DG-300 Wing fore/aft pin slop
Old January 27th 06, 06:38 PM posted to rec.aviation.soaring
Default DG-300 Wing fore/aft pin slop
I'm a new owner of a 1984 DG-300 with 700 hrs. Upon first assembly,
it is apparent there is approximately 1/8" gap between the wing root
and fuse. Also there is what appears to be a moderate amount of
movement of the wings fore/aft when moderate force is applied. What is
the acceptable amount of movement? Is there an adjustment, or shim
placement that could be expected?? I'll could feel "bumping" of the
wings in turbulent air. thanks...
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Grob G102 Setup BDS Soaring 11 August 30th 05 04:42 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
