Oil temperature questions
Old April 19th 06, 04:45 PM posted to rec.aviation.owning
Default Oil temperature questions
A few weeks ago while flying through -17 degree C air aloft, I spotted what
appeared to be really a low oil temperature indication of the
turbo-normalized, IO-520 engine in my V35. For a few moments, the oil
temperature was around 125 degrees F.
When I landed I contacted my mechanic, who verbalized that he suspected the
oil thermostat (the valve that controls the oil flow into the oil cooler)
was bad. In his experience, he stated that the oil temperature should be
around 180 degrees F.
After removing and inspecting this thermostat, he concluded that the valve
was not seating properly and that most likely allowed oil into the cooler,
despite the lower oil temperature. Thus, I authorized the replacement of
it (it was under warranty).
These days and with a new thermostat installed, I am only seeing oil
temperatures of no higher than 155-160 degrees F while flying through air
of +1 to +5 degrees C. Does this still seem low?
BTW, I did share this observation with my mechanic and he called Tornado
Alley (manufacturers of the turbo-normalized system). TA was not alarmed
with the 155 degree F oil temperature.
For some additional information, the oil cooler is located on the top of
the firewall, directly behind the engine, rather than in the front.
Peter
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Yesterday's IFR flight with questions A Lieberman Instrument Flight Rules 30 November 23rd 05 11:31 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Total Air Temperature question Mike Rapoport Instrument Flight Rules 12 December 14th 04 07:20 PM
