Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Abrasive blasting references?
Old April 6th 06, 01:28 PM posted to rec.aviation.restoration
Default Abrasive blasting references?
Can anyone suggest a text or other reference on abrasive ('sand')
blasting for removing rust from an aircraft steel frame?
It should discuss size of compressor, components I'll need, whether or
not a booth is needed, what abrassive material to use. Thanks, Mike
(in the meanwhile I'll polish off GOOGLE)
Old April 6th 06, 04:50 PM posted to rec.aviation.restoration
Do a search for CLEMCO.
They manufacture abrasive blasting equipment.
Plastic beads or glass beads work well on many parts. Many other blast
medias are also available.
There is a material which is a coarse form of baking power. Works well
and does little base metal removal but removes coatings and light
surface rust.
DO NOT USE SAND!!!!! Many dangers and problems with sand. It is
outlawed in many countries but still widely used by many in the US.
Black Beauty is an angular abrasive which will leave your surface too
rough.
Remove references etc... Andy Davey Soaring 0 October 24th 04 11:49 PM
Blasting and painting [email protected] Home Built 7 June 3rd 04 04:14 PM
