Arrow Fuel Injection question
Old March 20th 06, 03:43 AM posted to rec.aviation.owning
Default Arrow Fuel Injection question
My Arrow has recently tended to run on for a while when I pull the
mixture back to stop it. Has anyone encountered this, and can tell me a
solution?
My mechanic says the fuel injection system probably needs overhaul -
anyone know what that costs?
Old March 20th 06, 06:34 AM posted to rec.aviation.owning
solution?
We have never encountered that problem in our Arrow, and your mechanic may
certainly be right. A few years ago we had a problem that our mechanic
initially THOUGHT was in the FI system. IIRC, he told us at the time that
the system overhaul would run around $600. Turns out the problem was
something else, so we never had to do the FI overhaul.
Sounds to me like your cutoff seating is leaking in the FI system. If the
engine runs and performs properly otherwise, I don't see why this would
require a full system overhaul, but I'm hardly an expert. I presume your
mechanic has verified that the problem is not simply a slippage on the
mixture control cable so that you can't pull the control totally into
cutoff.
-Elliott Drucker
Old March 20th 06, 12:51 PM posted to rec.aviation.owning
solution?
I have had the same problem with my IO-540.
Most likely cause is the fuel shutoff plates have a scratch in them.
Lapping them will fix it. Other possibilities a the fuel drain is
clogged and storing fuel. If the drain system has been worked on it may
be too long or if you have a sniffle valve in the drain line it may be
malfunctioning..
Don't let your A&P talk you into a full overhaul unless it is necessary.
There is a lot of un-necessary work done on equipment when system are
not completely understood.....
Michelle (A&P)
Old March 22nd 06, 12:58 AM posted to rec.aviation.owning
Thanks for the input. According to the logbook, the system hasn't been
overhauled since 1983, so a fresh overhaul doesn't seem unreasonable.
I'm getting cost estimates from $1200 to $2000 depending on what has to
be done. Down time is a couple of weeks.
O-360 takeoff power fuel flow question argon39 Owning 13 August 2nd 05 06:23 PM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 08:48 AM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 03:21 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 10:47 PM
