Sport Pilot and Glider Questions
Old February 21st 06, 05:34 AM posted to rec.aviation.soaring
Default Sport Pilot and Glider Questions
I hope to get both the Sport Pilot and Private Glider certificates.
Which order would be best to get them in - would Sport Pilot be better to
get first or last?
I am especially interested in a motorglider called the Virus (what an
unfortunate choice of name!). Does a glider certificate let you fly a
motor glider?
http://www.mcp.com.au/pipistrel-usa/models/virus.html
Old February 21st 06, 05:54 AM posted to rec.aviation.soaring
A glider license can be earned using one of three launches: a ground launch,
aero launch or self launch. Once you get the license, you must get get
logbook endorsements for either of the others.
I am not sure there is an advantage to obtaining either the sport license or
the glider license first. Do whatever is most convenient. Both are fun and
require and hone different skills. Soaring is best in the summer,
generally, while flying power planes works well when there is no thermals.
So, I suppose I would fly with an engine in the winter and fly gliders in
the summer.
Hard to go wrong with either one.
Colin
Old February 21st 06, 11:07 AM posted to rec.aviation.soaring
If I recall correctly.. there is no Glider Rating at the Sport Pilot level.
If you complete a Sport Pilot Rating in "airplane", then you still need to
complete a Glider Rating at the Private Pilot Level. Complete with Glider
Private Pilot written exam and check ride.
Of issue is that the Sport Pilot rating does not address certain
physiological factors of high altitude flight or long distance cross county
flying, which the Private Pilot rating does.
With the Private Pilot Glider rating you would only need a log book
endorsement for "self launch".
As this aircraft called a "Virus" seems to be a motor glider, then a Glider
Rating with Self Launch endorsement is all that is needed to fly it.
so why the Sport Pilot rating? unless you have other aspirations.
But then again, I could not be remembering correctly...
BT
"Ralph Steiner" wrote in message
get first or last?
motor glider?
Old February 21st 06, 02:35 PM posted to rec.aviation.soaring
Yes, I wish to have both the sport pilot and glider certificates.
It seems that for a glider I need less training if I already have a pilot
certificate. Some training for pilot also applied to glider. But that text
has not changed since before the sport pilot regulations were released.
This caused the question of if that situation also applied to sport pilot
training.
RS
"BTIZ" wrote in message
news:ICBKf.40$Uc2.37@fed1read04...
level.
county flying, which the Private Pilot rating does.
Glider Rating with Self Launch endorsement is all that is needed to fly
it.
Old February 21st 06, 03:16 PM posted to rec.aviation.soaring
There are no 'ratings' exactly for the sport pilot certificate, but the
equivilant is a instructor sign off for the glider category. Check FAR
61.301 - 61.329.
Off course that would give you the privilege to fly a light sport
glider, which are pretty rare so far.
Todd
3S
Old February 21st 06, 03:36 PM posted to rec.aviation.soaring
level.
Yes you can get a Sport Pilot - Glider; however, the standards are so close
to the Private Pilot - Glider that I hardly see why it would be worth while.
I seem to remember that the basic requirements are something like the
following:
1 . Must be 16 years old
2. Total of 20 hours in a heavier-then-air aircraft with: 10 hours of flight
time in a glider, including 10 flights in a glider receiving flight training
from an authorized Instructor and at least 2 hours of solo flight.
3. Five solo launches and landings, and 3 hours of flight training on those
areas of operation specified in §61.311.
4. Have passed the written examination; and
5. Have passed the flight exam with an Examiner
http://www.aopa.org/sportpilot/pts_sport_airplane.pdf Chapter 3 covers the
practical test standards for Sport Pilot glider privileges.
Flying sailplanes as a Sport Pilot would limit you to flights less than
10,000 feet MSL (major problem where I fly) and a sailplane that has a Vne
of less than 120 kts.
I really don't know where the Virus falls. It meets the Sport Aircraft -
airplane; however, I am sure that its' Vne is over 120 kts; therefore, fails
to meet the Sport Aircraft - glider requirements.
I believe the Private Pilot - Glider (self-launch) is the best route to
flying a Virus.
The bottom like is that you must have a pilot certificate that matches the
aircraft's airworthiness certificate. If the FAA calls it a glider, it is a
glider. Otherwise it is a single engine airplane. (If you review the FAA
records you will see some WindRose homebuilts registered as gliders and some
registered as single-engine airplanes.)
HP-14 N990 "6F"
http://www.soaridaho.com/
Old February 21st 06, 03:43 PM posted to rec.aviation.soaring
"Flying sailplanes as a Sport Pilot would limit you to flights less than
of less than 120 kts."
Not quite true. There is an exception to flying over 10,000 feet. I recall
it is a maximum clearance. Also, the maximum speed is based upon level
flight operation and is not Vne. It is Vh.
Colin
Old February 21st 06, 04:33 PM posted to rec.aviation.soaring
With the sport pilot certificate first, you would qualify under the FARs and
having more than 40hrs in an aircraft before moving on to the glider rating,
that would qualify you as requiring less training hours or flights logged to
achieve the private glider rating.
Because the sport pilot does not cover some material that a private pilot
does, it cannot be done as an "add on" rating, you would still need to take
the glider private written test prior to the check ride.
As a CFIG, I can assure you that you would be trained in all areas required
for your glider check ride, but because you already hold a Sport pilot
rating it would take less time on basic aerodynamics, flight control,
traffic patterns and airspace study etc.
BT
text has not changed since before the sport pilot regulations were
released. This caused the question of if that situation also applied to
sport pilot training.
RS
level.
to complete a Glider Rating at the Private Pilot Level. Complete with
Glider Private Pilot written exam and check ride.
it.
Old February 21st 06, 04:37 PM posted to rec.aviation.soaring
"COLIN LAMB" wrote in message
ink.net...
recall
Colin.
Here are a couple quotes:
Source: http://www.sportpilot.org/nprm/sectional_analysis.html
An unpowered light-sport aircraft (e.g. glider) would have a maximum
never-exceed speed (VNE) of 115 knots, as VH is not applicable. This speed
limitation also limits the commanded kinetic energy of an aircraft flown by
a pilot holding a sport pilot certificate. For a VNE equal to 80% of the
aircraft's structural design limit speed, a 115-knot VNE limit for aircraft
would mean that structural design limits would preclude gliders with a speed
capability in excess of 144 knots from being approved as light-sport
aircraft (144 X .80=115).A light-sport aircraft would have a maximum stall
speed in the landing configuration (VS0) of 39 knots. This value for a
maximum stall speed is a characteristic of low-performance aircraft and
would assist in ensuring that light-sport aircraft possess handling
characteristics commensurate with the training and experience of sport
pilots. It is also consistent with foreign airworthiness standards for
similar performance aircraft.
Source: http://www.sportpilot.org/becoming/
Restrictions on a sport pilot certificate: ....... no flights above
10,000' MSL ......
Am I missing something here?
Respectfully,
Old February 21st 06, 04:38 PM posted to rec.aviation.soaring
thanx guys.. I knew there was a 10,000MSL limit but did not know there may
be a waiver for unpowered sport aircraft, I knew the Vne was so low as to
exclude 90% of currently available gliders.
Time for me to do some more reading.
BT
"T o d d P a t t i s t" wrote in message
close
while.
I agree - it's probably better to get the Private Pilot
glider than the Sport Pilot glider. For gliders, the
limitations on a SP are greater and the extra effort needed
for the PP is less. Once you have the PPG, you
automatically qualify for the SPG. You can then add the
SP-Airplane with simple instructor signoffs - something you
may find worthwhile.
T o d d P a t t i s t - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Can a Private Pilot tow gliders and get paid? BTIZ Soaring 1 October 17th 04 02:35 AM
Will US Sport Pilot be insurable? Mark James Boyd Soaring 12 November 29th 03 04:57 AM
Latest Newsletter Pipistrel Motorgliders Michael Coates Soaring 20 September 19th 03 02:25 AM
