Why is wind directon expressed as "FROM"?
Old January 5th 06, 05:51 PM posted to rec.aviation.piloting
Default Why is wind directon expressed as "FROM"?
Is it me, or is wind direction bass ackwards?
Vectors normally indicate direction an object is moving, but not so with
wind.
Why is that?
Old January 5th 06, 05:56 PM posted to rec.aviation.piloting
wind.
Why is that?
I suspect it's a holdover from weather. You don't care where wind is
going (for the purposes of weather prediction) but you do care where it
came from (as that gives hints as to what kind of airmass will be
arriving, and what it will bring with it). When wind is coming from New
Jersey, this tells you something. When wind is =going= to New Jersey,
it's their problem.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old January 5th 06, 05:58 PM posted to rec.aviation.piloting
wind.
Why is that?
Not sure of the official reason, but hearing the wind direction expressed
as a FROM direction provides me with a very quick way of determining which
runway is most aligned with landing into the wind.
For example, landing at an airport with a single strip runway labeled 10 on
one side and 28 on the other, you hear the wind on the ASOS reported as
"250 at 15." What runway will you choose?
Peter
Old January 5th 06, 06:02 PM posted to rec.aviation.piloting
wind.
Why is that?
it's their problem.
The usage probably predates aviation, but it certainly does come in
handy for pilots trying to pick the right runway to use. If the ATIS
says the wind is X, pick the runway numbered closest to X and you'll
have a headwind.
Old January 5th 06, 06:08 PM posted to rec.aviation.piloting
When wind is coming from New Jersey, this tells you something. When wind is =going= to New Jersey, it's their problem.
LOL
The Monk
Old January 5th 06, 06:25 PM posted to rec.aviation.piloting
In article , Peter R.
The one that lets me roll out closest to the parking area. :-)
Garner R. Miller
ATP/CFII/MEI
Clifton Park, NY =USA=
http://www.garnermiller.com/
Old January 5th 06, 06:46 PM posted to rec.aviation.piloting
On Thu, 5 Jan 2006 11:51:58 -0500, "JohnH"
wrote in ::
Why is that?
The convention is probably a result of the way a weather vane works;
the arrowhead points into the wind, so a compass rose placed under it
indicates the direction of the wind's origin.
Old January 5th 06, 06:49 PM posted to rec.aviation.piloting
I'd say the opposite - the vane is designed that way because we're
interested in where the hot air came from.
One could easily design a vane that worked the other way.
Jose
Old January 5th 06, 06:54 PM posted to rec.aviation.piloting
On Thu, 05 Jan 2006 17:49:51 GMT, Jose
wrote in ::
How would you do that?
Old January 5th 06, 07:01 PM posted to rec.aviation.piloting
Make the arrowhead really big and mount the thing by the tail.
Tie a piece of string on a stick and see which way it points.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Headwinds, always Paul kgyy Piloting 36 June 9th 05 02:05 AM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 05:33 AM
