WinPilot shorts on PocketPC screen
Old January 19th 06, 11:02 PM posted to rec.aviation.soaring
Default WinPilot shorts on PocketPC screen
I sent this question to the associated vendors but being a little
pressed for time due to glider delivery I thought I'd try it here.
After I installed WinPilot Pro on an iPAQ 3955 (running PocketPC 2002
Premium) I had the two large shortcuts on the screen for WinPilot PRO
and WinPilot PRO Simulator. I then installed ConnectLX, after which
the WinPilot shortcuts were removed, replaced only by a ConnectLX
shortcut.
Does anyone know how I can get the WinPilot shortcuts back?
Advance thanks
-ted/2NO
Old January 20th 06, 02:52 AM posted to rec.aviation.soaring
The same thing happens with Connect Me.
Old January 20th 06, 02:59 AM posted to rec.aviation.soaring
On the PDA go to
StartSettingsTodayItems
then check the box in front of WinPilot to select what you want to show
up on the "Today" screen
After that, you have to reset the PDA (stylus in the reset hole) to get
the change to take effect. Works for me.
-Dave Leonard
ZL
Old January 20th 06, 02:25 PM posted to rec.aviation.soaring
Paul,
I was aware of having to do the reset, and did have the large icons
after I did so. But the icons went away after I installed ConnectLX. I
re-installed WinPilot, did a soft reset, had the icons back, ran
ConnectLX, and the icons were gone again.
Not a real big deal but when you're sitting in the cockpit and you want
to fire up the WinPilot it's a lot easier with those icons!
-ted/2NO
(Going to try the Start.Settings.Today.Items thing today)
Old January 20th 06, 08:44 PM posted to rec.aviation.soaring
It only works one time. Each time I run ConnectLX, the WinPilot icons
disappear and the WinPilot item shows up deselected in the
Start.Settings.Today.Items list.
I think this may be a PocketPC 2002 thing ... I don't have this problem
on my PocketPC 2003 iPAQ ...
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 02:30 PM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 06:09 PM
WinPilot offer... and UK news Paul Crabb Soaring 2 February 19th 04 10:22 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 05:44 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
