Volkslogger downloads with high-speed serial port & OLC submission
Old April 17th 06, 04:39 PM posted to rec.aviation.soaring
Default Volkslogger downloads with high-speed serial port & OLC submission
This is just a data point for those having problems with OLC files.
I last evening I downloaded a 4 hour flight logged at a 4 second intervals.
The secure .igc file downloaded in 12 seconds. The VL took 45 seconds to
'calculate the key' before starting the download. The high-speed serial
port card driver is set to auto-select the fastest bit rate without data
corruption. The desktop computer is a 2.6 GHz Win XP machine. The file
uploaded from SeeYou to OLC without a hitch.
This is MUCH faster than last year using an old 450 MHz Win 98 machine with
1st generation serial ports.
Bill Daniels
Old April 18th 06, 01:03 AM posted to rec.aviation.soaring
Bill,
Would it pass the IGC securty check program?
Thanks for the info. I need to get a serial card for my new XP laptop.
John
Old April 18th 06, 01:41 AM posted to rec.aviation.soaring
"Go" wrote in message
Bill,
Not sure. Just checked the OLC.
I'm not sure that you can add a card to a laptop.
Bill Daniels
Old April 18th 06, 02:38 AM posted to rec.aviation.soaring
Sure you can add a card to a notebook: a PC Card.
See, for example:
http://www.pcconnection.com/ProductD...ourceID=k81092
These tend to work better than some of the USB-to-Serial
adapters (we've found Belkin actually work).
Hope this helps,
Best Regards, Dave
Old April 18th 06, 07:11 AM posted to rec.aviation.soaring
Yes, I was thinking about a pcmcia card, sure glad they started calling
them pc cards as I just couldn't remember all those letters!
My new laptop has four USB ports, one pcmcia port, and no serial or
floppy as they have been deemed obsolete now. I hadn't decided if I
should use up my only pcmcia card port or one of the many USB's.
So the Belkin pcmcia serial card works well, or did you mean a Belkin
USB to serial adaptor? I need to use it for my volkslogger and for my
LX5000.
But as I have interest in records once I get the new laptop serial
adaptor up and running I need to see if the new SeeYou higher speed
upload capability will pass the igc securty test.
I appreciate the help.
John
OT High Speed 'Net Access Options Bill Kambic Naval Aviation 3 September 19th 04 04:07 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 05:12 PM
German High Speed SAM Missile JT Military Aviation 11 October 22nd 03 06:14 PM
