Tech: Aluminum Forming Question
Old March 14th 06, 04:41 PM posted to rec.aviation.homebuilt
Default Tech: Aluminum Forming Question
Can anyone tell me how to form the internally rolled edge on the turtledeck
access panel seen here?
http://www.steenaero.com/Files/Proje...01385_main.jpg
Thanks!
Scott
Old March 14th 06, 05:08 PM posted to rec.aviation.homebuilt
Well it could be a stamped part or you can make a flange by hand using
a flange roller tool witch is basically a peice of flat steel with 2
rollers attached the metal goes between the rollers and you work aroud
the opening bending it a little each time. I haven't used one but I
have made not quite as nice flanges using a peice of wooden dowel with
a slit cut in the end to bend a flange a little at a time.
Thanks!
Scott
Old March 15th 06, 12:09 AM posted to rec.aviation.homebuilt
Default Aluminum Forming Question
"Scott Rodriguez" wrote in message
turtledeck
Thanks!
Scott
Form blocks would work. You need two, one underneath with the appropriate
radius and one on top to hold it in place. Work it down with at hammer.
Geoff
Spell checking is left as an excercise for the reader.
Old March 15th 06, 01:44 AM posted to rec.aviation.homebuilt
Thanks!
Scott
Make a formblock, form over the block. The link shows steps for forming
a part using a formblock. These parts were formed soft then heat treated.
http://www.eaa292.org/noon_patrol/jan_00.html
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old March 15th 06, 05:42 AM posted to rec.aviation.homebuilt
Thanks!
Scott
That's no different that a flanged lightening hole in a rib except the
angle is 90 deg. It's just a metal stretching operation. You make a
form block and backup block with the required bend radius and angle, and
hammer down with a rubber mallet or you can use something like a small
rolling pin to work the flange down at little at a time (I made a
circular hole flanging tool that uses a double width roller bearing
mounted at an angle in a fly cutter. Mounted in a drill press and
turned by hand, it rolls the flange down like a can opener. You could
do the same thing freehand with a rolling pin.)
John
24/7 computer tech support [email protected] Home Built 0 May 5th 04 04:32 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
A Source for Aluminum Ron Wanttaja Home Built 4 October 11th 03 02:38 AM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 11:10 PM
