Polarized Instrument Display
Old May 5th 06, 02:57 AM posted to rec.aviation.soaring
Default Polarized Instrument Display
I recently bought some new polarized prescription glasses and have found
that when I look directly at the display screen on my LX5000, I can't see
anything. I can see it better if I turn my head and look obliquely at it
(not really practical). I suspect the screen has a polarization on the
surface and somehow it is reacting with the polarization on my glasses.
Does any one know of some kind of fix for the LX5000 screen for this
situation? I really don't want to change glasses.
Rick
Old May 5th 06, 03:30 AM posted to rec.aviation.soaring
Rick,
You either have defective polarization on your glasses or the LX has
incorrect polarization on the display. You need to determine which is
your problem child. Don't be too sure that one is the culprit over the
other. Some soaring instrument manufacturers have had problems with
some of their units when the subassembly manufacturer made them with the
wrong polarization. All of your LCD instruments should have similar
polarization.
Try other polarized sunglasses and see if that fixes it. With
everything with the correct polarization, you should be able to see the
LCD screens with your head oriented to the normalized position.
Regards,
Larry
-- zero one - USA
"Rick" wrote in message
news:%px6g.1696$yh.681@trnddc04:
Rick
Old May 5th 06, 04:48 AM posted to rec.aviation.soaring
Larry's right. I bought a pair of sunglasses last year at Sears and
one lens had the polorization 1 way and the other at 90 degrees. Did
wierd things to perspective and computer screens (eg WinPilot). I
opted for a full refund.........
MB
01-- Zero One wrote:
Rick,
polarization.
Regards,
Larry
-- zero one - USA
Rick
--BF4ED55A-EB55-438D-98B5-964CA6D1D8B8
Content-Type: text/html
X-Google-AttachSize: 4551
html xmlns="urn:schemas-microsoft-comfficeffice" xmlns:w="urn:schemas-microsoft-comffice:word" xmlns:st1="urn:schemas-microsoft-comffice:smarttags" xmlns="http://www.w3.org/TR/REC-html40"
head
meta http-equiv=Content-Type content="text/html; charset=us-ascii"
meta name=Generator content="Microsoft Word 11 (filtered medium)"
o:SmartTagType namespaceuri="urn:schemas-microsoft-comffice:smarttags"
name="place"/
name="country-region"/
!--[if !mso]
style
st1\:*{behavior:url(#default#ieooui) }
/style
![endif]--
style
/* Font Definitions */
@font-face
{font-family:Papyrus;
panose-1:3 7 5 2 6 5 2 3 2 5;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
p.MsoEnvelopeReturn, li.MsoEnvelopeReturn, div.MsoEnvelopeReturn
{margin:0in;
font-size:10.0pt;
font-family:Papyrus;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{colorurple;
span.EmailStyle18
{mso-style-typeersonal-compose;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
/style
/head
body lang=EN-US link=blue vlink=purple
div class=Section1
p class=MsoNormalfont size=3 face="Times New Roman"span style='font-size:
12.0pt'Rick, o/o/span/font/p
12.0pt'o /o/span/font/p
12.0pt'You either have defective polarization on your glasses or the LX has
your problem child.  Don’t be too sure that one is the culprit over
the other.  Some soaring instrument manufacturers have had problems with
some of their units when the subassembly manufacturer made them with the wrong
polarization.  o/o/span/font/p
12.0pt'Try other polarized sunglasses and see if that fixes it.  With
everything with the correct polarization, you should be able to see the LCD
screens with your head oriented to the normalized position.o/o/span/font/p
12.0pt'Regards,o/o/span/font/p
12.0pt'Larry  o/o/span/font/p
12.0pt'-- zero one –  st1:country-region w:st="on"st1lace
w:st="on"USA/st1lace/st1:country-regiono/o/span/font/p
12.0pt'br
br
"Rick" > wrote in message
news:%px6g.1696$yh.681@trnddc04:br
br
> I recently bought some new polarized prescription glasses and have foundbr
> that when I look directly at the display screen on my LX5000, I can't seebr
obliquely at itbr
on thebr
> surface and somehow it is reacting with the polarization on my glasses.br
> br
> Does any one know of some kind of fix for the LX5000 screen for thisbr
> situation?  I really don't want to change glasses.br
> br
> Ricko/o/span/font/p
/div
/body
/html
--BF4ED55A-EB55-438D-98B5-964CA6D1D8B8--
Old May 5th 06, 04:50 AM posted to rec.aviation.soaring
Larry,
Thanks for your response. I have another pair of polarized prescription glasses and the same thing occurs, namely I can't see the screen unless I turn my head and look at it obliquely. Maybe my next step should be to look at a few other LX5000 display screens with my glasses and see if there is a difference. Thanks again.
Rick
"01-- Zero One" wrote in message ...
Rick,
You either have defective polarization on your glasses or the LX has incorrect polarization on the display. You need to determine which is your problem child. Don't be too sure that one is the culprit over the other. Some soaring instrument manufacturers have had problems with some of their units when the subassembly manufacturer made them with the wrong polarization. All of your LCD instruments should have similar polarization.
Try other polarized sunglasses and see if that fixes it. With everything with the correct polarization, you should be able to see the LCD screens with your head oriented to the normalized position.
Regards,
Larry
-- zero one - USA
"Rick" wrote in message news:%px6g.1696$yh.681@trnddc04:
Rick
Old May 5th 06, 05:08 AM posted to rec.aviation.soaring
Early Cambridge 302's had the screen polarization 90 degrees off. If you
never use polarized sun glasses, you'd likely never know. Wear them, and all
the other LCD's look fine except for the dark 302! Later versions corrected
the problem. I sent mine in to get it fixed, which Cambridge did at no
charge as I had them calibrate it at the same time.
all the best,
bumper
news:s3z6g.15299$O_6.15040@trnddc08...
Larry,
Rick
Rick,
Regards,
Larry
-- zero one - USA
Rick
Old May 5th 06, 01:47 PM posted to rec.aviation.soaring
Cambridge did the same for me, and it fixed the problem. They explined that
the polarization is in the cover glass for the LCD.
Some (many) "Pay-at-the-Pump" displays are invisible with my polarized
glasses
Hartley Falbaum
"bumper" wrote in message
all the other LCD's look fine except for the dark 302! Later versions
corrected the problem. I sent mine in to get it fixed, which Cambridge did
at no charge as I had them calibrate it at the same time.
all the best,
bumper
Larry,
Rick
Rick,
polarization.
Regards,
Larry
-- zero one - USA
Rick
Old May 5th 06, 05:46 PM posted to rec.aviation.soaring
As a quick check on whether the LX screen or your glasses are wrong, go
find a calm lake or pond. When the sun is reflecting off it at you, your
glasses should dramatically reduce the reflections from the water
surface. Both lenses should be the same.
This is because reflected light from a liquid surface is polarized by
being reflected (IIRC its horizontally polarized). The whole point of
polarized glasses is to cut this reflection, so if they don't do that
take them back and demand a refund.
Once you know the glasses are set up right its time to go check on the
LX screen.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old May 5th 06, 07:25 PM posted to rec.aviation.soaring
Rick,
I'm not sure what kind of sunglasses you have but I'm highly suspicious
of them.
I've had two LX5000s and now an LX7007. I've used several brands of
sunglasses and never had a polarization interference problem with any
of them.
~ted/2NO
Old May 5th 06, 10:35 PM posted to rec.aviation.soaring
I have the same problem with my LX-5000.
I've tried 3 pairs of polarized glasses with the same result. But I
recently got a pair of non-polarized sunglasses just for flying. Life
is better...
Jeremy
Old May 11th 06, 07:07 PM posted to rec.aviation.soaring
"Jeremy Zawodny" wrote in message
news
recently got a pair of non-polarized sunglasses just for flying. Life is
better...
Jeremy
Although I have not had the problem with instruments I have had it with PDAs
in the cockpit. Personally I don't think that polarised sunglasses are the
things to use when flying because of the possibility of seeing the stress
lines and so on in the canopy and the possibility of interference with LCD
displays. I much prefer tinted specs for this reason.
Robin
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 03:41 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
