I've been told that it is possible to load successive approaches in the
flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a flight plan to take off at one airport, fly to a second airport then do several instrument approaches at the second airport then head to a third airport and do several approaches there. I have no problem loading in the airport and then the first approach, but if I try to enter a second approach, the first approach is erased, even if I re-enter the airport in the flight plan after the initial approach. Any ideas? Thanks Jim |
towards the back of the book that comes with the 430 is a section on entering
flight plans and saving them. I will look up the exact page for you. Jim wrote: I've been told that it is possible to load successive approaches in the flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a flight plan to take off at one airport, fly to a second airport then do several instrument approaches at the second airport then head to a third airport and do several approaches there. I have no problem loading in the airport and then the first approach, but if I try to enter a second approach, the first approach is erased, even if I re-enter the airport in the flight plan after the initial approach. Any ideas? Thanks Jim |
page 54 in the manual will tell you in detail about creating the flight plans
and saving them. Jeff http://www.turboarrow3.com Jim wrote: I've been told that it is possible to load successive approaches in the flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a flight plan to take off at one airport, fly to a second airport then do several instrument approaches at the second airport then head to a third airport and do several approaches there. I have no problem loading in the airport and then the first approach, but if I try to enter a second approach, the first approach is erased, even if I re-enter the airport in the flight plan after the initial approach. Any ideas? Thanks Jim |
Yep, I've read that whole section but no where does it tell you if you can
or how to enter multiple approaches. I'm at home now just playing with the sim, but everytime I try to enter a second approach in the flight plan, it replaces the first approach that I had entered. The flight plan format seems to have 2 sections, Enroute (at the top) then Approach (under the Enroute portion) you can enter and save as many Enroute waypoints as you want ( well, up to 31 ) but only enter one approach after the enroute section. I can also enter an airport or any other waypoint after the hold portion of the approach that is saved, but I can not enter a second approach even if it is at a different airport. For instance if you wanted to pre load your alternate airport and an approach in case you couldn't get in at the first airport, you'd fly the missed, the garmin would go into suspend mode, then you could hit the OBS button and have it sequence you to the alternate airport and fly the approach that was saved in the same flight plan. Jim "Jeff" wrote in message ... page 54 in the manual will tell you in detail about creating the flight plans and saving them. Jeff http://www.turboarrow3.com |
On Sun, 30 Nov 2003 17:44:16 -0600, "Jim"
wrote: For instance if you wanted to pre load your alternate airport and an approach in case you couldn't get in at the first airport, you'd fly the missed, the garmin would go into suspend mode, then you could hit the OBS button and have it sequence you to the alternate airport and fly the approach that was saved in the same flight plan. You can't load multiple approaches. Since you won't know what approach you will be assigned until it is assigned and the approach selection is so quick it doesn't make sense to pre load any approaches. |
sorry, I thought I read routes, not approaches....
Jim wrote: Yep, I've read that whole section but no where does it tell you if you can or how to enter multiple approaches. I'm at home now just playing with the sim, but everytime I try to enter a second approach in the flight plan, it replaces the first approach that I had entered. The flight plan format seems to have 2 sections, Enroute (at the top) then Approach (under the Enroute portion) you can enter and save as many Enroute waypoints as you want ( well, up to 31 ) but only enter one approach after the enroute section. I can also enter an airport or any other waypoint after the hold portion of the approach that is saved, but I can not enter a second approach even if it is at a different airport. For instance if you wanted to pre load your alternate airport and an approach in case you couldn't get in at the first airport, you'd fly the missed, the garmin would go into suspend mode, then you could hit the OBS button and have it sequence you to the alternate airport and fly the approach that was saved in the same flight plan. Jim "Jeff" wrote in message ... page 54 in the manual will tell you in detail about creating the flight plans and saving them. Jeff http://www.turboarrow3.com |
"Jim" wrote in message ...
I've been told that it is possible to load successive approaches in the flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a I am unaware of any way to do this, nor would I consider this to be a desirable feature. I think there would be too much risk of confusion which approach you are flying and/or how to sequence to a missed approach hold vs. sequence to a new approach. I suppose you could enter the waypoints for an approach manually, but in that case the approach would not arm/activate/annunciate correctly and thus that would not be desirable. -- Richard Kaplan, CFII www.flyimc.com |
Thanks. I thought I knew the unit pretty well and didn't think you could do
it however the person telling me that you could was very adamant about it. The topic came up while doing multiple practice approaches at a non towered airport and started out with the question "Why don't you just load all the approaches before you take off?" Ummmm.... you can't! ![]() Jim "Richard Kaplan" wrote in message om... "Jim" wrote in message ... I've been told that it is possible to load successive approaches in the flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a I am unaware of any way to do this, nor would I consider this to be a desirable feature. I think there would be too much risk of confusion which approach you are flying and/or how to sequence to a missed approach hold vs. sequence to a new approach. I suppose you could enter the waypoints for an approach manually, but in that case the approach would not arm/activate/annunciate correctly and thus that would not be desirable. -- Richard Kaplan, CFII www.flyimc.com |
Sounds like you need to tell Mr Adamant to show you how its done... and
see if he's really correct on this issue.. Dave Jim wrote: Thanks. I thought I knew the unit pretty well and didn't think you could do it however the person telling me that you could was very adamant about it. The topic came up while doing multiple practice approaches at a non towered airport and started out with the question "Why don't you just load all the approaches before you take off?" Ummmm.... you can't! ![]() Jim "Richard Kaplan" wrote in message om... "Jim" wrote in message ... I've been told that it is possible to load successive approaches in the flight plan page but have been un able to either figure out how to do it or find any info in the manual about it. For instance if I wanted to create a I am unaware of any way to do this, nor would I consider this to be a desirable feature. I think there would be too much risk of confusion which approach you are flying and/or how to sequence to a missed approach hold vs. sequence to a new approach. I suppose you could enter the waypoints for an approach manually, but in that case the approach would not arm/activate/annunciate correctly and thus that would not be desirable. -- Richard Kaplan, CFII www.flyimc.com |
| Thread Tools | |
| Display Modes | |
| Question on Garmin GNC 250XL | Ron | Home Built | 1 | October 24th 04 09:26 AM |
| Garmin 430 question | smf | Instrument Flight Rules | 4 | December 1st 03 04:03 AM |
| Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 03:04 AM |
| "Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? | Richard | Instrument Flight Rules | 20 | September 30th 03 03:13 PM |
| Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 10:04 PM |
