Attn: Jim Weir - 24v to 12v
Old December 23rd 05, 06:37 AM posted to rec.aviation.homebuilt
Default Attn: Jim Weir - 24v to 12v
I have a car adapter that powers my pda and gps receiver. The adapter is
generic and has no information on it that says what the allowable input
voltages are. Is there an easy way to determine if it allows a 24/28v
input?
Also, is there an easy circuit to convert 24/28v to 12/14v for these kinds
of adapters?
Old December 23rd 05, 05:01 PM posted to rec.aviation.homebuilt
Default Jim Weir - 24v to 12v
"Jackal24" wrote in message
input?
/wry/ Sure, plug it in to the 28 volt connector. If it starts smoking and
fries the pda and gps, it wasn't meant for 28 volts /*wry*/
The only way I know for sure is to call the manufacturer of the adapter and
ask. That what I personally would do.
of adapters?
Yes. A 7512 voltage regulator will handle the job quite nicely up to an
amp. THere are ways beyond that if you need more current, but not a subject
for a newsgroup. I believe Rat Shack still carries the 7512, and if not,
the LM317 is the adjustable version of a 1 amp regulator.
Old December 24th 05, 06:29 AM posted to rec.aviation.homebuilt
Thanks for the help guys. I will look into this circuit.
Attn: Jim Weir - Cellphone adapter? Jackal24 Home Built 3 August 23rd 05 02:46 PM
Headset connections (attn: Jim Weir) Bruce Home Built 5 April 20th 04 04:56 PM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 03:10 PM
Jim Weir and radio racks Matthew M. Jurotich Home Built 4 November 13th 03 04:51 AM
B is for Governor candidate Jim Weir Montblack Piloting 17 August 19th 03 05:35 AM
