Stormscope
Old November 19th 05, 01:27 AM posted to rec.aviation.ifr
Default Stormscope
Does anyone know how a stormscope is able to sense the distance to the
lightning ...
Old November 19th 05, 01:38 AM posted to rec.aviation.ifr
Default Stormscope
Roland wrote On 11/18/05 16:27,:
lightning ...
It counts the difference between the flash and the cracking sound.
No, kidding, sorry. Lightning generates radio frequency energy, just like
any electrical current does. So the location solution can be found
just like they find a radio transmitter, by using directional antennas
and paralax.
Old November 19th 05, 02:15 AM posted to rec.aviation.ifr
Default Stormscope
"Roland" wrote in message
lightning ...
You will probably find some useful information about this subject by
Googling for lightning sferics.
Jon
Old November 19th 05, 02:34 AM posted to rec.aviation.ifr
Default Stormscope
lightning ...
It uses an algorithm based on the intensity of the strike signal. A strong
strike signal will therefore appear to be closer than it really is, and a
weak one further away.
Default Stormscope
lightning ...
The booklet that came with ours used the term "pseudo range." Ryan
(the inventor) measured the strength (amplitude) of a number of
lightning strokes, and calculated the average.
The stormscope assumes that every lightning strike is of "average"
intensity, and it calculates the distance from the signal strength.
A strike that is stronger than average will seem to be closer than it
actually is; a weak one will seem to be farther away. Hence "pseudo."
But it's good enough to provide safe guidance to the pilot.
vince norris
Old November 19th 05, 03:22 AM posted to rec.aviation.ifr
Default Stormscope
lightning ...
I don't know for sure as they don't publish their algorithms, but most
folks use dispersion of the signal to estimate distance as different
frequency components of the signal travel at slightly different speeds
through the air. The farther they travel the more dispersed the signal.
Matt
Old November 19th 05, 03:32 PM posted to rec.aviation.ifr
Default Stormscope
lightning ...
The explanation I got seems better: The atmosphere attenuates some
radio frequencies more than other (I believe high frequencies are
attenuated more than low, but it may be way more complex.) A lighting
flash is an impulse and thus, has all frequencies present at the same
level. The distance sensor can measure the level of 2 frequencies and
derive the distance. In practice I've heard that 6 frequencies are used
but that implies 36 amplitude ratios are being used.
Take your pick.
Old November 21st 05, 05:07 PM posted to rec.aviation.ifr
Default Stormscope
Ding ding ding ding ding ding! Finally someone responded with the correct answer.
Dave
Old December 4th 05, 08:21 PM posted to rec.aviation.ifr
Default Stormscope
Dong, dong, dong, dong, dong...
Perhaps the current Stormscope uses this method; Ryan's original work used a
spot frequency (50 kHz) and amplitude discrimination. And Ryan didn't
"invent" it. The seminal work was done by Smythe Research Associates in San
Diego on a field trip to the South Pacific.
Strikefinder was the first to use multiple frequencies across a rather broad
bandwidth.
"Dave Butler" wrote in message
news:1132589727.740244@sj-nntpcache-3...
answer.
Dave
Old December 4th 05, 08:42 PM posted to rec.aviation.ifr
Default Stormscope
Just for clarity, using multiple frequencies is not the key to its
working. A pair (2) will suffice. Using multiple frequency (ratios)
will probably increase the accuracy, however.
Hats off to whoever invented it. Very clever.
bandwidth.
answer.
Dave
Pinout for StormScope WX-900 epotenziani Products 0 August 22nd 05 09:32 PM
Shops for Stormscope Install - Madison WI Jim Burns Owning 3 February 6th 05 07:48 PM
ADF vs. StormScope antenna David Megginson Instrument Flight Rules 0 September 6th 03 11:03 PM
WX1000 Stormscope battery D. J. Gooding Owning 2 August 9th 03 03:25 AM
FS: WX-1000E Stormscope Lenny Sawyer Owning 0 July 1st 03 03:29 AM
