Expirimental Crash Plant Cityl- No records on file?
Old April 25th 06, 05:56 PM posted to rec.aviation.homebuilt
Default Expirimental Crash Plant Cityl- No records on file?
About a month ago a friend and I watched an expirimental aircraft crash at
Plant City in Florida.
It was a two seater ultralight, with a registered N number. We even helped
pick up the pieces
so to speak.
The gentleman piloting came in for a landing and I could instantly tell he
was having problems. It appeared
that he stalled the craft, it fell out about 10 feet from the sky, bounced
up hard, then he did a go around.
The second time around it was worse. He stalled it at a higher altitude and
he crashed hard. Bent the back wheels
and frame in two, and the plane was out of commission after that.
Haven't seen any news reports or other info on it. He wasn't hurt, but was
extremley lucky as a landing like he had
could have easily broke his back.
Anyone see anything on it by chance?
Old April 26th 06, 01:40 AM posted to rec.aviation.homebuilt
On Tue, 25 Apr 2006 16:56:42 GMT, "iliad"
pick up the pieces
so to speak.
Probably never got reported. Just another hard landing.
Old April 26th 06, 01:55 AM posted to rec.aviation.homebuilt
pick up the pieces
so to speak.
No info on that incident, but might have a likely explanation of why you
haven't seen anything.
It's not unusual for the NTSB to hand off investigations to the local
FAA if there are no serious injuries or deaths. If the FAA can call it
an 'incident' instead of an accident, they will often do so & not
investigate. I can speak from personal knowledge that even with heavy
structural damage to an experimental they have looked the other way when
they were busy & no one insisted on a report (who would?).
You can bet that line level FAA guys hate paper work as much as we do.
Charlie
Old May 1st 06, 11:02 PM posted to rec.aviation.homebuilt
pick up the pieces
so to speak.
Here in the US, Ultralights don't have two seats or N-numbers.
What you described was hard landing that damaged
the aircraft. It may well have not been reported, especially if the
plane
or pilot were not legal.
FF
Uploading CAI file from Cam 20 to OLC Roy Clark, B6 Soaring 25 May 26th 05 04:42 AM
FAA plane crash records? Larry Home Built 3 August 23rd 04 03:52 PM
USS Liberty Challenge/Reward Issac Goldberg Naval Aviation 75 July 16th 04 09:28 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
