Cardinal 177A 1968 advice
Old November 21st 05, 11:54 PM posted to rec.aviation.owning
Default Cardinal 177A 1968 advice
Hello there,
I am considering the purchase of a Cardinal 177A with low frame and
engine times, nice gps and slaved HSI. It has had 2 accidents, one in
2003 requiring major work to everything in front of and including the
firewall. I have flown the plane and it feels heavier on the landings
with more stick pressure required than in the 172`s I have flown but
otherwise OK. I have heard that this early model Cardinal has tail
stall issues and that one should not fill her up to the max permitted
gross weight on warm days. I would be flying alone 95% of the time and
in Canada where we only have cold days.
Any thoughts by owners on this plane?
Tien, CP
Old November 22nd 05, 02:44 AM posted to rec.aviation.owning
The tail stall problem with early Cardinal went away when the slots
were put in the stabilator back in 1968. See this thread
http://groups.google.com/group/rec.a...e?dmode=source
If you are interested in purchasing a Cardinal, I highly recommend
you checking out this website
http://www.cardinalflyers.com/
You may want to consider joining the club for $34/yr. There is a
wealth of information at the site for members. I joined CFO before
purchasing our Cardinal. We have owned our C177B sinc March 2003 and
have been very happy with our decision.
The main drawback of the 177A is the 150HP engine. It may not be an
issue if you don't live in high altitude areas and don't plan to fly
with max load. One advantage of the 177B is the autogas STC which is
worth consideration.
Hai Longworth
Old November 22nd 05, 05:10 AM posted to rec.aviation.owning
I have owned a 177A for eight years and love it. It has several
qualities hard to find anywhere, even in later year Cardinals. If you
are looking at a 177A(Cessna 1969 model), and not a 1968 177(no A),
then it came from the factory with the 180 HP engine. It is the 150 HP
1968 model that you can't fill the seats on a hot day.My 177A has a
useful load of over a 1000 lbs, and I have flown it there several times
and it handles it well. The slots in the Stabilator eliminated the
stalling in the flare issue. Cardinals have great looks, room, and the
early ones have a high useful load. I actually prefer the early airfoil
that was changed the following year to a more Skyhawk like one. If you
use alot of nose up trim, you should feel little pressure upon landing.
Should get 118 knots at 75% cruise. Later models will do 130.
Wouldn't trade it for anything in it's class.
Hello there,
Tien, CP
Old November 22nd 05, 05:25 AM posted to rec.aviation.owning
Thanks everyone for your help.
It is indeed a 177, 1968 with a 150 HP engine. I think I can live with its
handling characteristics.
Tien
Old November 22nd 05, 05:52 AM posted to rec.aviation.owning
There is a STC upgrade to 160hp if you so desire... Can still run on
mogas as well, with the proper STC for that...
Old November 22nd 05, 07:33 PM posted to rec.aviation.owning
It has a "PowerFlow Extractor Exhaust System" which is supposed to bump
up the bhp somewhat putting it possibly in the neighborhood of 160 hp.
Tien
Old November 23rd 05, 07:17 AM posted to rec.aviation.owning
a C177 will feel nose heavier than a 172..
an A model does get "tail stalls" when landing.. if slow.. that's why the
mod on the B model
I've run out of nose up trim on final in 177B RG with two in the front seats
and light on fuel, no aft baggage. Nothing I could not hold up, just could
not trim it out at 70KIAS on final.
BT
" wrote in message
Hello there,
Tien, CP
Flying our Cardinal south for its new plumage - Long report Longworth Piloting 20 October 20th 05 06:01 AM
Flying our Cardinal south for its new plumage - Long report Longworth Owning 19 October 20th 05 01:23 AM
Any Cardinal owners that frequent this group? Jack Allison Owning 6 November 17th 04 04:05 PM
Swift Boat Veterans For Truth: Are They Going To Sink John Kerry? BUFDRVR Military Aviation 151 September 12th 04 10:59 PM
Lot of noise being made about Purple Hearts Jack Military Aviation 154 September 8th 04 08:24 PM
