I want to run my engine (ford v-6) this summer for various tests and I
want some sort of prop. What do most people use for props when testing at this stage? I was thinking of glueing together 2 or 3 fir 2x6's or using a laminate beam (leftovers from a remodeling project) and carving some airfoil shape. Seems like it should work if it is balanced. Of course I don't want to sling a blade down the taxiway or through my neighbors hangar door. Anybody offer some suggestions? Thanks. David Woolery |
"Philippe Vessaire" wrote A square wood beam, aera= a*a diam=15*a You find the power with this formula: P=0.0532 * (diam/450)^5 * (rpm/1000)^3 with diam in mm rpm in revolution / mn or diam=((P/0.0532) * 10^9 * 450^5 / rpm^3 ))^0.2 a=diam/15 I you want check 180hp @ 3800rpm diam = 1026mm a = 68.4mm Is the area in the formula the cross sectional area, side of the beam area, surface area, or what? More information is needed, please. -- Jim in NC |
("Philippe Vessaire" wrote)
from Michel colomban (cricri, MC100, MCR01 designer) "We're not worthy. We're not worthy." Montblack :-) |
On 28 Mar 2006 14:41:50 -0800, "
wrote: I want to run my engine (ford v-6) this summer for various tests and I want some sort of prop. What do most people use for props when testing at this stage? I was thinking of glueing together 2 or 3 fir 2x6's or using a laminate beam (leftovers from a remodeling project) and carving some airfoil shape. Seems like it should work if it is balanced. Of course I don't want to sling a blade down the taxiway or through my neighbors hangar door. Anybody offer some suggestions? Thanks. David Woolery When I was ready to test my Ford V6, I bit the bullet and bought an IVO Magnum prop. It's ground adjustable and all three blades adjust simultaneously by cranking a large threaded cylinder in the hub. That way you can flatten out the pitch so that the engine revs up to it's maximum rpm while not moving. I was unable to get the engine to rev past about 3,100 rpm without repitching from the initial setting. I was reluctant to hold that power setting for very long anyway as I was basically blowing things off the walls behind me in the car port, and the prop was sucking sand off the driveway and pitting the prop tips. Corky Scott |
| Thread Tools | |
| Display Modes | |
| Counter rotating propellers | Raoul | Military Aviation | 24 | September 21st 04 06:59 AM |
| New Company selling Airplane Propellers for Experimental, Display and Air | Plane Pieces Inc | Owning | 8 | September 18th 04 06:02 PM |
| Aero Composites Propellers | Badwater Bill | Home Built | 26 | June 18th 04 06:30 AM |
| Missing propellers | Benny | Simulators | 1 | March 18th 04 08:18 PM |
