H-stab rigging angle for the ASW27
Old December 24th 05, 02:07 PM posted to rec.aviation.soaring
Default H-stab rigging angle for the ASW27
Could some one look up and give me the incident angle between
the wing and H-stab in there
Maintenance and Repair Manual of the ASW27
under Control Deflections and Rigging Angles
Thanks in advance
Udo
Old December 24th 05, 02:57 PM posted to rec.aviation.soaring
Udo,
I believe this is what you are looking for.
From the manual:
Wing Incidence
+ 1.35 degrees to horizontal tailplane
-2.35 degrees to fuselage tail boom axis
Horizontal Tailplane incidence
-1.35 degrees to wing chord
-3.7 degrees to fuselage tail boom axis
The tailboom axis is level when a wedge 1000 in 54 =3.1 degrees is put
level on the rear part of the fuselage tailcone.
Chip Fitzpatrick
Old December 24th 05, 04:47 PM posted to rec.aviation.soaring
Chip
Thank you for your help.
Udo
From the manual:
Wing Incidence
Chip Fitzpatrick
Old December 24th 05, 05:26 PM posted to rec.aviation.soaring
Udo ! Whatcha building ? Another Frankenglyder ?
A mystery open class machine to challenge Concordia and Eta ?
Enquiring minds want to know !
Happy Holidays, Dave
Old December 24th 05, 05:54 PM posted to rec.aviation.soaring
Here is a photo diary of the wing construction portion of the project. He
is using HP-18 spar caps and the airfoil he designed.
http://www.soaridaho.com/Schreder/Co...g_Building.htm
Old December 26th 05, 05:10 PM posted to rec.aviation.soaring
Dave,
happy returns as well,
Yes I am working on other project. It will have air of Herr Frankenstein
about it, I just hope it (the creation) does not kill.
I am trying to keep my challenges affordable. Challenging the factory toys
of my gilding acquaintance will be just fine.
The airfoil is 13% thick from the tip to 1/4 span and transitions from
there to the root to 15%. Average thickness ratio is about 13.75%,
root is 33" tip 14"Aspect ratio is about 24, wing area about 103 ft/sq,
all very conventional.
Udo
Old December 26th 05, 09:48 PM posted to rec.aviation.soaring
Thanks for the update Udo.
Are you using an 18T fuselage ?
We'll look forward to seeing it soon !
Will you bring it to Mifflin in the spring ?
Perhaps I'll bring the whale and leave the factory-built toys home.
Best Regards, Dave
Old December 26th 05, 10:56 PM posted to rec.aviation.soaring
Dave,
When you say "whale" are you referring to your RHJ-8? If so, I would like
to have some pictures for the Schreder web site
(http://www.soaridaho.com/Schreder/RHJ/RHJ_Links.html) the next time you
take it out of the "box".
Best Regards, Dave
Old December 27th 05, 01:01 AM posted to rec.aviation.soaring
Dave,
Yes I will be using a modified HP18 fuselage.
I may fly the new wings at first with the V tail.
Mifflin maybe in the spring of 2007
I will see you most likely next spring but it will
be with the 24.
Udo
Best Regards, Dave
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 02:19 AM
Bending extruded angle Veeduber Home Built 8 August 29th 04 01:58 AM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 11:01 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 09:46 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
