SWRFI - next weekend!
Old May 8th 06, 01:10 AM posted to rec.aviation.homebuilt
Default SWRFI - next weekend!
South West Rggional Fly-In
Next weekend
Hondo, Texas
Ya'll come on down!
Richard
Old May 8th 06, 06:47 AM posted to rec.aviation.homebuilt
Next weekend
Hondo, Texas
Ya'll come on down!
Richard
BRAVO, Richard! you broke rec.aviation convention and posted the
location in clear, concise language!
Rant over.
Old May 8th 06, 07:20 AM posted to rec.aviation.homebuilt
Rant over.
Now, if we had an identifier, to know which airport in Hondo, and to type it
in for the flight planning software! Bfg
Can't win for losin', right? :-)
Old May 8th 06, 04:41 PM posted to rec.aviation.homebuilt
Rant over.
Why can't we give BOTH? It makes life a lot easier for all of us!
Old May 8th 06, 04:49 PM posted to rec.aviation.homebuilt
Rant over.
KHDO is what I found at AirNav.
http://www.airnav.com/airport/KHDO
FAA Identifier:
HDO
Lat/Long:
29-21-34.3000N / 099-10-36.0000W
29-21.571667N / 099-10.600000W
29.3595278 / -99.1766667
(estimated)
Elevation:
930 ft. / 283.5 m (surveyed)
Variation:
08E (1980)
From city:
2 miles NW of HONDO, TX
Zip code:
78861
Airport Operations
Airport use:
Open to the public
Sectional chart:
SAN ANTONIO
Control tower:
no
ARTCC:
HOUSTON CENTER
FSS:
SAN ANGELO FLIGHT SERVICE STATION [1-866-300-3867]
NOTAMs facility:
HDO (NOTAM-D service available)
Attendance:
MON-FRI 0800-1700, SAT IREG
Pattern altitude:
1800 ft. MSL
Wind indicator:
lighted
Segmented circle:
yes
Lights:
DUSK-DAWN
Beacon:
white-green (lighted land airport)
Airport Communications
CTAF/UNICOM:
122.725
WX ASOS:
119.675 (830-426-3060)
OPNS:
121.95 123.3 123.5
RWY SUPERVISOR UNIT FOR RWY 17L-35R CALL 'TINCAN' ON 123.5; IF
UNABLE TO CONTACT CALL 'HONDO MOBILE' ON 123.3.
APCH/DEP SVC PRVDD BY HOUSTON ARTCC ON FREQS 134.95/269.4
(KERRVILLE RCAG).
Nearby radio navigation aids
VOR radial/distance
VOR name
Freq
Var
HDO at field
HONDO VOR/DME
109.40
08E
CSIr169/33.8
CENTER POINT VORTAC
117.50
08E
SSFr270/(38.8)
STINSON VOR
108.40
09E
NDB name
Hdg/Dist
Freq
Var
ID
HONDO
at field
329
08E
HMA
CASTROVILLE
265/17.1
338
08E
CVB
DEVINE
310/18.2
359
07E
HHH
UVALDE
062/30.7
281
07E
UVA
Airport Services
Fuel available:
100LL JET-A
FOR FUEL AFT HR CALL 830-741-3836, MAJOR CREDIT CARD
ONLY.
Parking:
tiedowns
Airframe service:
MINOR
Powerplant service:
MINOR
Bottled oxygen:
NONE
Bulk oxygen:
NONE
Runway Information
Runway 8/26
Dimensions:
6059 x 150 ft. / 1847 x 46 m
Surface:
concrete, in good condition
Weight bearing capacity:
Single wheel:
30000 lbs
Double wheel:
45000 lbs
Double tandem:
90000 lbs
Runway edge markings:
RY NUMBER IS FADED.
RY NUMBERS ARE FADED.
RUNWAY 8
RUNWAY 26
Latitude:
29-21.842200N
29-21.843050N
Longitude:
099-11.104300W
099-09.963150W
Elevation:
930.1 ft.
922.4 ft.
Gradient:
0.0
0.0
Traffic pattern:
left
left
Runway heading:
082 magnetic, 090 true
262 magnetic, 270 true
Displaced threshold:
no
79 ft.
Markings:
basic, in poor condition
Touchdown point:
yes, no lights
yes, no lights
Obstructions:
none
6 ft. trees, 200 ft. from
runway, 235 ft.
right of centerline
APCH RATIO 0:1 BASED ON DSPLCD
THLD; 6 FT TREES AT THLD 230 FT
RIGHT.
+6 FT TREES AT THLD 230 FT
RIGHT.
Runway 13/31
Dimensions:
6045 x 150 ft. / 1843 x 46 m
Surface:
Single wheel:
30000 lbs
Double wheel:
45000 lbs
Double tandem:
90000 lbs
RUNWAY 13
RUNWAY 31
Latitude:
29-21.702950N
29-20.998183N
Longitude:
099-11.097217W
099-10.291733W
Elevation:
927.3 ft.
909.3 ft.
Gradient:
0.0
0.0
Traffic pattern:
left
left
Runway heading:
127 magnetic, 135 true
307 magnetic, 315 true
98 ft.
471 ft.
Markings:
Touchdown point:
yes, no lights
yes, no lights
Runway 17L/35R
Dimensions:
6024 x 150 ft. / 1836 x 46 m
Surface:
Single wheel:
30000 lbs
Double wheel:
45000 lbs
Double tandem:
90000 lbs
Runway edge lights:
medium intensity
RUNWAY 17L
RUNWAY 35R
Latitude:
29-21.984317N
29-20.990417N
Longitude:
099-10.321183W
099-10.320550W
Elevation:
927.1 ft.
909.5 ft.
Gradient:
0.3
0.3
Traffic pattern:
left
right
Runway heading:
172 magnetic, 180 true
352 magnetic, 360
true
Markings:
basic, in poor
condition
Touchdown point:
yes, no lights
yes, no lights
Obstructions:
10 ft. trees, 450 ft. from runway, 270 ft.
left of centerline, 25:1 slope to clear
none
Runway 4/22
Dimensions:
5400 x 150 ft. / 1646 x 46 m
Surface:
Single wheel:
30000 lbs
Double wheel:
45000 lbs
Double tandem:
90000 lbs
RY NUMBER IS FADED.
RUNWAY 4
RUNWAY 22
Latitude:
29-21.328667N
29-21.959050N
Longitude:
099-11.001250W
099-10.282583W
Elevation:
918.7 ft.
925.9 ft.
Gradient:
0.2
0.2
Traffic pattern:
left
left
Runway heading:
037 magnetic, 045 true
217 magnetic, 225 true
294 ft.
532 ft.
Markings:
Touchdown point:
yes, no lights
yes, no lights
Runway 17R/35L
Dimensions:
3224 x 140 ft. / 983 x 43 m
Surface:
asphalt, in good condition
Single wheel:
30000 lbs
Double wheel:
45000 lbs
Double tandem:
90000 lbs
Operational restrictions:
CLSD TO ACFT OVER 12500 LBS.
RUNWAY 17R
RUNWAY 35L
Latitude:
29-21.780617N
29-21.248700N
Longitude:
099-10.998000W
099-10.997800W
Elevation:
927.9 ft.
916.9 ft.
Gradient:
0.3
0.3
Traffic pattern:
right
left
Runway heading:
352 magnetic, 360 true
454 ft.
no
Markings:
basic, in fair condition
Touchdown point:
yes, no lights
yes, no lights
Airport Operational Statistics
Aircraft based on the field:
22
Single engine airplanes:
22
Aircraft operations: avg 69/day
74%
military
17%
local general aviation
9%
transient general aviation
Additional Remarks
MARKINGS ALL RYS ARE NSTD; NRS 30 FT TALL; NPI BARS 100 FT
LONG; RY 17R/35L NO CNTRLN.
ALL TWYS HOLDING LINE MARKINGS NSTD.
EXTENSIVE PILOT TRNG IN T6-A ACFT BEING CONDUCTED UNDER
THE RANDOLPH 2A MOA & WITHIN 15 NM OF HONDO MUNI MON-FRI
SR-SS FM SFC TO 7500 FT MSL. WKEND FLYING CONDUCTED AS
NEEDED.
U.S. AIR FORCE T-6 ACFT FLY A NONSTANDARD RIGHT TFC PAT TO RY
17L & A NONSTANDARD LEFT TFC PAT TO RY 35R.
MILITARY USE: MISC - TOUCH AND GO TRNG PROVIDED ONLY O/R
CTC RIDGE CON-121.95, TINCAN MOBILE-122.8 OR HONDO
MOBILE-123.3 FOR ADVSY WHEN 20 NM OUT.
A57-04
APCH RATIO 50:1 BASED ON DSPLCD THLD.
A57-13
A57-17R
A57-22
A57-31
Instrument Procedures
NOTE: All procedures below are presented as PDF files. If you need a
reader for these files, you should download the
free Adobe Reader.
NOT FOR NAVIGATION. Please procure official charts for flight.
FAA instrument procedures published for use between 13 April 2006 at
0901Z and 11 May 2006 at 0900Z.
IAPs - Instrument Approach Procedures
RNAV (GPS) RWY 17L
download (198KB)
VOR RWY 17L
download (125KB)
NDB OR GPS RWY 35R
download (224KB)
Other nearby airports with instrument procedures:
T89 - Castroville Municipal Airport (17 nm E)
23R - Devine Municipal Airport (18 nm SE)
KUVA - Garner Field Airport (31 nm W)
KSKF - Lackland Air Force Base (Kelly Field Annex) (31 nm E)
T30 - Mc Kinley Field Airport (32 nm S)
Old May 8th 06, 10:34 PM posted to rec.aviation.homebuilt
7
chuckle Yeah, I agree; it couldn't take much effort from the poster.
Really, I was just trying to have a little fun, at your expense. You know,
twisting the knife, a little. g
Old May 8th 06, 11:08 PM posted to rec.aviation.homebuilt
("Morgans" wrote)
know, twisting the knife, a little. g
And the salt. Don't forget the salt. :-)
Montblack
New MontJet update is in the works.
I'll need to strap on my salt-proof Hazmat suit before posting.
Old May 9th 06, 02:18 AM posted to rec.aviation.homebuilt
Rant over.
type it in for the flight planning software! Bfg
FAA Identifier:
HDO
Too much info can't you just give the identifier, I can look up all the rest
bg and running for cover!
John
Old May 9th 06, 03:35 AM posted to rec.aviation.homebuilt
But what is the name of the control tower operator? Damn, can't you
get anything right?
BFG
Old May 9th 06, 04:09 AM posted to rec.aviation.homebuilt
"Montblack" wrote in message
("Morgans" wrote)
Thanks! - My bad, forgetting that! ;-)
Combo Deals -- Do they work? Jay Honeck Piloting 60 September 29th 05 05:45 PM
SWRFI - 05, The Texas Flyin... LONG David Staten Piloting 6 May 27th 05 04:09 PM
Weekend IFR ground school with Aviation Seminars Brad Z Instrument Flight Rules 1 September 20th 04 04:05 PM
Announcement: M-ASA Weekend Open (USA East Coast) Chris OCallaghan Soaring 1 June 29th 04 07:30 PM
The War's Lost Weekend WalterM140 Military Aviation 32 May 18th 04 08:42 AM
