096486. 5832.497853429 XMC
3096.87000000 .000500 0 589 355492 6 1381045373438. 6060.426822048 XMC
3097.50000000 .000100 0 590 355528 6 1381326018368. 6061.658373230 XMC
3505.00000000 .002000 0 591 378192 6 1563051098226. 6859.120621315 XMC
3509.40000000 .000100 0 592 378429 6 1565011496892. 6867.723418071 XMC
3553.40000000 .000300 0 593 380794 6 1584634070906. 6953.832952311 XMC
3557.00000000 .000500 0 594 380987 6 1586238816702. 6960.875041334 XMC
3764.00000000 .000100 0 595 391916 6 1678550571576. 7365.965740010 XMC
4417.00000000 .000100 0 596 424553 6 1969755477216. 8643.857150963 XMC
5279.10000000 .000100 0 597 464139 6 2354207012814. 10330.941763046 XMC
5280.60000000 .000035 0 598 464205 6 2354876005782. 10333.877497820 XMC
5368.60000000 .000500 0 599 468057 6 2394120230862. 10506.092516138 XMC
9872.80000000 .000200 0 600 634729 6 4402761234374. 19320.590611335 XMC
10355.30000000 .001000 0 601 650054 6 4617930659940. 20264.816328365 XMC
Type 7 Polyhedron III 4 VI 4
493.63600000 .000035 1 602 125330 7 220136158450. 966.021178473 XMC
493.69100000 .000100 1 603 125337 7 220160723914. 966.128978839 XMC
762.30000000 .000035 0 604 155826 7 339946573432. 1491.783956788 XMC
763.70000000 .000130 0 605 155969 7 340570789024. 1494.523195475 XMC
770.00000000 .000100 0 606 156611 7 343380267052. 1506.851998225 XMC
782.40000000 .000200 0 607 157867 7 348910065788. 1531.118355598 XMC
895.90000000 .000100 0 608 168930 7 399525193624. 1753.232186351 XMC
958.20000000 .000700 0 609 174705 7 427308164224. 1875.151902719 XMC
971.10000000 .000100 0 610 175877 7 433060530088. 1900.394949068 XMC
973.00000000 .000035 0 611 176049 7 433907970304. 1904.113762015 XMC
979.00000000 .000100 0 612 176591 7 436583810212. 1915.856122014 XMC
997.00000000 .000100 0 613 178207 7 444610782788. 1951.080800968 XMC
1019.38000000 .000100 0 614 180196 7 454590900572. 1994.876446403 XMC
1115.65000000 .000100 0 615 188513 7 497522755552. 2183.273852054 XBC
1234.35000000 .000500 0 616 198288 7 550456609252. 2415.562923020 XBC
1282.80000000 .001000 0 617 202142 7 572062264288. 2510.374790759 XMC
1295.00000000 .000200 0 618 203101 7 577503070232. 2534.250622003 XMC
1315.20000000 .001000 0 619 204679 7 586511768084. 2573.783395613 XBC
1317.00000000 .000100 0 620 204819 7 587314386124. 2577.305515879 XMC
1387.00000000 .001000 1 621 210153 7 618530789098. 2714.292127260 XBC
1420.10000000 .000100 0 622 212685 7 633291706744. 2779.067306223 XMC
1519.70000000 .000150 0 623 220017 7 677707804288. 2973.977997836 XBC
1533.60000000 .000500 0 624 221021 7 683907048472. 3001.182075596 XBC
1534.50000000 .000100 1 625 221049 7 684308219530. 3002.942530312 XBC
1553.00000000 .000500 1 626 222378 7 692558640898. 3039.147767239 XBC
1600.00000000 .000100 0 627 225755 7 713517640924. 3131.121925629 XBC
1665.00000000 .000200 0 628 230295 7 742504242484. 3258.323523023 XBC
1673.30000000 .000500 1 629 230833 7 746205345338. 3274.565033576 XBC
1680.00000000 .000200 0 630 231330 7 749193203224. 3287.676618772 XBC
1685.00000000 .000100 0 631 231674 7 751423035304. 3297.461767331 XBC
1691.10000000 .000070 1 632 232058 7 754143943138. 3309.401898434 XBC
1694.00000000 .000200 0 633 232292 7 755437277788. 3315.077425215 XMC
1700.00000000 .000100 1 634 232668 7 758112711718. 3326.818003665 XBC
1713.00000000 .000100 0 635 233591 7 763909844212. 3352.257498944 XMC
1767.00000000 .000200 1 636 237210 7 787991377570. 3457.934237367 XMC
1863.80000000 .000100 0 637 243656 7 831158859892. 3647.365643992 XMC
1913.00000000 .000300 0 638 246851 7 853099282732. 3743.646569749 XBC
1940.00000000 .000070 0 639 248587 7 865140432188. 3796.486618697 XMC
1956.00000000 .000100 0 640 249610 7 872275623944. 3827.797905299 XBC
1973.60000000 .000100 1 641 250698 7 880124209858. 3862.239771948 XMC
1975.00000000 .001000 1 642 250787 7 880749061414. 3864.981801430 XMC
2008.00000000 .000100 1 643 252874 7 895465057730. 3929.559852595 XMC
2112.40000000 .000035 1 644 259366 7 942021617738. 4133.863513026 SMC
2115.00000000 .000200 0 645 259557 7 943181341288. 4138.952715628 XBC
2147.00000000 .000100 1 646 261482 7 957451248514. 4201.573198752 XMC
2299.00000000 .000100 0 647 270612 7 1025235752188. 4499.031220108 XBC
3513.00000000 .000200 0 648 334516 7 1566618042812. 6874.773406559 XMC
3526.14000000 .001000 0 649 335141 7 1572477550312. 6900.486621418 SMC
3553.00000000 .000004 0 650 336415 7 1584455440964. 6953.049072424 XMC
5278.00000000 .000700 0 651 410027 7 2353715710588. 10328.785786678 XMC
5278.20000000 .000100 1 652 410015 7 2353805822590. 10329.181224224 XMC
10232.30000000 .000500 0 653 570906 7 4563079244392. 20024.112441000 XMC
Type 8 Polyhedron III 32 IV 6
549.30000000 .000500 0 654 103362 8 244959312984. 1074.952365267 XMC
767.00000000 .000300 0 655 122139 8 342042273786. 1500.980496511 XMC
782.50000000 .000100 0 656 123366 8 348949186002. 1531.290026420 XMC
783.30000000 .000100 0 657 123430 8 349311409628. 1532.879568531 XMC
784.10000000 .000350 0 658 123493 8 349668272810. 1534.445587462 XMC
886.60000000 .000900 1 659 131279 8 395377477026. 1735.030805423 XMC
897.60000000 .000100 0 660 132129 8 400283555022. 1756.560095662 XMC
1021.00000000 .000100 0 661 140919 8 455313592092. 1998.047825965 XMC
1115.74000000 .000100 0 662 147312 8 497562563268. 2183.448539833 XBC
1189.38000000 .000200 1 663 152063 8 530401996866. 2327.557479355 XBC
1197.24000000 .000035 1 664 152565 8 533907654108. 2342.941317994 XBC
1233.10000000 .000070 0 665 154866 8 549899204994. 2413.116871803 XBC
1273.30000000 .000350 0 666 157370 8 567825980478. 2491.784751270 XMC
1279.00000000 .000300 0 667 157722 8 570368575908. 2502.942395934 XMC
1378.00000000 .000100 1 668 163682 8 614517019392. 2696.678544064 XBC
1384.10000000 .000350 1 669 164044 8 617237149790. 2708.615263552 XBC
1419.00000000 .000700 0 670 166131 8 632808684348. 2776.947664146 XMC
1421.00000000 .000150 0 671 166247 8 633692756334. 2780.827227902 XMC
1423.00000000 .000004 0 672 166364 8 634584919860. 2784.742299678 XMC
1428.00000000 .000100 0 673 166656 8 636814330596. 2794.525599258 XMC
1517.30000000 .000700 0 674 171788 8 676638322890. 2969.284803916 XBC
1529.00000000 .000100 0 675 172449 8 681855160866. 2992.177798892 XMC
1532.30000000 .000500 0 676 172635 8 683327056950. 2998.636904928 XBC
1547.00000000 .000700 0 677 173461 8 689881896800. 3027.401439392 XBC
1638.00000000 .000500 0 678 178490 8 730463995014. 3205.487432251 XMC
1671.43000000 .000100 1 679 180273 8 745358659296. 3270.849530163 XBC
1674.20000000 .000100 1 680 180424 8 746607061664. 3276.327881086 XBC
1690.00000000 .000100 0 681 181301 8 753653124876. 3307.248045840 XBC
1694.00000000 .000100 1 682 181488 8 755436568038. 3315.074310626 XBC
1771.00000000 .000100 0 683 185595 8 789775123422. 3465.761830444 XMC
1783.00000000 .000100 1 684 186196 8 795126260018. 3489.244166636 XLC
2079.00000000 .000500 0 685 201087 8 927126601704. 4068.499871524 XMC
2268.00000000 .000035 1 686 210005 8 1011411306990. 4438.365553295 XBC
2452.40000000 .000150 0 687 218400 8 1093644232242. 4799.227430420 SBC
2464.40000000 .000100 1 688 218911 8 1098995719826. 4822.711306848 XBC
2469.00000000 .000300 0 689 219138 8 1101047603262. 4831.715565253 XBC
2472.00000000 .000100 0 690 219271 8 1102385070008. 4837.584756445 XBC
2515.90000000 .000100 1 691 221187 8 1121961942798. 4923.493740487 SBC
2568.60000000 .000100 1 692 223492 8 1145463584756. 5026.625747605 XMC
2647.40000000 .000100 1 693 226895 8 1180604313114. 5180.833434611 SBC
2710.00000000 .000100 0 694 229584 8 1208520197340. 5303.336414439 SBC
2790.00000000 .000100 0 695 232948 8 1244196358160. 5459.893734061 SBC
2814.90000000 .000200 1 696 233964 8 1255300742784. 5508.622987793 SBX
2974.40000000 .000100 0 697 240523 8 1326429634652. 5820.757152528 XMC
3414.80000000 .000350 0 698 257715 8 1522825187364. 6682.597681651 XMC
3686.02000000 .000100 0 699 267754 8 1643775686498. 7213.363479205 XMC
5279.60000000 .000700 0 700 320448 8 2354429684820. 10331.918912257 XMC
Type 9 Polyhedron III 8 IV 18
493.64000000 .000100 1 701 94196 9 220138012266. 966.029313554 XMC
493.67000000 .000500 1 702 94199 9 220151233218. 966.087330918 XMC
759.00000000 .000500 0 703 116862 9 338474610204. 1485.324556105 XMC
773.50000000 .000035 0 704 117973 9 344941208432. 1513.701860792 XMC
775.90000000 .000004 0 705 118156 9 346011528734. 1518.398736066 XMC
776.40000000 .000035 0 706 118194 9 346234384194. 1519.376690326 XMC
781.80000000 .001300 0 707 118604 9 348641867256. 1529.941422813 XMC
783.50000000 .000070 0 708 118733 9 349400776782. 1533.271737469 XMC
897.90000000 .000400 0 709 127106 9 400416897708. 1757.145241963 XMC
1019.50400000 .000080 0 710 135440 9 454646293272. 1995.119525603 XMC
1020.30000000 .000430 0 711 135495 9 455016816936. 1996.745490684 XMC
1189.61000000 .000070 1 712 146272 9 530505070550. 2328.009796514 XBC
1192.55000000 .000100 0 713 146484 9 531815963904. 2333.762375970 SBC
1310.00000000 .000500 1 714 153498 9 584192233254. 2563.604605424 XMC
1321.30000000 .000070 1 715 154159 9 589231742966. 2585.719432652 XBC
1387.60000000 .001100 1 716 157981 9 618798947174. 2715.468882512 XBC
1398.00000000 .000100 0 717 158601 9 623436044232. 2735.817806543 XMC
1412.00000000 .000100 0 718 159393 9 629679433692. 2763.215606551 XMC
1459.00000000 .001000 0 719 162024 9 650638417056. 2855.189691824 XMC
1524.00000000 .000150 0 720 165594 9 679625530842. 2982.393537013 XBC
1527.00000000 .000004 0 721 165757 9 680963505416. 2988.264956701 XBC
1542.00000000 .000100 0 722 166569 9 687652733850. 3017.619227169 XBC
1544.70000000 .000500 0 723 166715 9 688856978574. 3022.903801569 XMC
1583.00000000 3.5D-06 0 724 168769 9 705936358070. 3097.853062174 XBC
1672.10000000 .000200 1 725 173427 9 745670819562. 3272.219379760 XBC
1675.00000000 .000100 0 726 173604 9 746964126660. 3277.894785635 XBC
1712.80000000 .000100 0 727 175552 9 763820363276. 3351.864830698 XBC
1864.70000000 .000150 0 728 183171 9 831560366640. 3649.127571813 XMC
1869.00000000 .000700 0 729 183382 9 833478453350. 3657.544691459 XMC
1872.00000000 .000100 0 730 183529 9 834816087962. 3663.414619295 XBC
1874.00000000 .000100 1 731 183602 9 835707239394. 3667.325249709 XMC
1967.00000000 .000250 1 732 188104 9 877180692104. 3849.322764086 XMC
1969.30000000 .000100 1 733 188214 9 878206590456. 3853.824702985 XMC
1972.40000000 .001000 1 734 188362 9 879588267866. 3859.887903367 XMC
2110.30000000 .000035 1 735 194837 9 941085154596. 4129.754041713 SMC
2121.00000000 .000100 0 736 195354 9 945857106414. 4150.694747462 XBC
2127.00000000 .000200 0 737 195630 9 948532715034. 4162.436092503 XBC
2284.70000000 .000100 1 738 202730 9 1018858875798. 4471.047640815 XBC
2625.60000000 .001470 1 739 217332 9 1170881396010. 5138.166460202 SBC
2765.00000000 .000100 1 740 223028 9 1233047623824. 5410.969860956 SBC
2790.00000000 .000300 1 741 224034 9 1244195843262. 5459.891474539 SBC
2980.00000000 .000300 0 742 231558 9 1328926553988. 5831.714357271 XMC
5279.50000000 .000100 0 743 308211 9 2354385489936. 10331.724972315 XMC
9459.97000000 .000100 0 744 412569 9 4218659786898. 18512.700174337 XMC
10868.00000000 .000100 0 745 442208 9 4846569436392. 21268.149455589 XMC
Type 10 Polyhedron IV 6 VI 8
497.74200000 .000900 0 746 84716 10 221966978492. 974.055346721 XMC
552.00000000 .000200 0 747 89214 10 246163420466. 1080.236337410 XMC
763.00000000 .000100 1 748 104853 10 340258874720. 1493.154425230 XMC
783.40000000 .000200 0 749 106281 10 349355906942. 1533.074835624 XMC
890.00000000 .000100 1 750 113249 10 396894340322. 1741.687240600 XMC
984.45000000 .000500 1 751 119110 10 439014413426. 1926.522312420 XMC
1019.90000000 .000140 0 752 121267 10 454822862528. 1995.894362604 XMC
1115.39000000 .000100 0 753 126817 10 497406524420. 2182.763796205 XBC
1115.69000000 .000150 0 754 126834 10 497540170826. 2183.350275316 XBC
1239.00000000 .000300 1 755 133632 10 552530610434. 2424.664240496 XMC
1261.00000000 .000500 0 756 134841 10 562341518036. 2467.717342677 XMC
1283.00000000 .000300 0 757 136012 10 572151688412. 2510.767209697 XMC
1284.00000000 .000440 0 758 136065 10 572597514086. 2512.723621793 XMC
1287.00000000 .000100 0 759 136224 10 573936032888. 2518.597429710 XMC
1306.00000000 .000300 1 760 137199 10 582409134230. 2555.779850814 XMC
1311.30000000 .000100 0 761 137504 10 584772409766. 2566.150587882 XMC
1313.40000000 .000500 0 762 137614 10 585708376910. 2570.257882612 XBC
1375.00000000 .000070 1 763 140778 10 613179308462. 2690.808281322 XBC
1416.00000000 .000700 0 764 142888 10 631462728776. 2771.041221528 XMC
1423.00000000 .000130 1 765 143215 10 634584476984. 2784.740356210 XMC
1430.00000000 .000100 1 766 143567 10 637706209202. 2798.439420722 XMC
1496.00000000 .000200 0 767 146869 10 667139293010. 2927.600311447 XMC
1692.00000000 .001000 0 768 156194 10 754544870408. 3311.161283337 XBC
1787.00000000 .000100 0 769 160519 10 796909824092. 3497.070962019 XBC
1817.00000000 .000500 1 770 161838 10 810288007052. 3555.778300967 XBC
1870.00000000 3.5D-06 1 771 164182 10 833923476290. 3659.497580925 XMC
2106.60000000 .000004 1 772 174262 10 939435327158. 4122.514121397 XMC
2214.00000000 .000035 1 773 178650 10 987330323276. 4332.691226869 XBC
2452.50000000 .000150 0 774 188048 10 1093688397074. 4799.421238485 SBC
2465.10000000 .000100 1 775 188511 10 1099307810804. 4824.080852390 XBC
2471.00000000 .000100 0 776 188756 10 1101938753564. 4835.626190709 XBC
2500.00000000 .000100 1 777 189841 10 1114871439152. 4892.378558246 XBC
2626.40000000 .000200 1 778 194582 10 1171239193568. 5139.736579446 SBC
3414.10000000 .001000 0 779 221872 10 1522511963810. 6681.223166038 XMC
3683.00000000 .000100 0 780 230444 10 1642428435404. 7207.451351463 XMC
5278.60000000 .000100 1 781 275869 10 2353984267160. 10329.964290646 XMC
5369.90000000 .000500 0 782 278258 10 2394698514416. 10508.630191749 XMC
5383.30000000 .000800 0 783 278605 10 2400675355166. 10534.858298869 XMC
Type 77 Two Structure Types Within Ratio Range
893.00000000 .000100 1 784 446096 72 398232053850. 1747.557514742 XMC
893.00000000 .000100 1 785 190840 76 398232053420. 1747.557512856 XMC
957.40000000 .000100 0 786 174632 77 426951140788. 1873.585180546 XMC
957.40000000 .000100 0 787 326707 73 426951162224. 1873.585274614 XMC
10231.20000000 .001000 0 788 1510395 72 4562589132840. 20021.961689654 XMC
10231.20000000 .001000 0 789 646147 76 4562589050198. 20021.961326997 XMC
10268.50000000 .000500 0 790 812991 74 4579222648626. 20094.954371251 XMC
10268.50000000 .000500 0 791 571915 77 4579222747964. 20094.954807175 XMC
Type 88 Many Structure Types Within Ratio Range
1445.00000000 .000100 0 792 161245 89 644395584878. 2827.794337330 XMC
1445.00000000 .000100 0 793 242830 86 644395672838. 2827.794723324 XMC
1445.00000000 .000100 0 794 253849 85 644395686500. 2827.794783277 XMC
2040.00000000 .000100 0 795 288525 86 909735059976. 3992.180752694 XBC
2040.00000000 .000100 0 796 199192 88 909735068942. 3992.180792039 XBC
2040.00000000 .000100 0 797 171506 80 909735146270. 3992.181131377 XBC
2976.60000000 .000100 0 798 240612 88 1327410335442. 5825.060751444 XMC
2976.60000000 .000100 0 799 576066 83 1327410449688. 5825.061252788 XMC
2976.60000000 .000100 0 800 307920 87 1327410480484. 5825.061387930 XMC
2976.60000000 .000100 0 801 364336 85 1327410852320. 5825.063019654 XMC
Type 99 Zero Structure Types Within Ratio Range
938.27199800 .000038 1 802 LO 99 418421016631. 1836.152526827 XBC
938.27199800 .000038 1 803 HI 99 418421084914. 1836.152826472 XBC
Type Total
01 01
02 204
03 140
04 90
05 80
06 86
07 52
08 47
09 45
10 38 783 No. Matched
77 04
88 03
99 01 791 Grand Total
Blogs about soaring and aviation Roger Worden Soaring 3 August 11th 05 06:56 AM
wanna do a good thing? Sporkman Home Built 1 June 20th 04 07:43 PM
wanna do a good thing? Richard Hertz Instrument Flight Rules 0 June 20th 04 04:02 AM
150HP Super Yankee FS I forgot to post one last thing! Bill Berle Home Built 0 October 20th 03 10:46 AM
SUV thing Fastglasair Home Built 4 July 12th 03 06:32 AM
