Gas Theft Nashua (ASH)
Old February 4th 06, 03:48 PM posted to rec.aviation.piloting
Default Gas Theft Nashua (ASH)
Flew into Nashua last Sunday for business, topped off the tanks right
after setting down. When I came back from business on Thursday, found
the right tank down quite a bit. I was going crazy looking for the
leak and checking the drain for seepage, until the line guy pointed out
that he filled the tank back up exactly 5 gallons--which happens to be
the volume of a standard gas can. He said he'd seen it happen to
another plane on the line, both tanks down 5 gallons.
It was parked pretty much in front of the tower, but it is a low wing
parked in a line of high wings so I guess it made the easiest siphon
target.
I've never given any consideration to gas theft but I think in the
future I will top off right before taking off, as at least thirsty
tanks will make a less attractive target!
Hank Rausch
N9906T
Old February 4th 06, 04:46 PM posted to rec.aviation.piloting
target.
That has happened here in AZ, too. Acquaintance with a 421 was down *20*
gallons. It's a gaited airport, but it was at a tie-down near the
self-serve fuel station -- maybe somebody just got confused (har!).
Imagine seeing a twin, or any other airplane, and just helping yourself.
Unbelievable.
Old February 4th 06, 05:23 PM posted to rec.aviation.piloting
I would ten times over risk gas theft over water condensation overnight in
half-full or nearly empty tanks.
"Hank Rausch" wrote in message
Old February 4th 06, 05:59 PM posted to rec.aviation.piloting
I have a Mooney so filling the tanks is a rare event (7 hours of gas is
way more than I need and I don't like pulling a yaht around with a
Corvette). I generally keep only about 10 gallons per side when parked.
I park outside and have yet to see any water in the 6 years I've had
the plane. Maybe the fact that a Mooney technically doesn't have fuel
"tanks" makes it different.
-Robert
Old February 4th 06, 06:44 PM posted to rec.aviation.piloting
in half-full or nearly empty tanks.
There's not enough water in 20 gallons of air to matter.
How much water is there? In *extremely* wet conditions (saturated air
at 20 deg. C) there are only 14.7 g/kg of water in the air. A cubic
foot of air at SLP weighs about 34 grams at 20 C. 10 gallons is ~27 cu.
ft., so that gives about 900 g. of air and about 14 g. of water. Not a
problem.
Dan
C172RG at BFM
Old February 4th 06, 06:54 PM posted to rec.aviation.piloting
20 gallons is ~27 cu.
Old February 4th 06, 06:55 PM posted to rec.aviation.piloting
After 102 years of powered flight, you'd think locking gas caps would be
available.
Old February 4th 06, 07:02 PM posted to rec.aviation.piloting
But, if you fill it up, and they siphon it out, don't you still have the
same problem?
Old February 4th 06, 07:03 PM posted to rec.aviation.piloting
available.
If you hook up a tube to the fuel drain and the vent is working
properly, a locking cap won't make a difference.
Old February 4th 06, 08:09 PM posted to rec.aviation.piloting
same problem?
First thing that came to my mind as well when I read that.
The Monk
Theft among friends bumper Soaring 8 July 29th 05 06:51 PM
Theft From Baggage-Continental [email protected] Piloting 73 April 2nd 05 09:17 AM
A-10s at Nashua, NH (ASH) today? William W. Plummer General Aviation 0 May 15th 04 05:03 PM
Good News! Arrest in plane theft case Jamie Rogers Piloting 10 November 8th 03 07:43 AM
Nashua Festival, Avidyne and WSI Doug Vetter Owning 9 September 24th 03 03:45 AM
