New helicopter designs
Old December 28th 05, 07:16 PM posted to rec.aviation.rotorcraft
Default New helicopter designs
There are several firms offering either plans for, or kits, for homebuilt
helicopters that have little if any supporting actual flite test data. Yet
apparently there are willing buyers out there willing to part with their
money for these subjects of marketing rhetoric. Even EAA gave some notice
of one of the offerings which adds or implies some credibility to the
offering. In this case, the aircraft has demonstrated flight but is not
mechanically capable of autorotation. Am I missing something? Are there
that many people out there that just believe the marketing rhetoric without
having seen a demonstration or having access to an independent test report?
I know that I don't part with tens of thousands of dollars just based on the
advertising.
Old December 29th 05, 04:30 AM posted to rec.aviation.rotorcraft
"Stuart Fields" wrote in message
Yet
without
report?
advertising.
Frightening, isn't it! :-o
Old December 29th 05, 08:52 AM posted to rec.aviation.rotorcraft
Remember the words of PT Barnum?
Old December 29th 05, 09:31 AM posted to rec.aviation.rotorcraft
Well there is that angle as well.
However..... Perhaps the interest, down payments, etc., show that there
is a viable market pool of people with enough money to enter the
helicopter market at the low end dollar level.
Two hundred thousand for a clapped out whatever may be way out of their
financial ballpark but fifty grand for a kit of brand new parts is
something else.
It appears that in that particular market level that there are people
with both the money and the dream.
Old December 30th 05, 10:40 PM posted to rec.aviation.rotorcraft
Stu,
"....has demonstrated flight but is not mechanically capable of
autorotation. Am I missing something?"
Re autorotation;
It might be of interest to know that the first production helicopter, the
Flettner FL-282 had a rotor governor. In addition, Igor Sikorsky's chief
rotor designer, William Hunt, invented a rotor governor for the R-5. The
rotor governor provides automatic entry into autorotation.
Perhaps an article on this subject in your 'Experimental Helo' magazine
would be of interest.
Dave
Yet
without
report?
advertising.
Old December 31st 05, 02:07 AM posted to rec.aviation.rotorcraft
Dave: Thanks for the idea for an article. I'll look into that. On the
other hand if there is no collective pitch control available to the blades,
autorotation is going to be at least problematical. --
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Dave Jackson" wrote in message
news:ePhtf.222047$Gd6.115880@pd7tw3no...
Stu,
Re autorotation;
Dave
homebuilt
Yet
notice
not
there
without
report?
advertising.
Old December 31st 05, 02:39 AM posted to rec.aviation.rotorcraft
Dave: I looked at your site on the Unicopter and Sychrolite and saw the
references to the rotor governor, but couldn't tell just how this device was
supposed to work. I cautiously assume that it senses rotor speed and
collectively adjusts pitch to keep the blade speed at some pre-selected rpm?
I also assume that the pilot would have an override for this feature? Do
you know where I can read up on the use of the governor and why that device
hasn't continued to this day? It seems the R-22s might like to have one if
the downside was not too steep.
An aside issue, you state that the need for yaw control of the Unicopter
would be more like a fixed wing. With the exception of hovering, I find the
yaw control on my helicopter to be less than that required by the fixed
wings that I have flown. e.g. no need to lead the turn with pedals to keep
the ball centered. A lot of the multi rotor systems supporters seem to
think that the use of the anti-torque pedals requires a lot of training. I
did not find that to be true at all. Even in the hover. Are you helo
rated?
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
Stu,
Re autorotation;
Dave
homebuilt
Yet
notice
not
there
without
report?
advertising.
Old December 31st 05, 07:44 PM posted to rec.aviation.rotorcraft
Stu;
A gentleman sent me three pages out of William Hunt's book. The pages cover
his patent for this rotor with torque-pitch coupling. He also suggests that
the collective lever could be eliminated.
I will attach the three pages to an e-mail to you.
The technical and anecdotal information on these few pages was so
interesting that the book is now on order.
Dave
"Stuart & Kathryn Fields" wrote in message
blades,
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
Stu,
Re autorotation;
Dave
homebuilt
Yet
their
notice
not
there
without
report?
on
advertising.
Old December 31st 05, 08:17 PM posted to rec.aviation.rotorcraft
Stu,
was
rpm?
I assume that you are reffering to page http://www.unicopter.com/0575.html,
which is a sub page to http://www.unicopter.com/Governor.html. Actually, it
senses the torque to the rotor. By doing it this way, the application of
more torque from the engine to the rotor will immediately increase the
collective pitch. Conversely, the loss of engine torque lowers the
collective pitch to its autorotative setting. In other words, varing the
torque will vary the collective pitch. You will notice that Hunt's idea has
no provision for collective.
Yes, on the idea in my web site, the pilot could still have a collective
stick. A primary difference is that the pilot would have to take action to
stop from going into autorotation, instead of having to take action to go
into autorotation.
The UniCopter is a unique rotorcraft, in that the rotors and blades have
'absolute' (actually ~ as close as is reasonably possible to absolute)
rigidity. In other words, the relationship of the blades and the fuselage is
'theoretically' similar to that of an airplane's wings and fuselage. The
technical chalange is the consideration of yaw during hover, which of course
the airplane does not have to consider.
Are you helo rated?
No. Only fixed wing.
Dave
Old January 3rd 06, 03:47 AM posted to rec.aviation.rotorcraft
Yes, but who will be the one that will be able to finance a new start
up? I'm thinking of reviving the XROE-1. I think that will sell like
hotcakes.
The Monk
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 10:11 AM
Musings of a Commercial Helicopter Pilot Badwater Bill Rotorcraft 0 February 25th 04 07:39 PM
