Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Temporary, portable sand blasting 'cabinet'??
Old April 23rd 06, 01:18 AM posted to rec.aviation.restoration
Default Temporary, portable sand blasting 'cabinet'??
I can use the club's compressor, but I need to bring my bead-blaster
to that location.
Looking for schemes for erecting a temporary, portable sand blasting
'cabinet'. Thinking of something large enough for a rudder or smaller
if we can insert half of the work at a time.
Thinking of a poly-sheet over a PVC frame about a foot high.
Anyone done something similar? - MIke
Old April 23rd 06, 04:41 AM posted to rec.aviation.restoration
"Michael Horowitz" wrote in message
news
to that location.
For sandblasting I just lay out a big tarp on the lawn. Set the parts on a
basket. Most of the sand stays on the tarp, the rest ends up in the grass
Setting buckets around the work helps trap more...
'course sand is cheaper than beads - I don't mind if I loose 5-10%.
Wear a good dust mask and goggles. Tyvek coveralls help keep the sand out of
your shorts.
Geoff
Portable GPS w/ VOR? Mini Moebius Piloting 6 June 3rd 11 01:30 PM
A Temporary Flight Restriction is like ... Larry Dighera Piloting 1 August 19th 05 04:21 AM
Portable Push-To-Talk switch help Eric Brown Owning 9 April 16th 04 05:26 AM
