Sudden Flat Tire
Old October 13th 05, 07:54 PM
Kevin Kubiak
Default Sudden Flat Tire
Strange thing happened to me earlier this week (monday).
I flew from home base at KUGN to KDBQ with a friend
for a quick stop and then we were planning to fly up the Mississippi
to look for some fall colors.
Had a nice clear day with light winds. So we land at DBQ, I taxi over to the
FBO for a quick pit stop. Got back in the plane, got ATIS, contacted ground and
given taxi instruction to 36. So I'm # 2 in line, just finish mag check and
now I'm # 1. Start to move forward and seemed like the pedals were hare to
steer. I quickly think I got a flat nosewheel, and shut down the engine, worried
that I might strike the prop. Anyway, contact ground told them on problem and
plane behind me says yep it is flat.
FBO sends a truck to fill the tire, but the air rushed out almost as fast as it
entered. SO we now need a tow back to FBO. 2.5 hrs later I have new tire and
tube and we are off back to KUGN. Luckily I take the old tire & tube back.
Since the plane is owned by the club I'm a member in.
The general manager said I will be reimbursed for the repair, but was curious
about the flat. I was too since the tire looked to be relatively new.
In fact it was only replaced 2 weeks prior. The problem apparently was that
some of the steel cord must have popped up through the tires sidewall and
punctured the tub. If you rub your hand over the inside you can feel the steel
wire protruding through the sidewall.
Does this kind of thing happen frequently. Did I over react by shutting down
the engine, but I was really did not want to add a prop strike
to ruin my day?
Could side load or bad landings, bouncing on the nose cause such a failure?
My landing just prior to the this occurring was fine, mains first, then slowly
down on the nose. Just curious. Also, what would happen if the tire went flat
during flight? I guess I would know the minute the nose settled on the runway.
If that happened, all I could do is hold the nose off by pulling back on the yolk.
Kevin Kubiak PP-ASEL
Old October 13th 05, 08:05 PM
Seth Masia
I can't conceive of an operational situation that would cause a steel cord
to come adrift from inside the molded rubber. This wouldn't be an issue with
the tubeless tires on your car, but I'd hate to have it happen in the air
with an aviation tire -- bad news to land on a flat you didn't know about .
.. . . Sounds like a manufacturing defect to me. Someone should have a
heart-to-heart with the tire manufacturer.
Seth
"Kevin Kubiak" wrote in message
ground and
and
to steer. I quickly think I got a flat nosewheel, and shut down the
engine, worried
and plane behind me says yep it is flat.
as it
tire and tube and we are off back to KUGN. Luckily I take the old tire &
tube back. Since the plane is owned by the club I'm a member in.
curious about the flat. I was too since the tire looked to be relatively
new.
that
steel
down the engine, but I was really did not want to add a prop strike
to ruin my day?
failure?
slowly
flat
runway.
the yolk.
Old October 13th 05, 08:20 PM
NW_PILOT
ground and
and
to
worried
and
as it
tire and
back.
curious
that
steel
down
to ruin my day?
failure?
slowly
flat
runway.
the yolk.
Tire wasn't made by firestone was it?
Steven Rhine
CP-ASEL-IA
Old October 13th 05, 08:25 PM
Kevin Kubiak
Steven Rhine
CP-ASEL-IA
Don't really know. Funny now that you mention it
I had a problem with Firestone Tires on my
car 25 yrs ago. The same thing happened. The
steel belts shifted and started wearing through the sidewall.
I got lucky then too, because it was caught during
a routine oil change before I had a blowout.
Kevin Kubiak - PP-ASEL
Old October 13th 05, 08:35 PM
Skylune
Thats strange. My car has run flat tires (making blow-outs impossible).
Aren't the same available for planes?
Old October 13th 05, 08:39 PM
Jose
Did I over react by shutting down the engine, but I was really
to ruin my day?
You did not overreact at all. Something's amiss, you need to check it
out before flight. You're not going to get out of the plane to check it
with the engine running, are you?
sidewall and punctured the tub.
You were flying in a bathtub? I hope you didn't have water damage on
the floor.
Yep. Easy over or you'll be scrambled.
Jose
Money: what you need when you run out of brains.
NW_PILOT
Steven Rhine
CP-ASEL-IA
That was meant to me a funny as for all the Firestone tire recalls!
Old October 13th 05, 09:03 PM
Peter Duniho
to ruin my day?
Personally, I think it's a great idea to shut down the engine before doing
any service on the nosewheel.
Seriously though, in this situation, obviously if the prop hadn't hit yet,
it wasn't going to.
In any case, I agree that you're probably dealing with a manufacturing
defect. Tires should be able to take LOTS of abuse, and a botched landing
that actually damages a tire would damage plenty else on the airplane as
well.
You did the right thing, you got it fixed, AND you've got an FBO who handles
off-site repair reimbursement properly. What more could you ask?
(I'll skip the egg joke, since Jose already got that one... ).
Pete
Old October 13th 05, 09:35 PM
RK Henry
On Thu, 13 Oct 2005 12:54:18 -0500, Kevin Kubiak
I didn't know anyone made steel cord tires for aircraft, at least not
for aircraft that I'm likely to fly. All the tires I've seen are nylon
bias-ply tires. The only steel is the tire bead.
Could the steel cord be foreign object damage? In that case, lucky you
picked it up in the tire and not in the prop.
RK Henry
Old October 13th 05, 10:00 PM
Dan Luke
as it
entered.
You would've taken off if it had held air?
Blanik tire problem Greg Arnold Soaring 5 September 30th 05 07:02 PM
Tire question Jay Honeck Owning 30 February 8th 05 08:55 PM
Flat Spin JJ Sinclair Soaring 34 February 10th 04 06:57 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 04:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 04:51 AM
