Ventus 2 wing wheel
Old May 8th 06, 10:07 PM posted to rec.aviation.soaring
Default Ventus 2 wing wheel
The factory wing wheel for my V2C is having some lateral stability
issues. The cuff has the nice feature of allowing the flaperon to move,
but after moving the glider even short distances, the wheel cocks badly
to one side or another. Does anyone have any suggestions for modifying
this design so it behaves less hazardly?
~ted/2NO
Old May 8th 06, 10:42 PM posted to rec.aviation.soaring
Several of us have noted this problem. Worse still, the hinge on the
top surface of the wing can "ding" the surface as it is levered
sideways.
The obvious fix is to mod the wheel so that it becomes castoring -
lateral forces will then straighten the wheel instead of flexing the
wing. I have already discussed this with one of our ASA engineers and
have a sketch for a mod, but haven't done anything yet.
Old May 9th 06, 05:23 AM posted to rec.aviation.soaring
Or you guys could order one of Mark Mocho's which are rock solid and
work great! www.mmfabrication.com I'm pretty sure he has a couple
ready for the V2.
-Mitch
Old May 9th 06, 06:37 AM posted to rec.aviation.soaring
2NO, if you would like, we could whip something up pretty quick to
provide some lateral support for the wheel, such as two lateral braces
that would attach to the outside edge of the cuff, and extend down
close the the wheel fork. Let me know, GAP...
Old May 9th 06, 09:58 PM posted to rec.aviation.soaring
Karl's design sounds quite similar to what I had in mind for my Discus
wheel - get the drawings and we'll have GW take a look at how easy the
mod could be done.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Grob G102 Setup BDS Soaring 11 August 30th 05 04:42 PM
Ventus A and B Wing Root Fairings [email protected] Soaring 17 June 24th 05 03:13 AM
