Alternate requirements
Old September 17th 03, 07:33 AM
Anthony Chambers
Default Alternate requirements
I've spent the past couple of hours researching this in the regs and
newsgroups... and am still a little confused
If I require an alternate airport for a IFR Flight plan, does that alternate
have to have official weather reporting? I read somewhere that:
"The requirements for an airport to qualify for alternate minimums are
weather reporting and approach facility (navaid) monitoring"
But I also read that I can file an alternate with no approaches and no
weather reporting as long as I can descend under Basic VFR from the MEA to
the airport (Part 91).
What gives?
Old September 17th 03, 03:41 PM
Stan Gosnell
"Anthony Chambers" wrote in
alternate have to have official weather reporting? I read somewhere
that:
MEA to the airport (Part 91).
You can file a destination with no approaches and no weather reporting as
long as you can descend VFR. But you have to have a legal alternate to do
so.
See FAR 91.169, http://tinyurl.com/no9h
Regards,
Stan
Old September 17th 03, 05:29 PM
Ron Natalie
"Anthony Chambers" wrote in message ...
The rule is:
(c) IFR alternate airport weather minima. Unless otherwise authorized by the Administrator,
no person may include an alternate airport in an IFR flight plan unless appropriate weather
reports or weather forecasts, or a combination of them, [600-2, 800-2, or VFR from MEA down
as appropriate].
Whether you can glean this from area forcasts in the absence of on-field reporting is
up for you to decide (as a non-commercial operator). Airports without weather that
have approaches will generally have NA Alternate Minimums.
Old September 17th 03, 05:30 PM
Ron Natalie
"Stan Gosnell" wrote in message ...
so.
That's not what he asked.
Old September 17th 03, 09:48 PM
Stan Gosnell
"Ron Natalie" wrote in
m:
reporting as long as you can descend VFR. But you have to have a
legal alternate to do so.
I thought it was. Perhaps I wasn't clear. He can file a destination with
no approaches or weather, but he can't file an alternate with no approaches
or weather. I think he was confusing destination and alternate
requirements.
Regards,
Stan
Old September 17th 03, 10:15 PM
Ron Natalie
requirements.
He specifically asked if the alternate had to have weather reporting.
There is no requirement that the alternate have an approach nor is their a strict
requirement for "on-field" weather at the alternate. If the forcast is for severe
clear with no "chance of" or "probability of" lower than VFR conditions from the
MEA down to the ground, it's legal to use that airport as an alternate.
Old September 17th 03, 10:33 PM
Ray Andraka
Unless that airport is one that is not authorized as an alternate. As I understand it, most that don't
have wx reporting are so designated.
requirements.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Ron Natalie
"Ray Andraka" wrote in message ...
As I pointed out in my original response, if the airport has an approach, then the TERPS
say to mark it as NA if it has no weather. If the airport doesn't have an approach, there
is nowhere to mark it as NA (of course, you're pretty much going in their in VFR conditions
anyhow so it doesn't matter).
Old September 17th 03, 10:45 PM
ArtP
On Wed, 17 Sep 2003 16:33:14 -0400, Ray Andraka
I think it is approaches that are NA, not airports. For instance W50
has no IFR approaches, so it has no NA approaches and the AFD does not
indicate it the airport is NA. I would assume that any visual approach
that is not NA is suitable for an alternate.
alternate carb heat Ray Toews Home Built 16 October 29th 04 01:41 PM
Alternate turbine fuel Robert Bates Home Built 24 June 7th 04 08:16 AM
Battery Requirements jgarner Home Built 3 March 28th 04 07:32 AM
NA as alternate...redux Bob Gardner Instrument Flight Rules 1 September 11th 03 11:26 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
