ANN: SoarPilot 3.2.0 Now Available
Old February 15th 06, 05:59 AM posted to rec.aviation.soaring
Default ANN: SoarPilot 3.2.0 Now Available
SoarPilot 3.2.0 is now available via the main webpage at
www.soaringpilot.org. The following are the changes/enhancements for
this version. See the SoarPilot online manual for more details of each
item at http://www.soaringpilot.org/dokuwiki
1. Support for Flarm to show potential collision & other
traffic/obstruction data
http://www.soaringpilot.org/dokuwiki...arm_connection
2. Now Fully Functional on most WinMobile/PocketPC/WinCE devices using
the StyleTap® Platform PalmOS Emulator (www.styletap.com).
3. New Feature to show the estimated amount of logging time available,
and to show a warning at start-up of 5 hours remain
4. Support for reading pressure altitude, total energy vario and wind
information from the ILEC SN10.
5. New low battery warnings before the program is forced to exit
6. Faster download speeds for flight logs from the Cambridge 302
7. Achieved turnpoints in the Active task will be shown with a line
through the name
8. Changed order of sort buttons on waypoint list, putting the Distance
sort on the edge of the screen so it is easier to find in flight
9. Options to highlight or only display SUA with active warnings on the
moving map
10. Fix for task re-start if "No" was selected. This would move the
active waypoint back to the start in error
11. Fix for task distance calculations in AAT tasks
12. Fix for the Cambridge 302 MC bug. Setting can now be made on
either device without issue.
13. Fix for corrupt flight log if program terminates unexpectedly
(power loss)
14. Fix to stop an SUA alert corrupting the map screen on a T5 device
15. Fix to overlapping numbers on the moving map screen on hi-res
devices
16. Support for reading pressure altitude from Zander SR940/GP941 & SDI
PosiGraph
-Mark Hawkins & Paul Gleeson
ANN: SoarPilot 3.0.0 Final Has Been Released [email protected] Soaring 0 November 2nd 05 11:10 PM
