Refinishing wooden prop
Old December 17th 05, 03:54 AM posted to rec.aviation.homebuilt
Default Refinishing wooden prop
I have an otherwise airworthy wooden prop that could use refinishing and
I'm seeking advice on how to do the refinish. What's the best way to
remove the old finish? Will strippers cause the prop to delaminate?
What's the best or most commonly used finish?
Thanks
Old December 17th 05, 04:03 AM posted to rec.aviation.homebuilt
I would not use a stripper or solvent. No telling what that might do to the
glue. My prop manufacturer says to refinish his props with "a good
polyurethane", so I'd hand sand the prop then apply a coat or two of poly.
KB
"Wallace Berry" wrote in message
Thanks
Old December 17th 05, 06:24 AM posted to rec.aviation.homebuilt
Is this going to be a flying or nonflying prop, after this?
If you are going to fly it, hand sand and poly, like KB said.
If it was going on a wall, I would get a random orbital sander and go to it,
taking all of the old finish off, filling in any nicks or voids, then two
coats of sanding sealer, then two coats of high gloss poly.
Old December 17th 05, 11:39 AM posted to rec.aviation.homebuilt
However, if it's going on the end of a crankshaft, get thee to a propshop
and let them do it.
"Morgans" wrote in message
poly.
it,
Old December 17th 05, 04:10 PM posted to rec.aviation.homebuilt
Thanks for all the replies. The prop is destined to fly, at least for a
while, on the end of a C-85 crank. There is small nick on the end of one
blade, so I'll probably let a prop shop trim it and do the refinish.
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
FS: 114 inch wooden prop minot piper e Aviation Marketplace 0 November 21st 03 05:01 AM
Wooden Prop minot piper e Home Built 1 October 27th 03 12:39 AM
Wooden Prop Brian O'Sullivan Aviation Marketplace 3 October 13th 03 03:34 PM
Wooden Prop Ian Donaldson Aviation Marketplace 0 October 13th 03 12:30 PM
