IFR Refresher January 2004 Quiz
Old February 5th 04, 02:12 PM
Paul Tomblin
Default IFR Refresher January 2004 Quiz
Ok, this isn't the first time this has happened, but this month's quiz
asks you for the airport ident of the airport you use if you can't get the
local altimeter settings. Ok, the plate says to use "Whichita
Mid-Continent", that part I got. But then the quiz answer says to look on
the en route chart to see the ident. Except I can't even find Wichita
Mid-Continent on the en route chart segment they printed, and even if I
could, I don't see how you get the ident off the en route. That's
something that's always annoyed me about en route charts, is that they
don't print the identifier. And yet this is at least the second time
where the quiz has expected you to get the ident off the en-route. So are
the quiz composers seeing something that I'm not? Or are they expecting
it's there because they're used to Jepp en-routes?
Fortunately, he was promoted far enough up the management ladder that he
no longer has any real responsibility and is kept far away from sharp or
dangerous objects - such as cc, gcc, vi and emacs. -- Curt Fennell
Old February 8th 04, 03:55 PM
I don't know anything about what they printed but I am looking at the current
NACO low-altitude (L6) en route chart and see "Wichita (ICT) Mid-Continent
1338 L 103"
So, that tells me that Wichita Mid-Continent is ICT or KICT.
2004 Homebuilt Statistics Ron Wanttaja Home Built 8 January 15th 05 05:24 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
Marske Flying Wing Workshops for 2004 mat Redsell Home Built 0 March 9th 04 05:01 PM
Machinista 2004 - call for entries Robb Mitchell Machinista.org Home Built 0 February 24th 04 03:19 PM
