IFR Approach questions
Old November 5th 05, 03:17 PM
Roy Smith
Default IFR Approach questions
A Lieberman wrote:
When an airport has multiple approaches, like GPS, ILS, VOR and so on, and
lets say ceilings are above the GPS minimums, will Center automatically set
you up for the most precise approach available such as an ILS, or do you
have to request it.
For the most part, if there's an ILS at an airport that makes sense for the
prevailing wind direction, they'll be using that in preference to any other
type of approach. If the airport has an ATIS, they'll be advertising which
approach is in use there.
If you want to use some other approach, it's best to tell the first
controller you check in with from the approach facility that owns the
airport (if center is running the approaches, tell the guy who's on the
frequency listed on the approach plate as the approach control frequency).
Or, just tell whoever you're talking to when you're 20 miles out.
If you want to use some other approach which has roughly the same FAC as
the one being used by default (say, the GPS-22 instead of the ILS-22),
that's a no brainer. If you want to use some approach running differently
from the major traffic flow, you may have to wait until they can work you
in if it's busy.
If you should need to request a particular approach, when do you request
it? Especially at uncontrolled airports such as PIB (Hattiesburg/Laurel
MS). Can the approach be requested at the time I file with FSS?
In theory, you could tell FSS to put the approach name in the remarks box
on the flight plan, but I'm not sure it's worth the effort. It's easy
enough to just request what you want on the air. It's also easier to
predict what the weather is when you're 20 miles out then when you're on
the phone with FSS a couple of hours before.
Is it assumed you will be provided vectors by center or should one assume
that full procedure approaches are in order? I know you can request full
procedures, but what is the "default" or "expected" from ATC's point of
view?
If they have radar coverage in the area, ATC tends to prefer to give
vectors. If you want the full procedure, just ask for it.
Old November 7th 05, 02:41 AM
At my home airport (Ottawa, ON - CYOW, with two ILS approaches and
steady airline traffic) the preferred runway is 25, which has only a
LOC(BC) and NDB approach -- the assumption is that pilots will take the
visual approach on a good day.
Many airports around here have ILS approaches on east-facing runways.
The prevailing wind is from the west, but the lowest weather often
comes with an east wind.
All the best,
David
Old November 7th 05, 03:11 AM
Roy Smith
I see I wasn't careful enough in what I wrote. The ILS is generally used
in preference to any other instrument approach (that makes sense for the
wind direction). If the weather is good enough to fly a visual, that's
generally preferable to an ILS because it saves time.
Of course, there's always exceptions. Here in New York, LaGuardia has a
number of ILS's, including an ILS-22. The most common approach, however,
is the LDA-A, CTL 22. They run it in preference to the ILS-22 for noise
abatement purposes when the weather allows.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
More dumb CNX-80 questions -- unloading an approach? Roy Smith Instrument Flight Rules 2 September 17th 04 12:30 PM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 05:03 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
