Why does a prop ice up so apparently readily?
Old November 8th 05, 09:53 PM
The Visitor
Default Why does a prop ice up so apparently readily?
Were they the wide cord butcher props? Perhaps they spin slower?
Mine are electrically heated but only the inboard third or so. (seneca)
Peter wrote:
The other day I was talking to a commercial pilot of a big twin
passenger turboprop. He has been iced up a few times and recently was
down to 200fpm climbing flat out through FL150; looking out of the
window he saw a bit of ice on the wings but enough on the prop for it
to be visible while the prop was rotating.
He has rubber boots, and the props are electrically heated.
Now, I know a bit about mach heating and I can work out the
temperature rise over SAT (i.e. the TAT) using the Jepp CR-5 circular
slide rule. At 200kt IAS at FL150 his airframe temperature should be
SAT+9C. At 300kt TAS the TAT should be SAT+12C which nearly puts him
out of the stratiform cloud icing range of 0C to -15C or so.
So he can get ice on the airframe especially in slow flight, and
especially if there are local mach numbers where the airflow slows
down.
What puzzles me is the prop. Assuming a SOP of max revs if icing is
likely, much of the prop is going at between mach 0.5 and mach 0.8,
with a temp rise of 15C to 30C, so even on a slow piston aircraft only
the innermost part should ever ice up.
Is this true?
I haven't been able to test this myself because I have a TKS de-iced
prop (TB20) and always have the deicing on if in IMC below 0C. I've
had up to 1cm of ice on the wings but never noticed any performance
drop so presumably the prop was doing OK.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Why does a prop ice up so apparently readily? Brian Whatcott General Aviation 2 November 9th 05 01:02 AM
Why does a prop ice up so apparently readily? Brian Whatcott Piloting 2 November 9th 05 01:02 AM
Why does a prop ice up so apparently readily? Mike Rapoport General Aviation 3 November 8th 05 03:52 PM
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 03:52 PM
Why does a prop ice up so apparently readily? Mike Rapoport Instrument Flight Rules 2 November 8th 05 03:52 PM
