If I purchase an expirimental, what are the rules in regards to the 51%
build. Obvioulsy I am not the manufacturer...so is there anyway around this? Can I simply pass an exam then tak over all maintenance etc. on the plane? |
On Mon, 10 Apr 2006 03:16:46 GMT, "iliad"
wrote: If I purchase an expirimental, what are the rules in regards to the 51% build. Obvioulsy I am not the manufacturer...so is there anyway around this? Can I simply pass an exam then tak over all maintenance etc. on the plane? Anyone can do maintenance on an Experimental/Amateur-Built aircraft. You don't have to be the builder, nor do you have to take special courses. However, to perform the annual condition inspection, you must either possess a Repairman Certificate for that airplane (only awarded to the builder) or have an A&P license. I do all the maintenance on my Fly Baby, which I bought in flying condition about ten years ago. Once a year, I have an A&P examine the aircraft to verify its airworthiness. Ron Wanttaja |
Ron Wanttaja wrote:
On Mon, 10 Apr 2006 03:16:46 GMT, "iliad" wrote: If I purchase an expirimental, what are the rules in regards to the 51% build. Obvioulsy I am not the manufacturer...so is there anyway around this? Can I simply pass an exam then tak over all maintenance etc. on the plane? Anyone can do maintenance on an Experimental/Amateur-Built aircraft. You don't have to be the builder, nor do you have to take special courses. However, to perform the annual condition inspection, you must either possess a Repairman Certificate for that airplane (only awarded to the builder) or have an A&P license. I do all the maintenance on my Fly Baby, which I bought in flying condition about ten years ago. Once a year, I have an A&P examine the aircraft to verify its airworthiness. Ron Wanttaja I believe there's a provision for a non-builder owner to obtain a Repairman's Certificate by taking a specialized course no? I like the setup here in Canada. Whoever's name is on the CofR of an amateur built signs off on all maint, mods and annuals regardless of who built it. John |
![]() "J.Kahn" wrote I believe there's a provision for a non-builder owner to obtain a Repairman's Certificate by taking a specialized course no? I like the setup here in Canada. Whoever's name is on the CofR of an amateur built signs off on all maint, mods and annuals regardless of who built it. Only on a factory built LSA, not on an amateur built aircraft. -- Jim in NC |
On Mon, 10 Apr 2006 21:13:54 -0400, "J.Kahn" wrote:
I believe there's a provision for a non-builder owner to obtain a Repairman's Certificate by taking a specialized course no? No. The Repairman Certificate for an Experimental/Amateur-Built aircraft is a one-time-only affair. As Jim mentioned, the new Light Sport Category is different. An owner can take a 16-hour course to earn the Light Sport/Inspection Repairman Certificate. They can then perform inspections on any *Experimental* Light Sport Aircraft category aircraft they own. More precisely, they must own the aircraft and the aircraft must be of the same class (fixed wing, powered parachute, etc) as the course they took. The LS/I Repairman Certificate does not authorize the owner to perform the annuals on production-type LSAs. However, the owner of such an LSA can easily have the airplane transferred into the Experimental LSA category. I like the setup here in Canada. Whoever's name is on the CofR of an amateur built signs off on all maint, mods and annuals regardless of who built it. I like your system better, too...I think the "Owner Maintenance" category you folks have makes a lot of sense, too. Unfortunately, the FAA doesn't care what I think. :-) Ron Wanttaja |
On Mon, 10 Apr 2006 21:17:14 -0700, Ron Wanttaja
wrote: I like the setup here in Canada. Whoever's name is on the CofR of an amateur built signs off on all maint, mods and annuals regardless of who built it. I like your system better, too...I think the "Owner Maintenance" category you folks have makes a lot of sense, too. Unfortunately, the FAA doesn't care what I think. :-) Ron Wanttaja and the australian authorities (I use that word generously) dont care what we think either. In my book the canadians are the only country to have competently regulated for privately owned aircraft. Stealth Pilot |
Ron Wanttaja wrote:
However, to perform the annual condition inspection, you must either possess a Repairman Certificate for that airplane (only awarded to the builder) or have an A&P license. What really sucks is that only one person can qualify for that. If two people build the airplane, they have to decide who gets the certificate. I'm particularly upset by this, because I worked right alongside my dad when we were building our RV, and I know how it's put together about as well as he does. And then, I end up doing half the annual anyways. Should I ever end up getting the airplane, I wouldn't be able to do the annuals on it, and would either have to hire an A&P (ie, $$$$) or fly it back to his place once a year and have him sign it off. Oh well, guess I'll have to wait a few more years till I can afford to build one myself... |
Theres nothing in the rules limiting the number of repairmans certs issued
per project. ASK THE DAR to give you BOTH the ticked after you show him all the work YOU BOTH DID TOGETHER. It has to be fairly well documented however........ There is a correlation with how much work go's into the project and on complex laborious builds, partners can both meet the "implied" experience requirements. On an quickbuild RV's, I'm suprised you can even get a reparimans cert, the skillsets, knowlege acquired seem to be pretty limited. If you shake the box long enough it falls out built.......... "Bob Martin" wrote in message ... Ron Wanttaja wrote: However, to perform the annual condition inspection, you must either possess a Repairman Certificate for that airplane (only awarded to the builder) or have an A&P license. What really sucks is that only one person can qualify for that. If two people build the airplane, they have to decide who gets the certificate. I'm particularly upset by this, because I worked right alongside my dad when we were building our RV, and I know how it's put together about as well as he does. And then, I end up doing half the annual anyways. Should I ever end up getting the airplane, I wouldn't be able to do the annuals on it, and would either have to hire an A&P (ie, $$$$) or fly it back to his place once a year and have him sign it off. Oh well, guess I'll have to wait a few more years till I can afford to build one myself... |
On Thu, 13 Apr 2006 15:33:44 -0500, "pbc76049"
wrote: Theres nothing in the rules limiting the number of repairmans certs issued per project. From Advisory Circular 65-23A, "CERTIFICATION OF REPAIRMEN (EXPERIMENTAL AIRCRAFT BUILDERS)": "6 ELIGIBILITY. An individual desiring to be certificated as a repairman is required to: ..... c. Be 18 years of age or older, and the primary builder of the aircraft. For example, when a school, club, or partnership builds an aircraft, only one individual will be considered for a repairman certificate for each aircraft built...." Seems pretty definite to me. http://www.wanttaja.com/avlinks/AC65-23A.pdf Ron Wanttaja |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
T182RG cost of ownership, maintenance, operation? | john szpara | Owning | 5 | March 29th 06 08:10 AM |
TR182 cost of ownership - maintenance, etc. | john szpara | Piloting | 20 | March 29th 06 12:11 AM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
