Source for PA28-180 split master switch
Old October 4th 05, 04:03 AM
Mike Noel
Default Source for PA28-180 split master switch
I'm not having any luck locating a new master switch for my '74 Archer, PN
99377-05 / 8911k619. I've got an intermittently bouncing amp meter and
suspect the old master is the culprit.
Old October 4th 05, 10:58 PM
Roy Page
I understand that http://www.piperpartsplus.com/ may be able to help you.
Toll Free 866-897-2787
Main 901-259-6136
Fax 901-259-6070
Check the part number, I think Piper part number should be 587-829
Roy
N5804F
"Mike Noel" wrote in message
Old October 4th 05, 11:40 PM
Ross Richardson
That was the problem on my Cessna. I came across it quite by accident. I
had tried everything else to solve. That year Cessna used a single throw
- double pole pull switch. My ammeter started swinging and when I went
to touch the master it stopped. I found that I could start and stop the
wild swinging by slight rotational pressure on the switch.
Regards, Ross
C-172F 180HP
KSWI
Old October 5th 05, 03:29 AM
George Patterson
Get the number off of it and check with Maule Air. They use a lot of the same
parts, and they use a split master switch. I always found their prices to be
very reasonable for aircraft parts.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Master Switch Lakeview Bill Piloting 23 July 20th 05 02:46 AM
Of clocks and learning curves... Jay Honeck Owning 40 June 16th 04 06:17 AM
