SZD55 Launch hook info
Old December 27th 05, 01:07 PM posted to rec.aviation.soaring
Default SZD55 Launch hook info
We have a SZD 55 that was purchased with a aerotow
hook only, the fittings for the mounting of the hook
on the U/C leg and the cable guide on the wheel well
were already there (factory)
The problem we have.on fitting the winch hook....is
the range of movement of the 2 hooks is hugely different,
Both are the correct Tost hooks
We can operate the Aerotow OR Winch hook independently
without problems, however when connecting them in unison,
the aerotow hook range of movement ,restricts the winch
hook...
So anyone got a good photograph of the aerotow hook,
lever assy and cable routing please
Old December 27th 05, 11:32 PM posted to rec.aviation.soaring
Contact Jerzy Szemplinski with Windpath Corporation. He is based in
Toronto and he is the SZD dealer for North America and owner of the 55.
Old December 28th 05, 04:41 PM posted to rec.aviation.soaring
Hi Keith:
Could you please get in touch with me regarding the wing tip skids I
sent you 4 months ago?
Ulli Werneburg
Old December 28th 05, 09:57 PM posted to rec.aviation.soaring
Suggestion: you can either adjust the useful length of the actuation arm =
at each release or connect both to the release knob using a pulley, =
which makes their travel independent from each other.
Lawsuit filed over AFA towpilot fatality Stewart Kissel Soaring 20 June 11th 17 03:58 PM
Is it Possible to Self launch (no wingman) with CG hook?? Jerz Rossignol Soaring 43 November 16th 04 08:54 AM
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Vandenberg Launch, April 17 Piloting 5 April 9th 04 03:21 AM
CG hook on aero tows?? Ted Wagner Soaring 130 January 13th 04 12:04 AM
