ELT location for V2C
Old October 3rd 05, 05:30 PM
Default ELT location for V2C
Jumping into the ELT fray ...
I'm trying to figure out the best place to install one in my V2C.
The ELT is an ACK Technologies model E-01, a yellow brick
2.75"x2.75"x7.75". The glider's previous owner had tried it where the
transponder battery currently lives (he removed the ELT to make room
for the XPDR). The cockpit annunciator is still installed in the small
panel just above the tow release and pedal adjustment handles.
I'm thinking it would go best in the turtleneck above and just aft of
the wing spars. This would require a cable extension for the
annunciator. But I don't know what it would take to secure the unit to
the underside of the fuse top.
Advance thanks
~ted/2NO
Old October 3rd 05, 07:33 PM
Armando Pucci
Dear ~ted/2NO
On mine V2cM the ACK ELT was originally installed by factory on the left
side of baggage compartment just BEFORE of
the wing spars using original ACK support with a quick release latch; The
remote control is installed on the panel.
Sds VoLo.
Armando R. Pucci
Ventus 2cM (AR)
Old October 10th 05, 03:52 PM
01-- Zero One
Hmmm?? In front of the wing spar sounds to me like you now have a nice
forward moving projectile in the event of a forward moving collision.
I also have one of these units and I had it installed behind the spar
because 1) that was where I could fit it in and 2) there was a natural
barrier (the spar) to keep it from hitting me in a "sudden stop".
Larry
"Armando Pucci" wrote in message
Dear ~ted/2NO
Sds VoLo.
Armando R. Pucci
Ventus 2cM (AR)
Old October 11th 05, 04:46 AM
Ted Wagner
Larry, how did you mount it? I mean, how specifically is it attached to the fuse?
"01-- Zero One" wrote in message ...
Hmmm?? In front of the wing spar sounds to me like you now have a nice forward moving projectile in the event of a forward moving collision.
I also have one of these units and I had it installed behind the spar because 1) that was where I could fit it in and 2) there was a natural barrier (the spar) to keep it from hitting me in a "sudden stop".
Larry
"Armando Pucci" wrote in message :
Dear ~ted/2NO
Sds VoLo.
Armando R. Pucci
Ventus 2cM (AR)
Old October 11th 05, 05:13 PM
01-- Zero One
Ted,
I hope I did not mislead you. I fly an LS-3a, not a V2C. I was
responding generally about the dangers of flying projectiles in the
cockpit.
I mounted it ..er.. uh.. . I mean, it was mounted by the A&P by
screwing the retaining plate and straps to the baggage compartment tray
with a backing plate below the tray for strength. In the LS-3a, there
was just enough room to get it in next to the glider batteries.
Larry
"Ted Wagner" wrote in message
news:1128998777.1f71e5987c5709d715a54423cda1bf20@ teranews:
the fuse?
barrier (the spar) to keep it from hitting me in a sudden stop.
Larry
Dear ~ted/2NO
left
The
Sds VoLo.
Armando R. Pucci
Ventus 2cM (AR)
P-3 location lists Marco P.J. Borst Naval Aviation 5 January 2nd 05 04:52 PM
P-3 Orion Aircraft Location Reports - updated Marco P.J. Borst Naval Aviation 0 October 24th 04 03:49 PM
FS2004/FS9, Set location to non-airport? Squirrel Instrument Flight Rules 8 September 24th 04 01:43 AM
mysterious helipad location (Dallas, TX) Kyler Laird General Aviation 5 February 20th 04 04:57 PM
lookup navaid location Dan Jacobson General Aviation 3 November 21st 03 10:35 PM
